Results 1 to 24 of 24
Thread: Vmaxx coils
    Senior Member Three Rings gdub4.2's Avatar
    Jan 31 2011
    San antonio, TX
    Vmaxx coils
    Any experience . With vmaxx coils? Opinions? Im never gonna track the car, should I just lower with springs and use cash for other things? Discuss amongst yourselves ........
    Sent from my MB855 using Tapatalk 2
    Senior Member Four Rings dparm's Avatar
    Apr 24 2009
    Chicago, IL
    $699 for coilovers is pretty dang cheap, if you catch my drift.
    2011 S4 saloon S tronic
    + Stasis go-fast goodies
    Active Member Three Rings jeffrey146's Avatar
    Feb 19 2012
    04 s4 noggy avant MT 98 A4 2.8LQM 30V 207K 98 A6 2.8LQA 30V 118K
    Ogden, ut
    I would go with raceland first.
    Noggy S4 Avant MT B6
    Miro 111s, DRS extreme contact, AudiUp 10mm front 15mm rear spacers, 034 rear sway (soft setting till I get new end links), APR DPS exhaust and tune, H&R springs, Morimoto mini H1 Bixenon retrofit (4300k), clear corner mod & APR tune.
    Veteran Member Four Rings drew's Avatar
    Jul 27 2004
    Gone: 996TT stage 3, E46 M3
    so cal
    I wouldn't do it. Bare minimum would be the H&R/Koni combo.
    05 S4 6MT Light Silver/Black-Silver Alcantara
    13 VW Tiguan SEL 4MOTION
    Senior Member Four Rings yungcotter's Avatar
    Jun 09 2010
    Queens/Upstate New York
    for that price I would go with ST's instead there like 60 more and ar basically kw V1's but made of a different material Or Vogtland there around 100 more.
    06 A4 2.0T, Quartz Gray, Quattro Tiptronic.
    -Theo
    APR Stage 2, AWE Exhaust, 034 Rear Sway, Carbonio Intake, 034 HFC, GSG Front Mount intercooler, Tyrolsport rigid caliper sliders, ST Coilovers, S-Line Trunk, Podi Boost gauge, Hard wired Passport 9500ix, HID Projector Retrofit
    Senior Member Four Rings fatbrembos's Avatar
    Sep 30 2009
    b7 s4 avant/49cc scooter
    at home
    Quote Originally Posted by yungcotter View Post
    THIS
    at the end of the day you get what you pay for. ST's are a great way of spending your money right. I personally love my bc racing coils. Cheap but hey got to pick my own spring rates/spring sizes/shock sizes and you can even get them re- valved for free if your spring rates are aggressive. I have the only set for a b6/7 s4 that i know of but im very happy with the over all quality over the product and would have gladly paid double what i paid for them again anyday of the week. When it comes down to suspension Id rather spend a little more and be happy then spend a little less and be unhappy about my set up.
    just my 2 cents
    Bags = Cheating
    FS: CCW Classics 18x10.5/11.5 - SOLD
    FS: CCW LM20's 18x9.5/10.5 - SOLD
    Senior Member Two Rings Jordan80's Avatar
    Feb 22 2010
    Saratoga, NY
    Also agree with this, but only because of the price of the V-maxx. If you want to try out a cheaper coil, do something less expensive so if you have problems you're not down as much cash.
    It is definitely true that with most of the parts for these cars you get what you pay for, but at the same time there is some parts that may not be as nice as others, but will do the trick. With that being said, I think it's crazy to go out and blow 2g+ on a set of KW V3's, PSS9's, ect for a car that is a DD or never tracked/raced/show car. I've had Vogtlands for a couple years and for $800 shipped they hold up just as well as coils that are 2-3x as expensive. Maybe not as comfortable, but still work great. Just personal experience.
    If you have the money it's definitely nice to have a higher quality setup. But if you're ballin' on a budget like me, ST's and Vogtlands are the way to go.
    00 Nogaro S4 | Stage 3 K04's
    01 Santorin A4 1.8TQ | K04 Unitronics Stage 2+ --- Gone
    04 GSX-R 1000
    MK2 Jetta Turbo Diesel
    AutoHausMotors
    Veteran Member Four Rings trueno429's Avatar
    Aug 02 2007
    B6 1.8TQ 71R 6SPD
    BK,NYC
    op i have brand new kwv2 coilovers if you are interested. pm me
    Mar 26 2007
    Colorado
    I F****** hate these threads!!!!
    You drive a Luxury sports car, if you can not afford decent suspension, leave your freaking car alone......
    SRT8 Jeep / Custom exhaust w/ X pipe / Catch can / AFE intake / Diablo Intune/ 275's & 315's
    Senior Member Four Rings Hyde's Avatar
    Sep 05 2008
    Northwest Florida
    Vmaxx ... Don't do it. Not on this car.
    I don't plan on tracking my car, but I will be changing over to Bilstein PSS9s soon because I can't stand the squishiness of my FK HighSports anymore. They lowered the car, and got the job done for appearances, but I still can't take turns as fast as I expect I should in a car like this. I have close to 20k miles on the FKs, so at least I got some use out of them. From what I hear, the Vmaxx coils are just as soft, if not softer than the FKs. For as low as I want/need to go, I need my suspension to be firmer, not softer.
    Senior Member Three Rings EUROSWAGR's Avatar
    Oct 11 2008
    2013 Ford F-150 FX4 (twins) / 2012 Audi Q5 S-line
    Jacksonville, NC
    Vmaxx coilovers sucked on my MKIV GLI, don't try these on your S4. STs can be had for as low as $750 shipped and they are basically KW V1s so they are quality.
    2006 Audi S4 Brilliant Red 6-spd (neutered)
    Active Member Two Rings nicotino15's Avatar
    Jul 24 2011
    dallas
    so cheap, that is a downgrade from the stock suspension. Have you ever looked at the stock setup? They are actually nice components, anything less that H&R coils is a downgrade imo. You're handling will be less responsive, and you're ride will be less comfortable. I opted for Stasis Ohlins SL and they are incredible, but very expensive. They are firm, yet luxurious feeling due to the digressive valving, and the spring rates make the handling feel much better than stock.
    If all you care about is looks, get the H&R springs and koni shock setup, or spring for the H&R coils.
    Senior Member Two Rings rxbike's Avatar
    Apr 01 2009
    04 b6 s4, 07 toy tundra dc
    CA
    Quote Originally Posted by trueno429 View Post
    Didn't know that KW were available for the B6S4 in anything but the V3 versions. Are these something new ?
    2004 B6 S4 black on black. VMR RS4 reps wheels, APR down pipe and exhaust, JHM tune,JHM intake manifold and throttle body, JHM lightweight pulley, Snub Mount; Eclipse AVN 726E nav/dvd unit. AR slot/slot/dimple rotors
    2003 Porsche 996 TT EPL stage 1 tune, AR Design 3" xflo street exhaust, Clutch Master 3600lbs clamp force/LWFW
    2000 Porsche Carrera C2 Schnell Header/Exhaust , Schnell Cold Air, 19" SSR GT-3
    2007 Toyota Tundra 5.7L doublecab TRD intake
    2003 VW GTI 1.8T APR stage 1
    Active Member Two Rings BrandonS's Avatar
    Mar 26 2012
    B7 S4 / C5 A6 Avant / Suzuki GSX-R
    A buddy of mine recently purchased some ST coils for his mk5 jetta, they actually ride rather smooth and all the way down they actually sit at a very nice height. We shall see how they hold up long term, but so far so good. I must say tho, if you have the money dont cheap out, it may save you money in the long run. I have stasis coilovers and absolutely love them, they ride amazing and are fully adjustable.
    2006 Audi S4
    GIAC Tune - JHM Piggie Pipes - Stasis X-Pipe Cat-Back Exhaust - Stasis Ohlins SL Coilovers - K&N Drop-in - Apikol Snub Mount - Pioneer AVIC X-930 BT - 19" DPE GT-7 Forged - RS4 Grill - 6% Lamin-x'd Head lights/Tail lights - 034 Motorsports Intake Pipe
    Jan 31 2011
    San antonio, TX
    Quote Originally Posted by vdubjetta02 View Post
    no one said anything about affording prick, I'm asking for opinions from other AZ'rs who actually use the product, D-bag
    Mar 05 2012
    Mazda RX8 GT
    south florida
    i have them on my b7 (not by choice, the car came with them) and needless to say im setting money asside for future suspension upgrade. The ride is just to sloppy, i dont feel confident taking aggressive corners.
    Mar 03 2010
    cincinnati
    How about FK? Those can be had for under $1k. ??
    ...2006 S4 6MT #10 of 250
    || Fast Intentions Non-Res Cat-back || H&R Coils || Amazon "RS" Grille || 034 MAF Hose || 034 Rear Sway Bar || JHM Intake Spacers || JHM Intake Bypass ||
    Mar 26 2007
    Colorado
    Quote Originally Posted by gdub4.2 View Post
    Hey shit head......I have real life experience with Vmaxx.. Maybe if you would have searched you would have seen my other threads. If you are looking at "cheap coils" you have to worry about affording.
    My old VW with VMAXX at
    From 0:45 - 0:53
    http://www.youtube.com/watch?v=dxfFotk13EM
    Senior Member Three Rings howsyouraspen's Avatar
    Dec 06 2007
    Holladay, UT
    I love my Vogtlands so far. Been on a year and have zero complaints. I've yet to try em at the track, but I'm sure they'd do just fine. And it rides far better dumped, than stock ever did.
    I wanna know who found Vogtlands for 800 bucks. Damn.
    OP, a few things I've read about the VMaxx's on S4's is no bueno. I agree, if you can pony up another couple-few hundo, you'll def be better off. Not to mention, I think a few of these kits have even blown out on some of the dubs. Good luck on your choice.
    -Alex
    A6 Avant 3.0T
    *S4 SOLD*
    buy my Rials! http://www.audizine.com/classifieds/...aytonas&cat=48
    Senior Member Four Rings jlaudio's Avatar
    Mar 26 2009
    Canton, CT
    when i purchase coils in the next few weeks ill be going with Vogtland. peoples reviews of H&R are hit or miss, some love them, some say they are bouncy as hell. I don't track the car at all, so my coil purchase is more of a looks item.
    09 B8 A4 Prestige
    "We as a group now have a greater moral responsibility to act than those who live in ignorance, "Once you become knowledgeable you have an obligation to do something about it!" - Ron Paul
    Previous: 06 S4 6MT, 07 A4 6MT, 02 A4 QM, 99 A4 QM
    Jan 31 2011
    San antonio, TX
    From 0:45 - 0:53
    You should have lead with your opinion on the subject, dont like the thread dont read it dick
    Mar 26 2007
    Colorado
    I have been around this community a long time, this is my 2nd B6 S4 and 3rd Audi in 4 years..... Every month someone like you comes in, starts a thread and regardless of what everyone tells them or their lack of effort to SEARCH they look for a cheap way to modify their car.....
    Mod your car right the first time, it will actually save you money in the long run.
    Apr 01 2009
    CA
    Although I am a proponent of modding "right", our vehicles can now be had for a very low price, making them attractive to a newer crowd. That being said, you really can't blame anyone for asking questions out there regarding parts that are being sold specifically for our vehicles. It may be a small percentage responsibility on the OP for asking without searching, but the parts continue to be available, and maybe they have seen some improvement or sourced from a different mfg, I don't think it hurts to ask . Yes all of us would like PSS9 or KWV3, and every JHM bolt on available but financially this may not be the best route on an 8 year old platform when at the end of the day, its still an 8 year old car !
    Apr 24 2009
    Chicago, IL
    What's the spring rate? Does it match up with the stock shocks/struts? Those are the two questions you need to answer. Cheap springs could certainly work if the rate is correct. Otherwise you'll have a shitty ride and/or blow the struts.
