Results 1 to 21 of 21
    Senior Member Three Rings greg@dubaudi's Avatar
    Feb 05 2005
    2001.5 pearl Avant
    Alton Bay, NH
    lots of new parts same issue and no codes...... I need your help please
    In Nov I purchased flyingfish Tial 605 Pearl Avant. This weird thing happened on my first pull leaving his house to drive cross country. Car starts to make boost then burbles and looses power and wont build boost, it gets between 5-10psi and then boom the burble/mini backfire and then no power. it drives fine idles fine and most of the time it pulls hard with no issue. A handful of times the car will be pulling hard at high RPM and the car will have a abrupt cut in power, like you pulled the plug. This issue comes and goes and I always have 0 codes thrown from it. I have found in my testing that with the aquamist off it still has the promlem without the small backfires. One other thing I noticed is that when its having this issues you don't fell the boost even build up at all before it does it. The boost gauge reads boost between 5-10 but you don't feel it. When its running good I can feel the boost build and start to pull.
    Fast FWD to Today first time I have driven it in two weeks. Drive to work and it runs amazing with 0 issues, text the old owner and say I think I finally fixed it. I was pumped..... Well on the way home boom same issues. I hate how it just comes and goes with no real rime or reason why it decides to act up.
    I have replaced over the last 4 months in order.
    bypassed N-249 valve
    new 710N DVs
    updated to FSI coilpacks deleted ICMs
    Plugs
    checked for boost leaks, found some small vacuum leaks replaced a few lines
    coolant temp sensor
    N-75
    New aquamist HFS-4 controller to replace HFS-3
    Old owner did EGT's and O2's within 5-10k miles
    Any ideas from you guys would be great.. Do you think I could have a bad ECU? Not sure what else there is to replace, especially when I don't get any codes at all.
    Greg
    2001.5 EPL/Tial 770 Pearl Avant///93 Corrado SLC///11 2500 Duramax beast
    Recaro:Dunlop:ChampionMotorsport:HSport:AWE:EPL:Vi sa:Mastercard
    Senior Member Three Rings CELison's Avatar
    Feb 23 2010
    state college pa
    sounds like an a/f problem. log and see what your maf and map readings are.
    b5 s4- f21 Stage 3+ meth
    b5 a4 - bone stock 2.8L 12v dd/rally-x monster
    Active Member Two Rings ryandoka10's Avatar
    May 11 2009
    00 stage 3 s4
    MY GARAGE
    That car needs to be tuned to your new altitude. If I'm not mistaken, that car has a higher elevation tune. It will not run right until it is flashed for where you are located now. Also, the waste gates are set to open at a much higher psi for the higher elevation tunes. Ask me how I know! I bought a 605 car from that area myself and had all the same issues. Good luck Greg!
    By the way I've got a set of brand new sportster cs seats for sale if your interested.
    Cheers
    Ryan
    Feb 05 2005
    2001.5 pearl Avant
    Alton Bay, NH
    Quote Originally Posted by ryandoka10 View Post
    Cheers
    Ryan
    It had this same issue in CO and the car has been tuned to seal level @EPL. It ran great great all day on the dyno for tony and the issue poped up on the test drive at end of day. Tony said it could be the N-249. After diving tonight I feel it does it more under load. Like up a hill or when I have people in the car.
    Please PM me on the seats.
    Registered Member Four Rings DxC's Avatar
    Nov 16 2006
    Boston
    i think its EGTs. try a tune with them deleted and see if it continues
    Oct 29 2005
    1988 Jetta, 1998 ZX7R
    Ft. Lauderdale, FL
    Log the car and look at the fuel correction
    - Clint
    C5 RS6 4.2TT Motor FS - Click Here
    Gone: White '04 S4 2.7T - Stage 2+
    Not a fan of the AZ Classifieds? Tell Anthony here: http://www.audizine.com/forum/showth...assifieds-suck
    Active Member Two Rings MCsquared's Avatar
    Dec 04 2011
    Stop randomly guessing and log the damn car...
    Registered Audi Technician
    ASE Master Tech
    1999 A4 1.8qtm
    2001.5 S4
    Poverty is owning a race car
    Jan 25 2006
    A4 2.0T
    MD
    Do you have the aquamist fail safes hooked up to your n75? If so, my money is on your meth system.
    Feb 05 2005
    2001.5 pearl Avant
    Alton Bay, NH
    Quote Originally Posted by Don Supreme View Post
    last I checked that's how is should be wired.
    Registered Member Three Rings panix73's Avatar
    Mar 17 2006
    Battleship Kruzer
    Long Island, NY
    Run a test on your G31 MAP sensor.. sounds like it could be on its way out..
    As someone also said before, check your EGT's...
    Innovate.
    Jan 25 2006
    A4 2.0T
    MD
    Quote Originally Posted by greg@dubaudi View Post
    huh?
    Senior Member Four Rings witwer4444's Avatar
    Dec 13 2008
    01 Nogaro S4
    Around
    Greg, check your email, i have somewhat good news
    Call Me Dave.
    Senior Member Three Rings Cadiburns's Avatar
    Feb 17 2010
    Chicago
    Very strange. It's not the aquamist. And most likely not EGTs. 5-10 psi on on 605s is NOT limp mode. Limp mode on 605s is about 18-20 psi. Very strange.
    B5 Casa S4 Avant | Tial 605s | EPL | Aquamist
    Feb 05 2005
    2001.5 pearl Avant
    Alton Bay, NH
    Quote Originally Posted by Cadiburns View Post
    Yup I just don't get it, its driving me nuts, every time I think I finally figured it out it starts doing it again. To add to the fun im getting blue/white smoke when driving super slow like creeping down my dirt road to my house, also just noticed it smokes when im driving in vacuum. Doesn't seem to be using anymore oil or coolant. Guess its time to start thinking about a built motor once I get this issue sorted out. Just ordered new EGT's and MAF just so I know that is ruled out. and leaves nothing else but trying a different ECU. Wish was doing it all the time so it would be easy to log the car, I will be driving it again this weekend and I will be ready to log if it acts up. I can't wait to truly enjoy this thing when its running 100%
    Btw I double checked the Aquamist install using this write up. http://www.google.com/url?sa=t&rct=j...H_fsStFbNrffkQ
    Veteran Member Four Rings A62TURBO's Avatar
    Apr 18 2007
    Hows your breather system?
    6 Speed--EPL--034--SPEC--ER--AquaMist--Forge--RS4--RS6--K04 --RNS-E--DTS--PSS9's
    Greg
    C5UNION
    Jan 25 2006
    A4 2.0T
    MD
    Is the car misfiring during the low boost situation?
    Feb 05 2005
    2001.5 pearl Avant
    Alton Bay, NH
    No only sounds like misfire when the meth kicks in, if meth is turned off then it just doesn't want to build boost with no misfire sound with 0 codes.
    Feb 05 2005
    2001.5 pearl Avant
    Alton Bay, NH
    Quote Originally Posted by A62TURBO View Post
    Looks ok, one thing the old owner did not replace, noticed some oil around the pancake valve. Thinking of pulling the trigger on the vast catch can system.
    Senior Member Three Rings VR6Bomber's Avatar
    May 13 2009
    '12 ABARTH - 90TQ aan'd 3071'd
    HERE
    I have the vast can for sale if you are interested.
    Feb 05 2005
    2001.5 pearl Avant
    Alton Bay, NH
    just installed a new MAF at work and took it for a rip.... ran better than it ever has, fingers crossed its fixed..
    Feb 05 2005
    2001.5 pearl Avant
    Alton Bay, NH
    Went for two more drives to run errands and so far so good I think I finally got it...
    Thanks for the help guys
