Results 1 to 7 of 7
    Senior Member Four Rings redneck truck's Avatar
    Apr 22 2010
    2001 TTQ TDI Roadster 6MT, 2001 A6 4.2 6MT Stg 0-, 2000 Golf TDI 5MT, 2006 CBR1000RR
    Plano, TX
    VAG-Com - Revisiting communication issues, K1 short to ground, K2 OK
    I have had the same intermittent problem for about a year and a half and I can't seem to nail down what's causing it: VAG-Com will not communicate with any control module, and when entering Options\Test Connection, I get Status: Questionable; K1: Short to Ground; K2: OK.
    I have only seen this on my car and have used the same cable and port on a dozen different cars, so I know it's the car.
    - Radio is stock, no aftermarket electronics.
    - Transmission wiring harness was cut behind the firewall when I did the manual swap, removed the TCM.
    - While having the issue, disconnected ECU, cluster, radio, HVAC control head, ABS pump, didn't fix anything.
    - Inspected the OBD connector, looks fine to me.
    So, I'm at a loss. There are probably lots of modules on that communication bus, but I removed all the ones I could think of hoping one of them was causing the issue. Any thoughts on this would be most appreciated.
    Veteran Member Four Rings audifirst's Avatar
    Feb 08 2005
    C5 A6 Avant, VW Golf TDI
    Ontario, Canada
    K1: Short to Ground
    you need to trace wires , it is either cut or pinched somewhere.. perhaps when you did the conversion..
    did you test the vagcom in another car ?
    Apr 22 2010
    Plano, TX
    Yes, I've plugged it into my 3 other VW cars and several other cars as well. Suppose I better start pulling up carpet and figure out where it's shorting.
    Feb 07 2008
    00 stg 3 6mt a6, 91 f150 4x4 5mt
    01? I wonder if you're still running k-line data.
    I would check for power and ground at the obd connector with a multimeter.
    -dre
    Being different means nothing if you don't have taste
    WTB: 2001 4.2 A6 Transmission code FBC
    Apr 22 2010
    Plano, TX
    Communication is back! Seriously no rhyme or reason here. I let the car sit, turned off for 2 hours and now it works again. If the problem is wiring, one would expect some sort of mechanical input would be necessary to toggle the problem, but I literally walked away with it not working and walked back in to it working again. Maybe a relay is sticking? Maybe a module is shorted internally?
    Feb 07 2008
    I would lean towards the latter.
    I wonder what k1 and k2 are.
    -dre
    Apr 22 2010
    Plano, TX
    communication lines that run to all the modules, as I understand. Which means the short could be anywhere.
