Results 1 to 8 of 8
    Nov 11 2010
    wappingers Falls NY
    Spindle bolt seized and broke...
    Took my car in to Independent shop for a front wheel bearing and installation of my new front shocks..Wheel Bearing was
    covered under my extended warrenty. So Out of pocket for installation of shocks, wheel bearing and wheel alignment.. $581.. Not bad.. While removing the spindle pinch bolt, it snaps.. (both driver and passenger side) On top of the price before he tacks on another $975. for new used spindles and front and rear upper control arms...Does this sound correct?? Think im getting screwed.I told him that the bolt snaps often and with heat and airtool your able to get bolt out.. He claims not possible. I told him not to touch anything yet..How should i presue this? He already sourced used spindles at $135. each and claims he can not return..
    Sep 16 2010
    S6 Avant X TWO! and 67' Speed buggy
    Central Wash
    Items for Sale
    You're getting screwed. If they can't remove the pinch bolt THEY SHOULDN'T BE WORKING ON YOUR CAR. The fact that 99% of us can do it in our driveways with no special tools means they're doing something wrong.
    Senior Member Two Rings mk2rimar's Avatar
    Aug 29 2011
    montreal quebec canada
    Ad that same probleme last week.i work in a vw dealer and one side bolt was jamed the tech heated the knokle not the bolt...the knokle abd with a zip gun took out the bolt.i know that the knokle is made of aluminium and every body says its not good to heat them up but if you becarful and dont heat till it melts lol your find....good luck...and if they cant do it bring your ride to a true vw/audi antusiast tech or mechanic
    Sent from my LG-P999 using Tapatalk 2
    Veteran Member Four Rings lookaught's Avatar
    Apr 20 2007
    Aprilia SXV 550, BMW F800GS, Honda CRF450X Timbersled, Ram EcoDiesel, 1989 Bronco
    Lander, Wyoming
    I've drilled out the pinch bolts before without removing the spindle, it took about an hour and a few ruined drill bits to drill through 3 inches of steel. Buying new spindles is not necessary. If it came down to it you can remove the lower control arms with a ball joint separator (which he should own) and the shock tower and put the thing in a drill press which makes drilling out the bolts MUCH easier. If he bought new spindles he has to remove the old ones anyway.
    IMO take it to a new shop. If they are seized in place you can drive it a few miles without worrying about it falling out because it wont. He should have known better and heated up the bolt first because its very prone to galvanic corrosion if you have aluminum spindles. Also if you are buying new upper control arms you can heat the hell out of the pinch bolt and not worry about melting the ball joint boots, so this means you don't have to take out the spindles at all. If the bolt sheared you can still put the nut on the other end and heat it, then tighten the nut and it will break it free. Heat is your friend.
    Jon
    go > show
    Ich liebe mein Audi
    2002 GTRS Avant - Built with love, sweat, bloody knuckles, and pride.
    Apr 12 2009
    Quote Originally Posted by lookaught View Post
    Just to clarify, you want to apply heat to the knuckle and not the bolt, aluminum will take less heat and expand more then the bolt, if you heat the bolt it will expand casuing it to sieze even more. Mk2rimar is right even though he cant spell, lol.
    Jun 30 2008
    Erie, Pennsylvania
    Quote Originally Posted by shoppingcart111 View Post
    lol. This.
    2001 Laser Red A4 1.8TQM, 5-Speed Swapped, 4.11 Final Drive, APR 93, R8 coil packs, Labree HFC & DP, 2.5" Exhaust, ST Coilovers, 034 RSB, A8 Brakes Front & Rear, 18" RS4 Reps
    "You need to know what you are doing...Its like a rainbow jungle in there." - Redline380
    Dec 05 2007
    Items for Sale
    PM sent
    Aug 29 2011
    sory i'm french canadian so i do my best....DONT heat the bolt or you will be in deep sh*&.....first time wee heated the bolt first it got stock in a way that it dosent move anymore...
