Results 1 to 4 of 4
    Registered Member Three Rings
    Sep 14 2009
    s.e. mass
    Q?: Bleeding a DRY Hydraulic System? Any precautions to take
    Getting ready to finalize my build and wanted to have a discussion on the following:
    -DRY Power Steering Hydraulics system
    *Fresh Build, all new PS lines & Res. tank & pump
    -I'm mainly worried of frying my Powersteering pump... no fluid/a spinning pump = impending doom/unhappy nick.
    Just fill the PS reserve, cycle the steering wheel lock to lock a few times & add fluid as needed? Im just worried as the PS reserve is downstream from the pump you could say...
    Never dealt with a totally dry hydraulic system, as why I'd appreciate your .02cents!
    Thanks
    LAST
    PROJECT:B5
    -I'm here for the advancement of the B5 platform, not the AZ highschool drama... ITEMS FOR SALE
    Jun 29 2010
    Ottawa
    I beleive you want to jack the front off the ground and turn the wheel side to side while filling the reservoir. Once you have the fluid full turn the car on and do 10 full rotations of the steering wheel and add fluid if needed.
    Active Member Two Rings MCsquared's Avatar
    Dec 04 2011
    pull the fuel pump fuse and crank it over until the level stops dropping. then bleed it out normally
    Registered Audi Technician
    ASE Master Tech
    1999 A4 1.8qtm
    2001.5 S4
    Poverty is owning a race car
    Veteran Member Three Rings jballou's Avatar
    Mar 19 2005
    2007 Honda Fit
    French Valley, SOCAL
    I use a syringe and manually bleed it at the connector behind the motor on the pass. side. Makes life easier and harder to ruin the pump--plus no foaming.
    2000 Audi S4 Stage 3,000 Million +
    Some crap just thrown together....
    www.tvme.info
