Results 1 to 13 of 13
Thread: Hatch problems
    Active Member Two Rings fusion28's Avatar
    Apr 10 2012
    Fort Collins/CO
    Hatch problems
    Hey guys,
    I did a little search and I found nothing..
    My rear hatch will not open on warm days and will only open on some cold. I can use both the keyless or the actual handle on door. I can hear the machine working, but it won't release to open. Anyone know what could be wrong or have experienced this before?
    Senior Member Four Rings BCsniper's Avatar
    Jan 29 2010
    north ga
    I also have problems with my hatch latch. Right after having driven it I can open it, but if I close it then try to re-open it is a no-go. Same as you I can hear the mechanism moving but the latch wont release. My plan is just to replace the latch mechanism and hope for the best.
    Senior Member Three Rings SleeperLoDo's Avatar
    Aug 12 2008
    04 A4 Avant 3.0 / 08 Civic EX R18
    Denver Lodo, Colorado
    "not open on warm days and will only open on some cold"
    same as mine B6
    I just start the car and put unlock the doors, work sometimes and sometimes still can't open.
    " 3.sLOW n' Chill "
    Veteran Member Three Rings Kem's Avatar
    Aug 30 2004
    10 S4 6MT
    Oakland, CA
    This has happened to me a couple of times. What's the fix?
    '10 S4 6MT Prestige :: Phantom :: Black/Magma Carbon Atlas :: Sport Diff :: APR Stg II+ :: AWE Exhaust :: Roc-Euro Intake :: VMR v713 19x9.5 :: H&R OE Sport :: AluKreuz :: JHM Short Shifter :: RS4 Grill
    Senior Member Four Rings Greedo's Avatar
    Oct 26 2009
    I have no answer, but that's very strange. Perhaps the mechanism is being a girl and doesn't like the cold? Maybe you should rub your warm feet on it?
    Apr 10 2012
    Fort Collins/CO
    I will take a look at it on my weekend. It's pretty frusturating. Hopefully it's just something sticking that will be a cheap fix. I'll let you guys know if I can find the "cure".
    Jan 11 2012
    TN
    I had the same problem, I replaced the actuator that pulls the latch. Now it works great. You can open your hatch from the inside through the hazard triangle door, just pull the red chord. The actuator is located inside the hatch door panel.
    Senior Member Two Rings yourtoys7's Avatar
    Jan 29 2009
    Buffalo,USA/ London, Canada
    Just happened to me on fri/ sat. camping, very hot day and couldn't open the back... after I ran the car 5min. or so, it opened, temp. isue for for sure,
    waiting for a fix or something...
    A4 2004 3.0L 6spd. Avant
    A4 2004 3.0L 6spd. USP Sedan/ sold.
    A4 1999.5 1.8T 5spd./ sold.
    Aug 12 2008
    will work on my hatch this evening.....
    http://www.audizine.com/forum/showth...ighlight=panel
    " 3.sLOW n' Chill "
    Aug 12 2008
    I just put foam packaging in the back of Actuator
    " 3.sLOW n' Chill "
    Active Member Three Rings ebi718's Avatar
    Oct 29 2011
    C7 A6
    Brooklyn, New York
    Mine started having this issue yesterday. When I eventually got it open, I noticed the tailgate lock mechanism was stuck, not moving freely. After nudging it a bit, I closed the hatch; it has refused to open since then :banghead:. Question: is there a manual release lever (to pull) after removing the top/bottom trims? My hazard triangle door doesn't have a red cord.
    Sent from my Transformer using Tapatalk 2
    '13 Audi A6 2.0T Quattro Tiptronic
    '07 Audi A6 3.2 Avant Quattro S Line
    '04 Audi A6 3.0L Avant Quattro (sold)
    Links: VCDS Tweaks, more,Audi PR Codes Decoder
    Jan 29 2010
    north ga
    ...yeah I learned not to mess with the latch part. When I did I wasn't able to get it open for quite awhile.
    Sometimes locking and unlocking the door helps it to let the hatch open. Other times going and driving the car for a short bit will do the trick. It is frustrating as hell sometimes though
    Oct 29 2011
    C7 A6
    Brooklyn, New York
    If only I can successfully remove the trim. I followed that DIY, took out the screws at the hazard door and the grip ...the trim wont even budge when pulled at the edges , and I dont want to risk breaking it. Will take it for a spin and hope it opens...I have a can of WD40 for the latch.
    Sent from my PG86100 using Tapatalk 2
