Page 134 of 134 FirstFirst ... 3484124132133134
Results 5,321 to 5,326 of 5326
  1. #5321
    Jun 19 2017
    ABQ NM
    Quote Originally Posted by sswari View Post
    Started installing the new to her Transmission
    Quote Originally Posted by cal3thousand View Post
    Nice!!
    Good luck! Let us know how it goes
    So, this has been a fairly long process, just over 3 weeks. Swapping a transmission on your back is one thing, doing it in your yard, on the grass (I did have plywood between me and the grass/dirt), is an entirely different animal. There have been several days along the way, where I have not been able to work on it at all.
    Last Thursday, I was able to get everything forward of the flex pipes tightened down and torqued to spec. I also got the main drive shaft CV joint cleaned and reassembled (yes, on my back, under the car). Today the rear wheels come off the ramps so I can get the CV bolts torqued down. then it is just the exhaust and Fill it up if I have enough Lifeguard 8
    It's My Realtor Car
  2. #5322
    Veteran Member Four Rings JPJ2007's Avatar
    Apr 15 2009
    Middle TN
    phew I know thats a lot of work.
    2006 A6 3.2L Quattro S-Line (got my baby back)
  3. #5323
    Established Member Two Rings luketc1's Avatar
    Nov 13 2016
    Los Angeles, CA
    Quick debadge job:
    Coffee cup of hot-ish water to loosen, old plastic CVS card to pry, goo gone to clean, carnuba wax to polish
    2011 A6 3.0T
    Roc-Euro intake, 19" OEM Peelers, Eibach Pro-Kit 1.2"
    35% tint, beige interior, C7 shifter
  4. #5324
    Apr 15 2009
    Middle TN
    Nice, for others who want a tip floss works great to cut through the glue behind the badges
  5. #5325
    Senior Member Two Rings se.farrell's Avatar
    Jan 09 2014
    Los Angeles, CA
    Quote Originally Posted by JPJ2007 View Post
    This is what I did.
    Heat Gun + Dental Floss/Fishing Line. Then Goo Gone (NOT Goof Off!) to remove any remaining residue, glue, etc.
    Wax to polish after.
    Current:
    2008 Audi A6 3.2L S-Line
    Black RS6 Grille, 6000k High/Low
    Magnaflow Tru-X
    ST Coilovers
    AR Street Rotors - Black Zinc
    Akembono Ceramic Pads
    VMR V708 19x8.5 et38 - Hyper Silver
    Matte Black Trim
    Carbon Fiber Wrapped Interior Trim
  6. #5326
    Oct 31 2013
    Washington DC / NoVa
    What did you do to your C6 today?
    Reinstalled alu-optic stone guards after installing upside-down. Stone guards are OEM from a 2010 S5 ordered off amazon. A steal of a deal.
