Senior Member
Four Rings
BB5 LM Reps with Tires; Pearl White with Gold BBS Hardware and BBS Red Center Caps
Senior Member
Four Rings
I'll give you $900 shipped bro
Senior Member
Four Rings
Senior Member
Four Rings
Senior Member
Four Rings
Senior Member
Four Rings
Senior Member
Four Rings
So I think that $1200 minus 2 zeros sounds good
Griffin: Free style walker...everywhere
If that series of events ever happens again, and you guys can quote me on this, someone can come to my house and slap me one (1) time in the face. - Gram
Senior Member
Four Rings
Sounds great. Just add $1k and I'll deliver them, otherwise you can pick them up for an additional $1k.
Four Rings
Where'd you get the BBS hardware?
Senior Member
Four Rings
It was all on the wheels when I purchased them. I've only had them for about 3 months now.
I know Blackforest Industries and VRWheels sell BBS hardware.
Senior Member
Four Rings
someday my car should have 19x8.5/9.5 LMs.....
just not anywhere in my near future now
Senior Member
Four Rings
If only they were 18s And $900 :)
Double DIN swap, pioneer avh4000, TONS of suede, 15% tint, Forge 007, apr/vdo, rs4 grille, GIAC chip, Depo ecodes with 55w 5000k HID's, ST Coilovers, 034 street density motor and trans mounts, 034 snub w/ bracket, 034 aluminum subframe bushings, valeo single mass cluth/flywheel setup, new control arms and axles, evo ms CAI, powderoated snazzy stuff, euro trunk, multi colors, Shaved exhaust cuttout with hidden turn down tips (in progress... again)
its only just begun...
Senior Member
Four Rings
Senior Member
Four Rings
 Originally Posted by Turbwhistle
What reps are they?
BB5 - that's the brand. They were around until BBS sued them for having blatant copies of the LM.
Senior Member
Four Rings
You should have stated that in the op. Very rare set of wheels, plus they are next to identical to real lm's. GLWS!
Senior Member
Four Rings
I'll probably fine tune once I have the tires in hand so the sale can be an actual sale.
Thanks for the suggestion!
Active Member
Three Rings
These are absolutely beautiful. Pshhh you always have the nicest wheels mister. GLWS. I'd definitely scoop em up.
BOOBS& BOOST
['02 A4 1.8T B6 - CVT +Multitronic | Polar White | 50k]
|ST coilovers |REV O Stage 1| Carbonio CAI | USP Front | HID Headlights | Joey Mod | Pink HID fogs| Tinted Tails | Pink Rings |
Face.
Instagram: @boobsandboost
WTB: B6 A4 FWD 5-spd transmission for swap. PM me!
Senior Member
Four Rings
Start saving your pennies! They'll look perfect on you. Errr...your white car.
Senior Member
Four Rings
shutup TJ, no one wants your fake wheel real hardware bent non proper looking BB5's.
2001 Allroad 2.7T 6spd - Stage 3
SMIC | Jfonz'd | k04's | Bosch 710N (x2) | SSAC 3" DP | Podi Gauge | Skid Plate | ST Coilovers | RS4 Clutch | OEM RS4 Inlets | Custom Paint Matched Lowers
Senior Member
Four Rings
No one wants your turbo because turbos are dumb.
Senior Member
Four Rings
Tj let's pull em apart and re paint them. I'll grab the paint gun from my dad.
Active Member
Three Rings
If I'm not mistaken they are 1 piece wheels
2002 Silver S4 Avant 6spd
Senior Member
Four Rings
Phil is right. Even if he's a dirty bitch.
Senior Member
Four Rings
Haha well let's take the tires off, tape lips and spray :p still gotta take them apart to spray ;) aka pull bolts
Senior Member
Four Rings
he mean's that literally. I mean they don't even screw in hahahaha
Senior Member
Four Rings
i would assume they do screw in considering they are real bbs hardware...
Senior Member
Four Rings
they don't tj and I have discussed this lol
Senior Member
Four Rings
They how were they replaced with BBS hardware? I had always assumed they didn't in the past, until I saw this
Senior Member
Four Rings
they're just sealed in using RTV etc pretty much. I'll wait for TJ to post himself while he tells everyone to shut up. TJ lunch?
Active Member
Three Rings
Of course I'm right you dirty bitch.
Senior Member
Four Rings
I think almost all reps don't screw in the bolts. It would cost too much to make the bolts removable. I know the Miro/Raderwerks reps were plastic caps that needed to be drilled out. I think the new ESM reps my actually screw out, but the problem is all BBS bolts are long as they are designed to feed through and mount to the back with a nut on the other end as it's an actual fastener. Reps don't need to do this, so almost any bolt is going to have to be modified to fit.
Senior Member
Four Rings
these would look great on my car!! :D
Senior Member
Four Rings
Stop toying with your motor and buy some wheels!
Senior Member
Four Rings
hahaha yeah right... long list of things before wheels. the only thing that comes after wheels is something i'll probably never even get to; swap my headliner for the s4's black headliner lol
Senior Member
Four Rings
I has black headliner
Senior Member
Four Rings
Senior Member
Four Rings
Yes, because avants are better
Senior Member
Four Rings
Active Member
Three Rings
You would!  hahaha. I will start saving my pennies, sir. And if I happen to come up with 140,000 pennies at some point before someone steals these, I will contact you and buy these :) haha. GLWS.
BOOBS& BOOST
Face.
Senior Member
Four Rings
Don't blame me for liking blondes. Or females in general for that matter.
I wonder how much space 140,000 pennies would take up. Like how big would the box be and how much would it weigh? That's a lot of pennies.
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
