Results 1 to 21 of 21
    Senior Member Two Rings ljnaum26's Avatar
    Feb 02 2011
    Us
    Several Faults/ APR Related?
    I've had the stage 2 file installed for about 2 weeks now with no issues. While driving tonight, i put the car into "S" and sped up. While doing so the car began to slightly hiccup/surge. I immediately drove home and scanned it, resulting to several faults. Im REALLY hoping somethings not horribly wrong since i just had the testpipe and tune installed because dealing with the dealer/warranty/TD1 is going to be a nightmare. If anybody could look at the scan and let me know what they thinks going on i would greatly appreciate it. Thanks
    01-Engine -- Status: Sporadic communication error 1000
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: Malfunction 0010
    04-Steering Angle -- Status: OK 0000
    05-Acc/Start Auth. -- Status: Malfunction 0010
    08-Auto HVAC -- Status: Malfunction 0010
    09-Cent. Elect. -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: Malfunction 0010
    19-CAN Gateway -- Status: Malfunction 0010
    42-Door Elect, Driver -- Status: OK 0000
    46-Central Conv. -- Status: Malfunction 0010
    47-Sound System -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    53-Parking Brake -- Status: Malfunction 0010
    56-Radio -- Status: Malfunction 0010
    62-Door, Rear Left -- Status: OK 0000
    65-Tire Pressure -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    Address 01: Engine (-----CAEB) Labels: 06H-907-115-CAB.clb
    Part No SW: 8K2 907 115 D HW: 8K2 907 115 D
    Component: 2.0l R4/4V TF H14 0002
    Revision: E1H14---
    Coding: 0104010A190F0160
    Shop #: WSC 06325 000 00000
    ASAM Dataset: EV_ECM20TFS8K2907115D A01002
    ROD: EV_ECM20TFS8K2907115D.rod
    No fault code found.
    Readiness: 0010 0001
    Address 02: Auto Trans (J217) Labels: 0B6-927-156.clb
    Part No SW: 8K0 927 158 C HW: 0B6 927 156
    Component: 0B6 20TFSIUSA H04 0050
    Revision: --H04---
    Coding: 001002
    ASAM Dataset: EV_TCMAL651 A01004
    ROD: EV_TCMAL651.rod
    Address 03: ABS Brakes (J104) Labels: 8K0-907-379.clb
    Part No SW: 8K0 907 379 AB HW: 8K0 907 379 AB
    Component: ESP8 quattro H04 0060
    Revision: -------- Serial number: --------------
    Coding: 150500
    2 Faults Found:
    01314 - Engine Control Module
    004 - No Signal/Communication - Intermittent
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 26
    Mileage: 54799 km
    Time Indication: 0
    Date: 2012.04.20
    Time: 10:37:14
    Freeze Frame:
    Hex Value: 0x0000
    Hex Value: 0x0082
    Hex Value: 0x000C
    Hex Value: 0xB998
    Hex Value: 0x00FF
    00473 - Control Module for Elect. Park/Hand Brake (J540)
    013 - Check DTC Memory - Intermittent
    Freeze Frame:
    Fault Status: 00101101
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 26
    Mileage: 54799 km
    Time Indication: 0
    Date: 2012.04.20
    Time: 10:37:14
    Freeze Frame:
    Hex Value: 0x0000
    Hex Value: 0x2282
    Hex Value: 0x0013
    Hex Value: 0x0298
    Hex Value: 0x00FF
    Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
    Part No SW: 8K0 907 064 F HW: 8K0 907 064 F
    Component: BCM2 1.1 H80 0141
    Revision: 00002001
    Coding: 090100
    Part No SW: 8T0 959 754 A HW: 8T0 959 754 A
    Component: FBSAUDIB8 IDG H37 0060
    Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
    Component: ELVAUDIB8 H36 0041
    1 Fault Found:
    01330 - Central Control Module for Central Convenience (J393)
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 26
    Mileage: 54799 km
    Time Indication: 0
    Date: 2012.04.20
    Time: 10:37:14
    Address 08: Auto HVAC (J255) Labels: Redir Fail!
    Part No SW: 8T1 820 043 T HW: 8T1 820 043 T
    Component: KLIMA 1 ZONE H06 0140
    Revision: A0000000 Serial number: 0115.09.080027
    Coding: 64002000
    2 Faults Found:
    01271 - Positioning Motor for Temperature Flap (V68)
    001 - Upper Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100001
    Fault Priority: 3
    Fault Frequency: 2
    Reset counter: 44
    Mileage: 54191 km
    Time Indication: 0
    Date: 2012.04.12
    Time: 15:20:29
    Freeze Frame:
    Voltage: 13.90 V
    Temperature: 27.0°C
    Temperature: 13.0°C
    Count: 11210
    Count: 12089
    Bin. Bits: 01000000
    Bin. Bits: 00000111
    008 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Status: 00101000
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 27
    Mileage: 54799 km
    Time Indication: 0
    Date: 2012.04.20
    Time: 10:37:13
    Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
    Part No SW: 8K0 907 063 C HW: 8K0 907 063 C
    Component: BCM1 1.0 H22 0253
    Revision: 04022001 Serial number: 00000000221389
    Coding: 690000B1063C00010000080000007F5F0F1452080000000100 0000
    Part No SW: 8K1 955 119 A HW: 8T1 955 119
    Component: WWS 230908 H06 0070
    Coding: 00FD11
    Part No SW: 8K0 941 531 F HW: 8K0 941 531 F
    Component: E1 - LDS H07 0070
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 27
    Mileage: 54799 km
    Time Indication: 0
    Date: 2012.04.20
    Time: 10:37:00
    Address 15: Airbags (J234) Labels: 8K0-959-655.clb
    Part No SW: 8K0 959 655 F HW: 8K0 959 655 F
    Component: AirbagVW-AU10 H27 0410
    Serial number: 0039KD146YKO
    Coding: 303836354230303030304A55304C384B3053
    ASAM Dataset: EV_AirbaECUVWAUDI010 A02007
    ROD: EV_AirbaECUVWAUDI010_AU48.rod
    Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
    Part No SW: 8K0 953 568 F HW: 8K0 953 568 F
    Component: Lenks.Modul H13 0013
    Revision: -------- Serial number: 90304HII000A0
    Coding: 000014
    Component: E221 - MFL H02 0003
    Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
    Part No SW: 8K0 920 950 A HW: 8K0 920 950 A
    Component: KOMBIINSTR. H17 0224
    Revision: 00000000 Serial number: 9DR2A2R98
    Coding: 831309000300D705020000
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 26
    Mileage: 54799 km
    Time Indication: 0
    Date: 2012.04.20
    Time: 10:37:15
    Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
    Part No SW: 8T0 907 468 H HW: 8T0 907 468 H
    Component: GW-BEM 5CAN H06 0094
    Revision: 4GB20042 Serial number: 4200G0890183AC
    Coding: 000303
    Part No SW: 8K0 915 181 B HW: 8K0 915 181 B
    Component: J367-BDM H04 0150
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 26
    Mileage: 54799 km
    Time Indication: 0
    Date: 2012.04.20
    Time: 10:37:14
    Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
    Part No SW: 8K0 959 793 B HW: 8K0 959 793
    Component: TSG FA H10 0170
    Revision: Serial number: 0000007712015
    Coding: 011C03204000410001
    Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
    Revision: 00002001 Serial number: 0114315394
    Coding: 0106063A007A000400B001
    Part No: 1K0 951 605 C
    Component: LIN BACKUP HO H03 1301
    Part No SW: 8K0 959 591 HW: 8K0 959 591
    Component: J245 PS034 H06 0037
    4 Faults Found:
    02615 - Fuel Tank Cap; Lock
    009 - Open or Short to Ground
    Freeze Frame:
    Fault Status: 01101001
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 14
    Mileage: 49457 km
    Time Indication: 0
    Date: 2011.11.16
    Time: 15:22:39
    02616 - Fuel Tank Cap; Unlock
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 14
    Mileage: 49457 km
    Time Indication: 0
    Date: 2011.11.18
    Time: 10:53:58
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 26
    Mileage: 54799 km
    Time Indication: 0
    Date: 2012.04.20
    Time: 10:37:14
    00230 - Transmission Park Selector Switch (F305)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 26
    Mileage: 54799 km
    Time Indication: 0
    Date: 2012.04.20
    Time: 10:38:15
    Address 47: Sound System (J525) Labels: 8T0-035-223-ASC.clb
    Part No SW: 8T0 035 223 AB HW: 8T0 035 223
    Component: DSP STD H07 0220
    Revision: S2100000
    Coding: 0203010102
    Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
    Part No SW: 8K0 959 792 B HW: 8K0 959 792
    Component: TSG BF H10 0170
    Revision: Serial number: 0000007718638
    Address 53: Parking Brake (J540) Labels: 8K0-907-801.clb
    Part No SW: 8K0 907 801 E HW: 8K0 907 801 E
    Component: EPB Audi B8 H05 0060
    Revision: 00000003 Serial number: 10000000100883
    Shop #: WSC 00000 000 00000
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 26
    Mileage: 54799 km
    Time Indication: 0
    Date: 2012.04.20
    Time: 10:37:14
    Freeze Frame:
    Voltage: 12.30 V
    Count: 64
    Speed: 0.0 km/h
    Hex Value: 0x0260
    Hex Value: 0x0001
    Hex Value: 0x0101
    Address 56: Radio (J503) Labels: 8Tx-035-1xx-56.clb
    Part No SW: 8T1 035 195 L HW: 8T1 035 195 L
    Component: Symph3 Sirius H02 0211
    Revision: 00000004 Serial number: AUZ5Z4H1047705
    Coding: 05020002010185004119070000
    Part No SW: 8T0 919 603 A HW: 8T0 919 603 A
    Component: Display
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 27
    Mileage: 54799 km
    Time Indication: 0
    Date: 2012.04.20
    Time: 10:37:19
    2009 A4 Q. H&R oe VMR v710 APR Stage 2
    Active Member Two Rings wrclaguna's Avatar
    Jan 11 2012
    A4 B8 S LINE
    POLAND/Bieszczady
    Chipped 203HP/419NM / FMIC / S4 Brakes 345/330 / Double Exhaust 3.0 TDI / H&R Springs
    Sway Bar RS4 B8 / Audi TT/R8 Steering Wheel / Aluminium Footrest & Pedals RS4
    TPMS / Rear Camera + PDC / Wheels S5 19" / SIDE ASSIST/ LANE ASSIST/ACC RADAR/HIGH BEAM ASSIST
    MY AUDI A4 B8 S LINE EXTERIEUR
    Senior Member Four Rings Calbee's Avatar
    Mar 04 2010
    Vancouver
    ...and i was just thinking of going stage 2 again..
    hope someone can come in here and clear it all up for you, and i hope for the best!
    Modifications: Debadged all the badges at the back for a clean, fresh look.
    http://instagram.com/crisostomoz : most up to date upgrades to the car, as well as random things.
    Active Member Two Rings b8dsbA4's Avatar
    May 23 2010
    2010 B8 A4 Quattro. 2005 Jeep Liberty
    Bergen County, New Jersey
    I had the same faults recently however when the car began to hiccup all the lights inside and outside (lowbeams, taillights, instrument cluster, radio and overheads) kept going on and off and eventually stayed off. I turned off the car and then turned it back on again and the lights still wouldn't come on. I had to disconnect the battery and reconnect it for the lights to come back on.
    Feb 02 2011
    Us
    i just noticed the dates the faults occurred was the day the car got flashed, but i have been driving problem free for 2 weeks? Does unplugging the battery erase the tune?
    Senior Member Three Rings rippin'av's Avatar
    Nov 18 2009
    '00 S4 Stage 3, '05 LR3, '08 ML63 AMG, '02 BMW 1150GS, '71 BMW R75/5
    CA
    No, unplugging won't erase the tune. Try clearing the codes with your ross-tech cable and scan after putting some more miles on the car. Tune shouldn't have done anything to cause issues. Faults were probably from the flash.
    2008 ML63 AMG
    2000 S4 6MT (371 whp/417 wtq)
    ASP Stage 3 / ER intercoolers / ST coilovers / 034 goodies / ECS spacers / Borla exhaust
    Senior Member Three Rings a4_bob's Avatar
    Mar 13 2010
    Atlanta/GA
    agreed, this looks more like something relatively harmless that happened during the install - maybe battery disconnect or something along that line. I often see codes like these when my car comes back from the Audi dealer. Just clear them and re-scan occasionally. If they come back during regular operation then you have something to investigate. Further, the ecu tune itself should have no impact whatsoever on these components.
    remain calm.
    Feb 02 2011
    Us
    UPDATE: Disconnected battery and re scanned after connecting it back, all codes cleared
    Still wondering why it was surging last night, will update thread if that persists.
    Thanks to everybody that contributed.
    Feb 02 2011
    Us
    The codes are gone but the car is still surging pretty badly under hard acceleration. Im going to give the APR installer a call. Anybody experience this?
    May 23 2010
    Yep. same thing happened to me. Did you do any electrical work on the car?
    Stage 3 Forum Advertiser Four Rings Excelerate's Avatar
    Jan 24 2008
    12 TT RS, 09 GTI, 03 GTi VR6, 02 GTi VR6
    Branford, CT
    Quote Originally Posted by ljnaum26 View Post
    The dealer probably forgot to clear out the codes after flashing the software. Just clear it out with VAG COM. Do a CAN based scan and then click clear all codes.
    Excelerate Performance specializes in performance parts, wheel and tire packages, suspension, and service for the VW/Audi platforms!!!
    12 Sycamore Way Unit 1
    Branford, CT 06405
    P: 203-483-6100 E: sales@excelerateperformance.com
    Click here for our Facebook Page
    WEB STORE: Store.ExceleratePerformance.com
    Feb 02 2011
    Us
    Quote Originally Posted by b8dsbA4 View Post
    Nope, only thing ive done is Vagcom tweaks like disabling the seat belt chime and rolling the windows down with the key, whats the story with yours surging and how did you get it resolved?
    Apr 01 2010
    Definitely contact your installer. Probably wouldn't hurt to contact APR either. I had some issues with the Stage 1 upgrade. Installer didn't think my issue was related to the upgrade. Took my car to the car dealer and they ended up re-flashing back to factory. Luckily my installer put the tune back on for free. Several months later I had the same issue re-occur. Did some research and found the problem was due to the tune. Took it back to my installer, presented them with the information I found (non confrontational) and they contacted APR. There was an update from APR that they re-flashed my ECU with and that took care of the issue. That was two years ago and I haven't had a problem since.
    Senior Member Three Rings shonseb's Avatar
    Aug 04 2010
    2010 Audi A4
    Queenz/Ohio
    I had something similar recently, turned out to be a boost leak. Check your hoses, tighten if necessary.
    2011 A5 P+ Ibis White, Ti Edition, Nav, B&O
    OEM APR Eurocode H&R SPC SPM
    May 23 2010
    I had installed the xcarlink module and that seemed to cause the problem. I had taken the car to three apr dealers and none of them can figure out what was wrong with the car and the dealer couldn't figure it out either. I then started to trouble shoot the problem by removing the mods I installed prior to the problem happening. It ended up being a problem with the xcarlink unit so I took it out and I haven't had a problem since.
    Feb 02 2011
    Us
    going in wednesday to have it looked at, another thing i noticed is that it is MUCH more noticeable in 93 octane mode than stock. In fact, stock mode may be not doing it at all.
    Active Member Four Rings maga4's Avatar
    Aug 12 2011
    Olathe, Kansas
    Could it be something as simple as the gas not really being 93 octane? Or may the installer/flasher accidently put the 100 octane file in that slot or something? I don't know a ton, but shonseb had a good point regarding checking for a boost leak...could explain the surging... Good luck!
    2011 A4 Premium+, Quattro, 6MT, 18" OEM 5-spokes, Nav, Black/Black
    APR Stage 2, Eurocode HFC/TIP/TRUFit Kit/HFIP, 35% Tint, Eibach Pro-Kit, Vag-Com, Gloss Black 3.2 Grille, Hoen Endurance Fogs, LED Interior/License Plate Lights, Strat Short Shifter, BFI Catch Can, Hardwired V1, Rieger Lip Replica, FRT's CXRacing FMIC, aFe Filter
    '91 Audi 90s Quattro, 5MT, White, Stock
    Feb 02 2011
    Us
    lol id be pretty pissed if they accidentally made the 93 octane mode the 100 instead, that could do some pretty serious damage. But im hoping its just simple like a boost leak. Will find out on wednesday
    thanks
    Stage 2 Banner Advertiser Four Rings dbcperformance's Avatar
    Mar 23 2009
    TEXAS
    Quote Originally Posted by Excelerate View Post
    This. Clear the codes. I am making this suggestions based on your comment about all codes being from the flash day.
    Berk Ariercetin
    Managing Director | DBC Tuning
    P: 210.399.1172
    F: 210.579.6757
    E: berk@dbctuning.com
    Feb 02 2011
    Us
    I stated earlier that i already cleared the codes but the car is still having problems
    Feb 02 2011
    Us
    I went to the APR dealer today and they found that one of the spark plugs had a hair line crack and was arcing, so they needed replacement. I told the shop to go ahead and replace them. when i got home i noticed the part number of the plugs was for the B7. Any major differences in the plug generations i should be concerned about? Im kinda pissed about it and want to change them just to be safe.
