Page 2 of 2 FirstFirst 12
Results 41 to 53 of 53
  1. #41
    Active Member Four Rings Charles.waite's Avatar
    Jun 27 2011
    2004 A4 1.8TQ 6MT USP • 2006 A4 Avant 2.0T tip
    Did you get the dipstick tube fully seated? I had to give mine a few solid taps with a hammer and a block of wood to get it to properly snap in.
    -CP
    2004 A4 1.8TQ 6MT USP - APR Stage 1 - FSI Coils - BKR7EIX-11 - 034 Silicon Breather - 034 Rear Swaybar (Soft Setting) and Solid Spherical Endlinks - B6S4 Front + B7A4 Rear Brake Setup - Failing Clutch Mod
    2008 Black Unicorn (2.0t S-Line Ti 6MT Avant) - BRK6EIX-11
    SOLD -- 2006 A4 2.0TQ Avant Tiptronic stocker - Failing TC Mod
  2. #42
    Senior Member Four Rings
    Apr 03 2010
    houston, tx
    go back and look at the PCV. It's next to the dipstick tube; chances are that either that or the hoses that lead up to it are pooched.
    Valve cover gasket and CCT leaks have a tendency to wander and end up in places you wouldn't expect.
  3. #43
    Senior Member Three Rings b7a4GT30's Avatar
    Oct 01 2010
    b7 a4 2.0T 6MT
    Yes i tapped in a bunch of times with a rubber mallet!
    Quote Originally Posted by daihashi View Post
    Ok, but if it was the PCV valve then wouldn't the oil cap be hard to take off when the engine is running?
    2007 B7 A4 2.0T 6MT
    RNS-E | Rs4 Rear Sway Bar
    OEM Bi-Xenons | Bilstein / HR
    DTM Sport Shift Knob | AWE Boost Gauge
    Custom V1 Display | RS4 Steering Wheel
    More to come!!
  4. #44
    Jun 27 2011
    Quote Originally Posted by b7a4GT30 View Post
    A failed PCV valve should make it EASIER to take the oil cap off. But I've learned thats generally not a foolproof sign its the PCV, there can be a number of reasons that the block isn't under sufficient vaccum at idle to suck the oil cap down a little bit.
    It could be the PCV, and that's honestly the likeliest culprit, but it could also be a failed check valve somewhere in the vacuum system or the Suction Jet Pump.
    Heres a link for some of the PCV breather hose info: http://www.audizine.com/forum/showth...=1#post6016725
    They often snap but since they're buried behind a bunch of stuff, its hard to spot...
    -CP
  5. #45
    Senior Member Four Rings waldo1324's Avatar
    Apr 06 2009
    the Ghost of the Princess, 2007 Ford Fusion, 2006 Honda Accord
    The StL
    Suction Jet Pump.
    change that -- mine was completely clogged
    oh and chec your Diverter Valve line. mine was cracked and was robbing -5 in Hg and gave me hard starts and idle.
    if Charles hasnt suggested it , check your injector seats. if they are grimy, clean em or replace
    Engage.
    ""GHETTO MODIFIERS"" member #1
    The Princess: SOLD.. i love you, please forgive me
    "I agree with Waldo 100%" -1997GTX
    ..psst if you have a USP 05 or a 2003+ 225 TT, email me..wally.iverson(at)gmail.com
    aaand somebody buy my g'dam Ferodo Rear Pads FFS
  6. #46
    Apr 06 2009
    The StL
    Quote Originally Posted by doogie891 View Post
    WALDOOOOOOOO WTF is up with ur avatar now!!! hahahahaha! i was like who the hell just posted 3 times in a row looks like something waldo would do and it was you even before i saw it. lmfao!
    yes go forth and be blessed now my son
  7. #47
    Oct 01 2010
    b7 a4 2.0T 6MT
    Ok i will check all the above!
    2007 B7 A4 2.0T 6MT
    More to come!!
  8. #48
    Oct 01 2010
    b7 a4 2.0T 6MT
    OK i went over everything and it still has the same problem. Only now i can hear a loud very pronounced hissing sound (which means a leak) towards the back of the engine bay coming from the area right dead center back of the engine bay. In this pic http://www.google.com/imgres?q=b6+a4...9,r:1,s:0,i:74 (it is located right in front of the engine wall right around the area of the diverter valve looking piece [im not sure what this is called]). Anyways, that is where the loud hissing sound is coming from.
    Any ideas?
    2007 B7 A4 2.0T 6MT
    More to come!!
  9. #49
    Nov 12 2011
    Sounds like it could be your pancake valve (PRV)... take a look at this link: http://www.audizine.com/forum/showth...-n00bs-like-me. It's #1 in the list.
    Or, maybe even more likely, the 3-way breather hose right next to it. I've had that go bad on me twice...
    Even though I don't have any bad symptoms yet, I haven't replaced any of these, so I'm going to work my way down the list as preventive maintenance (well, as preventive as one can be with nearly 165k on the clock...)
    -Mark
  10. #50
    Oct 01 2010
    b7 a4 2.0T 6MT
    Ok i will look into this today. Is there a solid way of testing to see if the PCV Valve is the culprit other than starting the engine and taking the oil cap off? I did that last night at it wasn't easy to take off while the engine was idling.
    2007 B7 A4 2.0T 6MT
    More to come!!
  11. #51
    Jun 08 2008
    Calgary AB Canada
    Not always true. When one of the check valves died in my breather system it was nearly impossible to remove the cap while the engine was running. With a properly operating PCV the cap should "dance" on top of the valve cover
    2004 Audi A4 1.8T // quattro // 6 Speed // Brilliant Red
    Built 1.8T || AEB || revo || GT3076R
    1991 BMW ///M5 3.6 // 5 Speed // Macao Blue Metallic
    BetaAlphaTau Member #111
  12. #52
    Jun 27 2011
    Quote Originally Posted by onceover View Post
    Interesting. My PCV system is bascially all new (034 Silicon kit) and all my check valves are new as well. Could the somewhat suspect 034 billet PCV valve be an issue? Might have to order up an OEM one and see if it changes anything...
    -CP
  13. #53
    Oct 01 2010
    b7 a4 2.0T 6MT
    Solved the problem!!!! It was the PVC valve and the three way breather hose. I swapped them right out cleared the codes and the car is back to normal!! Thanks for all your help!
    2007 B7 A4 2.0T 6MT
    More to come!!
