Results 1 to 10 of 10
    Aug 05 2010
    2007 Audi A4 3.2 Quattro; 2010 Acura RDX (my wife's vehicle)
    Central IL
    Is synthetic oil darker than convential oil?
    Allegedly, I just had my 45K maintenance (last of the AudiCare) performed by the dealership on Sat. I checked my oil yesterday, several days later, after only driving a couple hundred miles and it is dark.
    Is this normal? I Googled it and obtained conflicting results. Thanks.
    2014 Monsoon Gray S4 Prem+ | S-Tronic | LH Magma Nappa leather interior | Carbon Atlas inlays | Sports Diff | Adaptive Damping suspension | 19 peelers | MMI Nav | Bang & Olufsen | tints | VAG COM mods via OBDeleven | Autostyle Mats
    Veteran Member Four Rings JPT's Avatar
    Oct 11 2010
    '05 Kawasaki Ninja ZX12R
    Long Island/NY
    You can not go by oil color. People keep saying things about color. The only way to know if the oil is still functioning, is to have it analyzed.
    Dec 11 2008
    '08 A4 Avant SE, '99 4Runner
    Westminster, CO USA
    I had the same question after my initial 5k oil change. 100 miles later it looked so dark compared to my 4Runner with 100k miles that looked like honey after 3000 miles. Even went back to the dealer and discussed. They were cool and gave me a quart of castrol to compare. The castrol oil is definitely darker to begin with than the Mobil 1 synthetic I use in my 4runner. A drop of each on a clean paper towel confirmed this for me.
    I'm satisfied, but always feel better when I am doing my own oil changes in between the 10k intervals recommended.
    Jul 19 2011
    Northern Minneapolis, MN
    This is very common with turboed engines. When you stop the car and the turbo is still hot, it burns the oil sitting in it (why you can buy units to keep your car running for 5min after you get out so it cools oil). Anyways, this makes a ton of black junk in there, and so a normal oil change will not get all of that out. If you want, you can do two oil changes back to back (maybe 10miles in between), and your oil might look nicer. That is why diesels usually have a high oil capacity (along with higher CR's and more blow by).
    All that being said... I wouldnt worry about it. You can go get analysis' done and look at the oil that way, but color alone wont tell you much about the oil. Also, synthetic vs dino, has very little to do with this.
    [FONT=Arial Narrow]Corey - BSME
    08 A4 6MT, Quattro, VAST Stg1, JOM C/O's, 034 RSB, BFI Snub - 24.75" FTG, 255/35-18 V12's
    ------------------> Buy my wheels/tires/spacers/bolts! <------------------
    Aug 05 2010
    Central IL
    Thanks for the advice! Now all I need to address is why I have oil spots in my garage after my dealership oil change.
    Jun 27 2011
    Items for Sale
    Double check the oil drain plug is snug and that it has a new copper washer. This is common at Jiffy Lube places. They're always in a rush and are total morons and end up spilling oil on the engine, which eventually drips down. A dealer I would expect not to do this though but who knows.
    -CP
    2008 Brilliant Black Unicorn (2.0t S-Line Ti 6MT Avant) - Bosch FR6KPP332S plugs - Q5 Rear Aero Wiper
    2012 Q5 2.0t - Stock Mommy Missile
    Former USP CLUB MEMBER #136
    Jul 19 2011
    They didnt tighten the oil filter holder enough. Make them do it with a digital torque wrench!
    Veteran Member Four Rings rongeur's Avatar
    Jun 04 2011
    Clayton, CA
    OR they overtightened and cracked the oil filter canister as it is plastic.
    2008 A4 2.0T Quattro 6MT S-Line QGM
    Stage 3 JHM TD05H-R on a fully built motor
    Build Thread
    Veteran Member Four Rings Jay-Bee's Avatar
    Feb 25 2011
    B7 Avant 2.0T
    Calgary, AB
    My drain nipple on the filter housing leaks a little, the cap was loose and dripping down till i tightened it.
    2008 Audi A4 Avant 2.0T
    2004 VW Golf TDI-PD
    Jul 19 2011
    Quote Originally Posted by rongeur View Post
    yeah, or this. lol
