Results 1 to 6 of 6
    Active Member Three Rings yayjohnny's Avatar
    Jan 18 2011
    Audi A4 B7
    Central Valley, CA (NorCal)
    Trunk Latch Replacement Sensor going whacko
    So I changed up my trunk latch to the newer version ones because mine kept failing due to the cold.
    After I changed it up, the sensor keeps saying the trunk is unlocked, but its clearly locked.
    I just tried to re-connect the sensor cable but still doesn't work.
    WHATS GOING ON?!
    UPDATE: fix it. took the latch apart and swapped the sensors.
    now it works like a charm.
    I also noticed white fluid/oil/grease in the new latch, and dried up residue what seemed to use to have the white fluid/oil/grease.
    It's also in the lock mechanism itself, perhaps the cause for the trunk latch problem is that it dried up?!
    05.5 B7 - Quartz Grey
    APR Stage II - K&N Drop In - Piston DV "D"
    DTM Front w/ Fogs :: Non S-Line RS4 Grille :: 18" BBS RC :: H&R Sport Springs :: Deval Trunk Spoiler :: RAI HFC & Downpipe to Stock Pipes with Magnaflow Mufflers :: LEDs (Interior and License Plate)
    Jan 18 2011
    Audi A4 B7
    nobody knows? :/
    Senior Member Four Rings jimrobbington's Avatar
    Dec 03 2008
    07 Suzuki SV650
    Parker, Colorado
    It is possible you got a bad latch. I would take it back and exchange it for another.
    Senior Member Three Rings JPT's Avatar
    Oct 11 2010
    '05 Kawasaki Ninja ZX12R
    Long Island/NY
    Mine does this. It was replaced, and it does it when I don't slam it closed. It clearly is closed, but the senor says it is open. So I open and close it, and it is fine.
    Jan 18 2011
    Audi A4 B7
    Quote Originally Posted by JPT View Post
    HMMM, weird... I'll try and reinstalling it, and/or swapping ti back to the old one and see waht it says
    Jan 18 2011
    Audi A4 B7
    the thing is, i tried unlocking, and locking, probably fifty times with the new latch. so nothing
    decided to take it apart and swap the sensor/motor.
    update: fixed.
