Results 1 to 7 of 7
    Active Member Three Rings dbX79's Avatar
    May 24 2012
    Atlanta,GA
    Slight Modifications
    I'm new to the forums. I went into the tech forums but had difficulty finding enough DIY for the B8 A4. I want to switch out my interior lights with LED's and I want the same for my Fog Lights. Any sources you can recommend? I think the dealer will not be much help here. I also wanted to ask about changing the thickness of my tires. I was told if I switch to a 19" wheel I'll lose ride quality, but what about a 18"? Will that be smoother than the 19" because of thickness?
    Senior Member Three Rings Limey's Avatar
    Nov 27 2010
    2004 srt4
    Edmonton,Alberta
    Try the search function, all the answers to your questions are in there
    2009 A4/Brilliant Black/6MT/Usual Vag-Com mods/A5 5 spoke "y" rims with Michelin 255/35/19 super sports/eibach sportline springs/Eurocode inlet pipe/RS4 grill/A4L grills/S-Line side blades/Ecode halogen to bi xenon conversion/LED bulb interior swap/Eurocode Meisterwerk Adjustable Short Throw Shifter/AWE quad tip exhaust/SPM Test & downpipe/APR stage 2 flash
    Active Member Three Rings AWDLover's Avatar
    Feb 07 2012
    2010 A4 Sport, 2009 WRX Premium
    Before you get butchered by the search Nazi's, here's some stuff to get you started. (edit: I am already too late haha)
    Interior LEDs:
    http://www.audizine.com/forum/search...archid=2155143
    Fogs:
    http://www.audizine.com/forum/search...archid=2155145
    Registered Member Two Rings
    Mar 07 2012
    20th Anniversary Gti (Sold)
    http://www.audizine.com/forum/showth...-install-video
    Video that shows you how to do the interior led's. Its a very simple job
    Also read through this thread for installing fog lights
    http://www.audizine.com/forum/showth...42-Yellow-Fogs
    you can either take the front covers off or go through the wheel well. I opted to go through the wheel well and it was pretty easy
    May 24 2012
    Atlanta,GA
    Alright, thanks. I don't use forums much just started to for my ride. I don't need antagonists up on here. Thanks for the links though. I hope it will show me everything.
    Forum Moderator Four Rings Stubek's Avatar
    Feb 13 2004
    2007 Honda Element SC
    Santa Clara, CA
    If you want a good idea of some stuff, look at the thread in my signature which is a list of all the mods I have done with links to the DIYs for some of them.
    Kevin - Moderator, Audizine
    2011 A4 Avant Meteor Grey/Black, Titanium Package, Prem+ Nav, B&O. Euro LED Tail Lights, Tint, LED license plate lights, LED interior lights, custom sub, lots of VAG updates, Eurocode Alu Kruez, Hotchkiss F/R Swaybars
    Build thread: http://www.audizine.com/forum/showth...ead?highlight=
    Forum Moderator Four Rings Blake P's Avatar
    Mar 02 2007
    Fresno, CA
    Plenty of info on these mods has been posted over the past 5 years since the B8 A4 has been in production. Please use the search tool. I promise it works.
