Results 1 to 8 of 8
    Senior Member Four Rings BCsniper's Avatar
    Jan 29 2010
    north ga
    Lets play a new game - How Hot Is Your Car
    I'm sure the numbers will continue to go up as the summer continues.
    I saw TJ post up 114, so here's my one up on him
    next person to go above 118 post it up
    Active Member Three Rings jeffrey146's Avatar
    Feb 19 2012
    04 s4 noggy avant MT 98 A4 2.8LQM 30V 207K 98 A6 2.8LQA 30V 118K
    Ogden, ut
    Is it allowed to take a blow torch to my sensor?
    Noggy S4 Avant MT B6
    Miro 111s, DRS extreme contact, AudiUp 10mm front 15mm rear spacers, 034 rear sway (soft setting till I get new end links), APR DPS exhaust and tune, H&R springs, Morimoto mini H1 Bixenon retrofit (4300k), clear corner mod & APR tune.
    Veteran Member Four Rings Coderedpl's Avatar
    Jul 27 2007
    2012 VW Golf .:R
    Valley Stream (L.I.), NY / NYC
    Quote Originally Posted by jeffrey146 View Post
    See how high you can get it!
    Current: 2012 Rising Blue 4Dr VW Golf [R 6spd
    Past: 2006 Black Audi S4 tip / 2006 Black A4 2.0T tip
    Jan 29 2010
    north ga
    Nope, no cheating. And no revving your car in a hot garage or any enclosed place where it will be more hot.
    Best if you are at least moving when the shot is taken. However you can half-cheat like I did. This way just before getting on the interstate. After I got up to speed the temp did drop some.
    Senior Member Four Rings Greedo's Avatar
    Oct 26 2009
    *** WANTED: B6/B7 FLAT door blades (moldings). Preferably in light metallic silver. And not warped. ***
    **Stuff that you must have - http://www.audizine.com/classifieds/...9779&protype=1**
    Jan 29 2010
    north ga
    ...Yeah I guess it was you who posted the 114
    However you missed the idea of the thread. You need to top the previous picture.
    Get 119+ and get back to us. Just go drive your car into one of the forest fires out there and you should have no problem.
    Senior Member Four Rings JoshDub's Avatar
    Oct 09 2008
    1990 Audi 90 Quattro 20V, 1989 BMW 325iS
    Quote Originally Posted by BCsniper View Post
    ...Just go drive your car into one of the forest fires out there and stay there.
    Fixed.
    The Awesome™
    Jan 29 2010
    north ga
    that was kind of my hopes when I said that
