wow, are you staged? mine had about 170k and were perfectly dry and looked new.. Of course it helps that they always ran under stock boost.
~Sergio~ Coalition of The OEM+ Audi Owner's Member #9. http://www.audizine.com/forum/showth...IY-Master-List http://www.allroadfaq.com/reference/engine.shtml
'01 AR= |034 TBB|034 Y pipe hoses|Custom Tune stg 1|Clarion NX501 ICE|oem roof bars|Yakima Skybox 18|VDO vent Boost Gauge|KnN Drop-in|Yellow Fogs|oem Double spoke wheels(2 sets) summer & winter|20%tint|034 SAI Block off plate kit, Now with less Combi valves
Into the cat or bouncing down the road most likely lol. What I'm curious about is how they got like that in the first place. Doesn't look like there was much, if any contact with the turbine housing.. almost looks like particulate in the exhaust stream or maybe just from being heat cycled so many times?
Is there ever any worry that the compressor will get chewed up like that and you could end up with your motor inhaling metal? Or is it just usually the turbine side that gets messed up like the pic above?
034 Motorsports STK (build thread IT'S ALIVE ) ~ INA Engineering ~ BritishTuning
~Pain is necessary, suffering is optional.
Vanes do not just go missing, you are inhaling some kind of particulate between you compressor housing and turbine housing. Look over your bottom charge tubes, intercoolers, intake mani, exhaust mani. Have you looked at your valves?
brilliant black 2001.5 s4 built bottom end stage 3+ on e85
This kind of damage cannot occur from the fins grinding against the housing? I'm not turbo expert, this is why I'm asking.
Anything can happen with the rotating assembly spinning at 150,000 rpm, but the damage above with the deep grooves of missing metal heavily towards foreign object damage (FOD).
You ever lost the electrode on a spark plug or maybe a chunk of carbon broke loose and got the ball rolling on them?
Cold side gets filtered by the ic most of the time.
Whats the compressor side look like? If there's a lot of play the turbine could hit the walls of the turbine housing and cause it to fracture like that. If you look at the fins they have a slight "curl" to them which would indicate they were hitting on something or something was stuck in the exhaust port and hanging down interfering with the turbine wheel.
