Results 1 to 23 of 23
    Jul 18 2011
    Norway
    Rear caliper piston not retracting
    b6 s4 caliper, i pulled it out fine, but when trying to retract this bitch , the threaded cylinder inside the piston just spins.
    this is obviously so the piston dont spin under braking and warp the pads.
    is there a ghetto way to get this piston back into the caliper? apply force while turning the piston?
    pics 4 fun
    Veteran Member Four Rings b4a41point8t's Avatar
    Jun 06 2009
    Los Angeles, CA
    Items for Sale
    maybe dumb, or i dont understand, but are you using the correct tool? There are notches in the piston that must be spinned while retracting the piston. this only applies to the rear pistons. Are you trying to just spin it and attach by hand?
    Established Member Two Rings black2.7t's Avatar
    Mar 07 2012
    2003 Audi A4 1.8T - traded 2005 Cobalt SS - DD
    knoxville
    just changed my rear pads the other day, you have to turn that piston clockwise to get it to go in. I used a c-clamp and channel locks to turn piston because i didnt have the proper tool lol
    03 A4 1.8T, silver/black, 5speed, Stage 1+ APR, gutted cat, APR Injectors, 6puck ACT unsprung clutch disc, light weight clutch masters flywheel, 034 street density tranny mount.
    Jul 18 2011
    Norway
    Quote Originally Posted by black2.7t View Post
    I did turn the piston while retracting, it enters maybe one or two threads, then starts to spin.
    Mar 07 2012
    knoxville
    You may have to disconnect brake line so that there isn't any pressure.. but you'll have to bleed your brakes if you do that
    Jul 18 2011
    Norway
    the calipers are fully taken apart as you van see in the pictures.
    Veteran Member Four Rings Kwarner's Avatar
    Sep 06 2009
    Bay Area
    Items for Sale
    You need to apply a lot of pressure for it to go back in. If you haven't used the proper tool yet, it would probably do it.
    Jun 06 2009
    Los Angeles, CA
    Items for Sale
    Quote Originally Posted by J_L View Post
    U need the tool. Hand isn't strong enough.
    Jul 18 2011
    Norway
    thanx for the help. no, i dont have the tool you mentioned, going to try again tomorrow, drink a big protein shake and apply some brute force
    Oct 30 2006
    05 Mini Cooper S
    Well now that you took the piston out, you need a new inner seal and dust boot for the piston.
    Also need the screw type caliper compression tool, and also a lot of brake fluid, that piston will not go in easily unless you literally bathe it in brake fluid.
    Would be wise to look up how to rebuild single piston rear calipers, you can't just put the piston back in as it, it will leak.
    -MilitantGrunt- Certified Audi Dealership Technician
    -F30 Estroil Blau 335 Xdrive M Sport 6spd.
    -Brilliant Red B6 A4 Ultrasport 1.8t Avant 621whp - RIP
    -Silver B6 A4 Ultrasport Sedan - SOLD
    https://www.facebook.com/auditech/
    Jul 18 2011
    Norway
    Quote Originally Posted by Militant-Grunt View Post
    the front and rear calipers are going to get painted and have new seals, thats why it is apart at the moment- I have done this before, just not the rear one`s with the piston out of the caliper. I dont have a compression tool at the moment, but I can fab one up at work in the morning.
    thanx for the help though:)
    Established Member Two Rings shoemaker617's Avatar
    Nov 15 2011
    Boston,MA
    lol wow
    Jul 18 2011
    Norway
    update: finished my front setup today, the rears just need some re-asembly after the paint.
    B6 s4 calipers with new seals, silver heat coating, Stoptec Possi-Quiet pads, Adams rotors drilled front/rear 340/300mm
    SS lines and Tyrolsport solid bushing kit:)
    Apr 07 2011
    Looks good! Let's see them on the car!
    Jun 27 2011
    Items for Sale
    Dude, that looks incredible. Its basically EXACTLY what I am planning on doing to my brakes. Any chance you could give me some tips, or a rough step by step, or at least the products you used to clean and prep the calipers for paint? I'm a bit of a noob when it comes to brake reconditioning.
    They really do look fantastic.
    -CP
    2008 Brilliant Black Unicorn (2.0t S-Line Ti 6MT Avant) - Bosch FR6KPP332S plugs - Q5 Rear Aero Wiper
    2012 Q5 2.0t - Stock Mommy Missile
    Former USP CLUB MEMBER #136
    Veteran Member Three Rings dewey527's Avatar
    Mar 10 2008
    '02 a4 1.8tq, '05 tahoe
    Puyallup
    Great choice in caliper color. I did mine this past wknd in silver and waiting for the rotors to come in by friday (fingers crossed) Charles I spent 2 hours dremeling a caliper and then I should have proceeded directly to the ER due to not have a mask on and breathing all that friggin brake dust...F that, so I got a sandblasting kit and an hour later everything was done! No leaking seals so I didn't rebuild them. Three coats of duplicolor caliper paint and ready to go. Tyrol stiffening kit coming in and the power bleeder ready to go
    mods - not enough for me and way too many in my wife's opinion
    K04, Revo "Stg2", PODI Boost Gauge, TT225, fmic, Forge DV, Tantrumwerks 300cell HFC, Neuspeed Exhaust, Stasis Touring Suspension, Spec Stg2 & LWFW, 034 RSB, Neuspeed SS, Neuspeed Snub, Neuspeed TIP, B6S4 front brakes, Tyrolsport Kit, 6K HID, Yellow Fogs, 20%, CC
    Veteran Member Four Rings BARRY's Avatar
    Nov 02 2007
    AE86 20v, UZZ30 LS2, 2002 A4 B6 1.8t, E63 AMG
    San Diego, Ca
    Items for Sale
    i haven't looked at my bentley manual, but for my corolla if you disassembled the rear caliper you need a special service tool which compresses and locks down the internal nut below the piston.
    have you looked at a bentley manual yet?
    Veteran Member Four Rings waldo1324's Avatar
    Apr 06 2009
    the Ghost of the Princess, 2007 Ford Fusion, 2006 Honda Accord
    The StL
    silver is sexy-- currently painting my spare front calipers red for the Zim drilled/ HPS/ SS lines swap. torn on whether to stop and go silver
    ""GHETTO MODIFIERS"" member #1
    The Princess: SOLD.. i love you, please forgive me
    "I agree with Waldo 100%" -1997GTX
    ..psst if you have a 2003+ 225 TT, email me..wally.iverson(at)gmail.com
    Jun 27 2011
    Items for Sale
    Quote Originally Posted by waldo1324 View Post
    Zebra stripe, red and silver. Or maybe one in red and one in silver.
    -CP
    Apr 06 2009
    The StL
    holy shit charles , you just gave me the best idea-- silver carrier and red caliper! or vice versa
    Jul 18 2011
    Norway
    here we go :)
    poss lookin oem brakes
    stock vs S4 (notice how the pads are the same size)
    installed
    I started at the rear, but the carrier bolts on the rear did not come out no matter what. I tried to heat it up with flames, and still no luck.
    so I started the fronts, and got`em done. Did a brake fluid change on the brake+ clutch system. next up was the brakes bed-in procedure:)
    Jun 06 2009
    Los Angeles, CA
    Items for Sale
    Damn that looks great! Props!
    Veteran Member Three Rings 9744RR's Avatar
    Sep 01 2005
    Great work for the OP and congrats on your new stopping power!
    This post may be too late for the OP but for the other newb's on AZ especially in North America who want to do the rears by themselves, buy one of these (click below) or something similar, it will make your life easier.
    http://www.rapidparts.com/prod/RP932...-Calipers/2664
    I have this same tool and paid $15 w/shipping years ago. The price now is ~$50. Happy
    His '64 Porshe 356, '15 A8 - Stock
    Hers '16 A6 3.0T
    Ours 2003 A4 1.8TQ TIP - GTRS Eliminator, STG 3 REVO, Delphi 440's, ASP FMIC, Extreme TIP, TP, TT-DP, S4 door blades.
