Tiptronic: tip mode clunk into first
So I have a tip trans with a 517 valve body. In D or S modes, when coming to a stop it's completely smooth, but when i drive in tip mode, when coming to a stop it seems like it shifts into first almost too early and I get a noticeable clunk. Does anybody else have this problem? It only happens when downshifting to first.
Four Rings
shot in the dark...
maybe it is drive line slop? (like a sloppy snub, trans, or rear diff mount)
-John
"get the biggest of everything you can. always. that's a winning combination. everytime. just ask the military." -Dan[FN]WTF
Four Rings
How long have you had the transmission? Some people get a super smooth transmission right off the bat, others it may take a couple miles to smooth out.
Smooth:
http://www.audizine.com/forum/showth...ns-T-C-amp-V-B
http://www.audizine.com/forum/showth...w-B7-A4-6HP19A
Damn, tried to find the posts about allowing some break-in time but can't find them. I definitely saw them, talk to Sam at 517 about it, also if 517 didn't do the install it might be wise to check the fluid level.
On another note, my valve body from 517 will be here tomorrow to meet up with my torque converter. =)
1.9L GT3071r 517 trans
Mods: Eurodyne Maestro 7 / Stasis Alcon 355mm Mono6 / 034 Billet Fuel Pump 005 / Neuspeed snub mount / RS4 rear sway / Custom Magnaflow 14581 exhaust / INA adapters with FSI coilpacks / Thor Skidplate / CF S4 blades / DTH CF Roof Spoiler / RD led lp / Smoked sidemarkers / 3k HID fogs / 35% tint / Symphony II+
Shift it yourself? It's in tiptronic if it's shifting down for you then the RPM are going too low... I'm sure what you feel is engine braking and it's normal
The valve body been installed for about 2 years...probably a good idea to check the fluid but it strange that it doesn't happen in d or s modes
It doesnt do it in D or S because it is shifting normally. In tiptronic the car expects you to downshift. Note the RPM when it doenshifts are going to be very low. It clunks because your engine is braking. Ever been in a manual car when a person engine brakes? It's the car slowing itself down.
This is not engine braking....when coming to a stop the downshift into first is very harsh and jerks the car...I wish the tcu didn't shift into first until the car was stopped...maybe it is the trans mounts like eerie said
Senior Member
Two Rings
My car will stay in 2nd until the car is completely stopped, if I do a nice california roll on a stop sign I will still be in second until I downshift when I start accelerating. Its a good 2-3 seconds when my car is stopped before it goes to first by itself.
That's what it should do! Mine shifts into 1st at like 5 mph.....I wonder if there's a software update for this?
Senior Member
Four Rings
Harsh downshifts while coasting in Tiptronic mode, eh? Maybe THIS GUY or perhaps THIS GUY OVER HERE.
2001 Laser Red A4 1.8TQM, 5-Speed Swapped, APR 93, Splitter, electronic oil pressure gauge, B6 Sport 17's, ST Coilovers,
Need to borrow a Cam Chain Tensioner Tool? $4 for shipping. PM me. *Unavailabe*
The car has a newish 517 valve body...all downshifts feel great except into first because it shifts into 1st too early, before the car has stopped.
Active Member
Four Rings
I would talk to 517 and ask them what the problem could be. You might need to reset the transmission adaptation. (assuming here that the transmission stores the driving adaptation values that is.)
-CP
2004 A4 1.8TQ 6MT USP - APR Stage 1 - FSI Coils - BKR7EIX-11 - 034 Silicon Breather - 034 Rear Swaybar (Soft Setting) and Solid Spherical Endlinks - B6S4 Front + B7A4 Rear Brake Setup - Failing Clutch Mod
2008 Black Unicorn (2.0t S-Line Ti 6MT Avant) - BRK6EIX-11
SOLD -- 2006 A4 2.0TQ Avant Tiptronic stocker - Failing TC Mod
Yeah that's a good call...I'll look into the trans adaptation...thanks!
Four Rings
how much did the 517 valve body cost you because i been thinking about doing that.
TuRboK1ng
You Are All Witnesses
And The Yankees WIIIIIIIIIIIIIIIIIIIIIIIIIIN
The Yankeeeeeeeeeeeees WIIIIIN!!!!!!!!!
The valve body is $700 if I remember correctly. The previous owner who did the install said it really made the car more enjoyable to drive and was the best mod he did.
2005 USP-APR k04,Kinectic exhaust manifold, techtonics downpipe, apr inlet, carbonio, boost brothers Fmic,VMR test pipe, st coilovers, b5 s4 brakes, 517 valve body
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
