Results 1 to 15 of 15
    Active Member Two Rings WestfarmRacing's Avatar
    Jun 23 2011
    Sweden/Norway
    Trackvideo with the A4
    Tracking the B5 on michelin street tires..
    Senior Member Four Rings viceprp's Avatar
    Oct 17 2009
    is attached to my house.
    alonE, Pa
    Wow.
    ATW 1.8TQM | SCAT | FX400 | GTcougaR | Meth
    For sale: RAI FMIC & misc '00 parts
    STEVE
    Mar 04 2010
    Indpls, IN
    So im guessing your diff is modified? Fun times at the track, is that a BOV i hear?
    Veteran Member Four Rings awdjunkies's Avatar
    Dec 18 2005
    sedan, avant, truck/suv
    nevada
    Awesome track, beautiful scenery!! Great driving..
    ~Sergio~
    Coalition of The OEM+ Audi Owner's Member #9.
    http://www.audizine.com/forum/showth...IY-Master-List
    http://www.allroadfaq.com/reference/engine.shtml
    '01 AR= |034 TBB|034 Y pipe hoses|Custom Tune stg 1|Clarion NX501 ICE|oem roof bars|Yakima Skybox 18|VDO vent Boost Gauge|KnN Drop-in|Yellow Fogs|oem Double spoke wheels(2 sets) summer & winter|20%tint|034 SAI Block off plate kit, Now with less Combi valves
    Jun 23 2011
    Sweden/Norway
    Thanks. Its a lockable reardiff from s2/rs2, and a modified high-bias torsen. The "blowoff" is actually flutter because we run it without any at all..
    Senior Member Three Rings CCA4's Avatar
    Oct 25 2009
    A4, Cannondale Ironman caad 5
    Sterling, VA
    Isn't that bad for the turbo?
    01.5 A4 Avant 1.8TQM|Tuned by K0mpresd|CM FX300 240mm w/ 19lb LWFW|VDO|K&N|APR TIP|710n|Stėrn|PanzerPlate|A8/TT|EBC Redstuff|Neuspeed Race|ATP 3" TP|034 Catch Can| SSAC cat back
    Jun 23 2011
    Sweden/Norway
    Quote Originally Posted by CCA4 View Post
    That's what the besserwisser's use to say :) I guess it brings some more stress to the turbo, but seriously it held up for over a year now so it isn't that bad.. Check out the group-b cars from the 80's, they didnt have any either..
    Apr 22 2007
    02 Allroad, 98 A4, 73 Porsche 914 v8, 13 Genesis Coupe 2.0t, 02 Kawasaki ZX6R
    Modesto, Ca
    Was this a drift event?
    Whats your suspension setup? because that looks like quite a lot of understeer... Doesnt look like its setup for much front end grip on turn in... I understand street tires...
    98 A4 1.8TQM 160k miles
    Apr Stage 3, Comp Turbo CTB5356 (10psi) / FMIC by Greedspeed/ Cone intake/ Borla exhaust/ Test pipe/ Apexi boost controller/ Stage 4 SB clutch/ Spec 16lb FW/ Koni Coil overs/ H+R rear 22mm rear sway with welded mount support/ In dash GPS mount / AWE Drivetrain stabilizer/ Urethaned trani, motor, and rear end mounts/ 255awhp, 0-60 4.9, 1/4mile 13.57@100mph, 1.04 G's See it in action
    Senior Member Three Rings bw86's Avatar
    Dec 06 2008
    2.0L 058
    LI
    Looks like a lot of fun.
    Wish I had a track closer to me.
    2008cc - Holset HX35 - Lugtronic - ID1000s - IECVA1s
    --> first start <--
    FS: GM coolant temp sensor + IE billet adapter
    Mar 04 2010
    Indpls, IN
    Ahh i can hear it more in the second video now, Cool setup on the differential..
    New Member One Ring
    May 16 2012
    suzhou
    Quote Originally Posted by runvsofme07 View Post
    That would be easy.
    Jun 23 2011
    Sweden/Norway
    Quote Originally Posted by andyrew View Post
    It has h&r coilovers and powerflex bushings, understeering comes from bad grip and locked rear diff. You need gas through the bends to make it steer..
    Oct 25 2009
    Sterling, VA
    Awesome vids!
    Apr 22 2007
    Modesto, Ca
    Quote Originally Posted by WestfarmRacing View Post
    I see, So basically now your a 70's 911...
    Jun 23 2011
    Sweden/Norway
    Yeah, kinda :) But its more fun driving it that way.. would like a ramp diff though...
