Four Rings
help removing intake manifold. (doing carbon cleaning)
so, this has all been pretty straight forward until i ran into this issue about 30 minutes ago. i have eveything disconnected except the 3 connectors way down low. they are impossible to get to with the manifold in place(i think one might be broken too) so i was going to remove the manifold, then take them off. however, my manifold does not want to unseat. im assuming this is probably the injectors being stuck not actually the manifold...but any tips you guys can give me? just pull really hard? all my fuel lines are disconnected, support bracket removed, bolts/nuts removed. i can shake the manifold back and forth a bit because its loose...just cant pull it off. thanks!
Active Member
Four Rings
They do tend to stick a bit from time to time. I typically get one end loose and then the other.
Gonna push this little K03 until it can take no more
Senior Member
Four Rings
Don't forget before and after pics! I can't wait to dive into this project, but my week long brake job has me a little tired of working on my car (and my wife won't let me for a while)>
05.5 A4 2.0T 6spd, REVO Stage 2, Vast Stage 3 clutch, VMR test pipe, custom non-res 2.5" Techtonics exhaust, Borla mufflers, wastegate adjustment, Treadstone TR6 FMIC, custom cold air intake, 034 catch can, BKR7E, 145 bar prv, DW300 LPFP, shiny manually cleaned valves, JHM Short Shifter, KW V1's, 19" V710's, drilled/slotted rotors, Akebono pads, Podi boost gauge, 640 Mod, 18% tint, baby seat.
Dyno proven 221 whp/302 wtq on 91 oct!
Active Member
Three Rings
x2....
Have to balance the work on the honeydo list, her van, etc.. with time spent on the A4. Sometimes just want to have a break. Been staring at the box of uber pads and menz stuff, plus knowing the carbon needs to be done but needing a break. Then I freakin rear ended someone, so now I need to waste the funds on my deductible.
2007 2.0T Q 6MT, S-Line, Ti Package, Brilliant Black (104K - Feb 2012)
Revo Stage 2 | K&N Drop in | APR HPFP | 034 HFC | AWE Catback | OEM DV Upgrade | 034 SD Motor Mounts | Neuspeed Snub | H&R Sport Springs | B5 Perches | RS4 RSB | H&R Spacers 15f/20r | Clear Corners w/Blackout | Clear Frt Markers (UV Clear Coat - Krylon 2-12-12) | Cupra R Lip | 20% Tint
Four Rings
Well I got it off... However this clip broke on one of the injectors. How important is it and can I get away with using it how it is?
Three Rings
I would say it is important. If i had to do it again i would buy new clips, orings, gasket too. Make sure your injectors are out of the manifold and seated in the slot correctly before putting the manifold back on. When i went to put mine back together it started leakin fuel.
Four Rings
FYI I did reuse the clip with one "leg" broken off. It looked to just be a retainer for a spacer the keeps the manifold from seating too far down onto the injector. Took the car for a short drive(up to operating temp) and no issues.
Senior Member
Three Rings
Becareful reusing the injector orings, I reused mine and leaked a whole bunch of fuel. I didnt notice til 5 min into 5 drive when I smelled gas and lost a 1/4 tank lol
Senior Member
Four Rings
Add before after pics to DIY thread please thank you :-)
Four Rings
Didn't take pics. Just wanted it to be done. My back was KILLING me after leaning over the car so long.
Senior Member
Four Rings
 Originally Posted by doublezero30
Didn't take pics.
Active Member
Two Rings
I hear you on that one.
My car the injectors came our with the intake manifold which was a pain in the ass to deal with the mass of wires and everything else that was coming along with it.
2005.5 A4 Avant Auto - Stock
2007 A4 S-Line TI Brilliant Black - Revo Stage 2+ | Carbonio | Billy Boat Exhaust | Eurocode TP | APR HPFP | JHM Short Shifter | CX Racing FMI | Forge DV | RS4 Rear Sway | 8000k HID fogs | Bagged
.:StageAwesome:.
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
