Senior Member
Four Rings
The best motor mounts EVER....
So tonight i figure it was time to change out the motor mounts in the car due to some serious in creases in vibration and some odd noises... Well glad i did because they were just awesome. Needless to say this mount made a better bowl than a mount. I decided to go wiht a set of 034 Street Density that i bought at JHMotorsports.
Enjoy
Four Rings
I can't believe how bad yours were.
-Jace-
RogueEuro
WTB: B7 Split Spoke Center Caps
Atlas FTW
Active Member
Four Rings
Wow. That's pretty freakin bad. :thumbdown:
edit: Stupid tapatalk. Why can't their smileys be the same as the forums'?
~Calvin
034Motorsport
RogueEuro 2004 Audi A4 1.8T /// 6-Speed /// quattro /// Moro Blue Pearl || uni stage 2 || symph ii+ || podi || ns sport w/ b5 seats || v718 sunken treasure
Four Rings
lol looks more like a donation can/bin, than a mount. Glad you went with 034's mounts..
Four Rings
-Nate
Please PM for items for sale:| Hofele Design 1 Piece Rear Trunk Spoiler/Lip | B6 A4 Brake Calipers | 4 OEMCoilPacks Rev. D | Arm Rest Cupholders - FREE | Washer Fluid Reservoir |
Active Member
Two Rings
Hey post up how the 034 mounts treat you. I was thinking about picking up a set.
B5 S4 brakes/ Hawk HPS pads, apikol snub
Four Rings
You can't go wrong with the Street Density 034 engine mounts. Have had these in my car for a long time (over 100k miles). Make sure they are installed properly as many have complained of excessive vibrations. The key to the install is to keep it loose and then run the engine to let it position itself into place properly. After than, you can then tighten everything up.
USP CLUB MEMBER #34
2004 A4 1.8T USP - GT2871R Eliminator - Unitronic program - ER Comp FMIC - Stoptech BBK & lines - AMS SS - CIM gauge - ECS RS4 clutch & LWFW - ECS LW pulley - RNS-E - RS4 pedals - RS4 e-brake - S4 Bi-Xenon ecodes - 19" OZ SLIII - Bilstein PSS9 - B6 S4 Recaros - more stuff...
Senior Member
Four Rings
OH GOD! That is insane. I have had the street density mounts in for around 20K and have been super happy with them. Good luck with the install!
Active Member
Three Rings
I believe the mounts settle a bit once they soften up. I had to re-align everything after about 1,000 mi using the process above. At first they seemed fairly stiff, then my vibrations got worse until I decided to try to loosen everything back up and try again. The snub was touching the bottom of the cage like the motor sunk a good 1/8" or so. After aligning everything again, my idle is smooth as silk.
I think these are a good buy, hope you enjoy them.
-Rich
"Because magic, and science, and learning books" -Dan[FN]6262
WTB: B6 sport steering wheel (grey) and clockspring.
Senior Member
Four Rings
Thanks for reminding me! I'm soon to drop them in with the 2.7T.
Audi Enthusiast  and MAG Audi Brand Specialist
Senior Member
Four Rings
I just replaced the snub, motor, and transmission mounts on my car with ones I got from JHM (034 motor/trans, Apikol snub) and there is now 0 vibration at idle. There wasn't almost none before, but now there is 0. Very impressed with the mounts and the shop that installed them for me. Old mounts had almost 150k on them, so they were definitely due for replacement.
Active Member
Four Rings
just curious, how many miles were on the car when you replaced them?
now that i see that im wondering how bad mine might be
'02 B6A4 1.8t 5sp Quattro Sport.
Stage1+ w/ TT225 injectors, vent pod boost gauge, Stratmosphere DV, interior LEDs , 6000k HIDs, Audiup race snub, hp2 calipers w/ StopTech SS Lines, 034 rear sway, DIY USP lower w/ Cupra, RAI Test Pipe.
want moar...
Four Rings
wow thats bad.
So getting the ready for a Cross Country Trip to WF??????
Neil_
Atlas Gray BT Avant... For Sale ..also ABT 3bar Grill NIB For Sale. avantneil@gmail.com
Instagram: avantneil
Stage 3 Forum Advertiser
Four Rings
vortexjunkie-
Good thing you decided to go with the 034 Motor Mounts! Yours were looking pretty beat up!
For those of you looking for the mounts that vortexjunkie bought, see below!
Click Me For Motor Mounts!
These are great Motor Mounts and they will definitely outlast your OEM mounts. We have tested these mounts on several B6-A4s with excellent results and a more rigid drivetrain! Results vortexjunkie can speak to!
For those of you who may also need Transmission Mounts, we offer 034 Motorsport's Transmission Mounts as well!
Click Me For Transmission Mounts!
If you have any questions about our products or would like help placing an order, feel free to give us a call!
Four Rings
This is EXACTLY the same route I went with as well and am VERY happy with the results!!!
Four Rings
i have the 034 track density engine and transmission mounts on both my tiptronic and 5spd. deff more vibration then stock even after adjusting a few times. for my wife it's a bit much but it doesn't bother me at all.
why? "because race car" of course....
03 Tiptronic A4 1.8TQ - REVO STAGE 3
03 5spd A4 1.8TQ - STOCK
-*- Click For Car Details -*-
- LOOKING FOR: Oettinger Side Skirts (not replicas) & Ring "Holder" For Mesh Grill.
Senior Member
Four Rings
I dont even need to tell you how much better my ride home from work was today with the new mounts.. It is seriously like an entirely different car. Love them.
My currently has 150K on it. i have no idea when they were replaced before the one looked almost new but i wanted to make sure i didnt have to do this again in a couple months so i replaced them both.
 Originally Posted by kneel
wow thats bad.
I am getting ready to head south to a show called Wuste... Im not sure but it sounds like its a big deal.
Senior Member
Four Rings
How do you like the street density mounts? I have the track one's and it vibrates like crazy from time to time especially in low rpm's. Maybe bc all my mounts are track density and poly.
Dynojet 198WHP / 248WTQ stock engine. stock K03. APR Tune. AWE Exhaust w. Testpipe. K&N Cone Filter. Forge DV. B5 A4 1.8T Trans. JOM coilovers. B5 S4 Wheels. Stud Kit. Painted Lowers. 4500k HID's. Track density engine mounts. APR Snub mount. Apikol Trans/Rear Diff mounts. Engine Refresh(cylinder hone/piston rings/Head re-done)
Active Member
Three Rings
I love my street density mounts, however I had to change out the trans mount as it got soggy after about a year. I would go with Apikol or Stern v2 for the tranny mount.
-Rich
Senior Member
Four Rings
What is involved with changing the tranny mounts? I am a tiptronic, so it will be a little different than most of you guys, but do you have to unbolt the motor mounts and then somehow lift up the engine and tranny together, or how do you get those suckers out of there. I am starting to get more vibration at idle than I used to have before, and it is only when it is in gear, so I think that points to a failed tranny mount rather than motor mounts or a snub.
Active Member
Three Rings
I'm not sure how the tiptronic is set up, but on the 5mt all I did was disconnect the snub from the oil pan and put a jack under the tranny. There's plenty of room to get the bracket and mount out separately if you lift the trans up about 1.5". Takes me 20min tops.
Here's the manual trans instructions, I'm not sure how your's is different. You may have more mounts. http://www.purems.com/products/STB7T...stallation.pdf
-Rich
Four Rings
Wow those mounts look like the car was in an accident or taken off road?
Not sure how the motor would twist the metal seat off the mount off like that.
'SOFTWALKER MODS
Do u have the Bentley or Dealership Manual & Tools it takes to work on YOUR car properly? Or...
Are u just going to continue to wing it & keep expecting manna to fall from AZ?
Apikol>Snub/Diff APR>ExhTIP-TB hoses,Stg3 AWE>DV
JHM>ShortShift-the works
Misc> 18x8x9 235/265;HSport S4 barsTT225;Bosch-F6DTC;CarbonioV2+V6Intake Inlet;HFC;Podi-P2;ATP mani;GPopK04;034mounts
SPEC>Stg3+,LWFW
STaSIS>328/305mm,40/60,SL
Personal Motto>Walk Softly Carry a Big Stick
Senior Member
Four Rings
Awesome, thanks a lot for the info. I will get under there and take a look at how mine are oriented. I was under the impression you had to undo the motor mounts jack the engine up as well. This looks like a pretty simple procedure. Perhaps I will be getting into that soon.
Active Member
Two Rings
How many miles on this car?
Active Member
Four Rings
I would maybe loosen the motor mounts as well so you don't put any strain on them or the engine cradle. Probably not necessary, but ideally you want to loosen all that up anyway to get them seated right, so its not really costing you any time.
-CP
2004 A4 1.8TQ 6MT USP - APR Stage 1 - FSI Coils - BKR7EIX-11 - 034 Silicon Breather - 034 Rear Swaybar (Soft Setting) and Solid Spherical Endlinks - B6S4 Front + B7A4 Rear Brake Setup - Failing Clutch Mod
2008 Black Unicorn (2.0t S-Line Ti 6MT Avant) - BRK6EIX-11
SOLD -- 2006 A4 2.0TQ Avant Tiptronic stocker - Failing TC Mod
Active Member
Three Rings
Jesus tap dancing Christ!
I just saw the pictures for the first time. <picks jaw up off floor>
-Rich
Senior Member
Four Rings
150k
Sent from my PC36100 using Tapatalk 2
Four Rings
Ya, 034 mounts are the kind of mounts you install and then you never worry about them again.
Diztek USP CLUB MEMBER #90
Apikol Snub Mount-GIAC FX04-Siemens 380cc-034Motor Mounts-AWE Exhaust-RS4 Rear Sway-OEM DSMIC-Evo Billet DV-Dension Icelink-Podi Boost Gauge-Stasis SS Coilovers-ECS slotted rotors.
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
