Results 1 to 7 of 7
Thread: Sweating 3.0
    Veteran Member Four Rings T0M3K's Avatar
    Sep 14 2007
    Valley Stream, NY
    Sweating 3.0
    My engine shows oil on the heads and it appears to be simply said, sweating:
    I would think that is the problem with head gasket.
    Active Member Four Rings Charles.waite's Avatar
    Jun 27 2011
    2004 A4 1.8TQ 6MT USP • 2006 A4 Avant 2.0T tip
    Nope thats a Valve Cover gasket. I think that's what you meant though.
    You might want to check out your PCV as when it fails it usually takes out the Valve Cover gaskets because the increased pressure in the crankcase causes oil to seep past the gaskets.
    -CP
    2004 A4 1.8TQ 6MT USP - APR Stage 1 - FSI Coils - BKR7EIX-11 - 034 Silicon Breather - 034 Rear Swaybar (Soft Setting) and Solid Spherical Endlinks - B6S4 Front + B7A4 Rear Brake Setup - Failing Clutch Mod
    2008 Black Unicorn (2.0t S-Line Ti 6MT Avant) - BRK6EIX-11
    SOLD -- 2006 A4 2.0TQ Avant Tiptronic stocker - Failing TC Mod
    Senior Member Four Rings rollerton's Avatar
    Sep 16 2010
    S6 Avant X TWO! and 67' Speed buggy
    Central Wash
    What he said. But those gaskets are kind of a PITA, due to the rigid coil pack harness housing, dipstick, and the front timing covers. Still, you can do them yourself- but be careful, the valve covers are PLASTIC. Don't overtighten.
    Senior Member Four Rings JoshDub's Avatar
    Oct 09 2008
    1990 Audi 90 Quattro 20V, 1989 BMW 325iS
    The valve covers are actually very easy.
    1) unbolt coolant tank and rotate out of way (don't drain!)
    2) remove air box
    3) remove coilpacks
    4) unbolt coil pack wiring harness from valve covers
    5) unbolt timing belt covers (should be 4 torx bolts up top).
    6) unbolt dipstick tube from side of engine and valve cover, then slide out of way (doesn't move much).
    7) disconnect the vacuum lines from back of valve covers (1 per)
    8) unbolt valve covers and remove / replace gasket.
    9) reinstall in reverse order.
    That should be everything is memory serves me correctly.
    The Awesome™
    Sep 14 2007
    Valley Stream, NY
    Sounds like one of those weekend projects, where 2 hour tasks takes 2 days since everything will go wrong.
    Senior Member Four Rings JEENYUS's Avatar
    Jul 28 2009
    2003 A4 3.0 V6
    SL,UT
    this. if your car is running like shit, that is the reason. I posted up a DIY for the PCV on a 3.0. it's a really easy swap.
    also, VC gasket is easy. i am going to have to do mine here this weekend i imagine. I will try to take pics and post up a DIY for that as well.
    Jun 27 2011
    Quote Originally Posted by T0M3K View Post
    This is definitely the case.
    I did my VCG on my 1.8t and i ended up snapping my PCV breather (extremely common I later learned) and it ended up I needed to trek to the dealer and for over $80 in parts and jerry rig other stuff with heater hose to get it up and running. Definitely leave extra time in case of the inevitable collateral damage...
    -CP
