Results 1 to 25 of 25
    Active Member Two Rings Epa7's Avatar
    Feb 25 2012
    Portland, OR
    How to Detail my New A7?
    The dealer let me know that my A7 is ahead of schedule and will be delivered toward the end of April. The dealer told me this is their prep:
    "Audi's arrive wrapped from the factory and without any wax. So after our pre-delivery inspection, we remove the wrapping and any adhesive from it... then wash, buff and wax the exterior. We also remove the saran wrap from the interior and vacuum the carpet only (no chemicals used)."
    Does Audi use the white plastic panel covers or is it really "wrapping" (i.e. full coverage)? I definitely want to clay, seal, and wax at some point, but should it be done right away? Is there any benefit to waiting a bit?
    Active Member Two Rings audisline08's Avatar
    Jul 20 2011
    Alabama/Ft. Benning, GA
    Correct me if I am wrong but you dont need to clay bar a brand new car?! You should be fine with regular washing/waxing for awhile!
    Brilliant Black Quattro 6MT
    Veteran Member Four Rings A4A4A4's Avatar
    Jun 02 2008
    Victoria/Calgary, Canada
    -Cam
    The Old: 2008 Audi A4 2.0T Quattro
    The New: 2008 BMW 335i Coupe
    Active Member Two Rings Darkstar752's Avatar
    May 20 2010
    Bethlehem, PA
    You'll want to correct the holograms that will most likely be there from the dealer. There is no benefit to waiting. Clay may or may not be necessary, depending on how much it was covered during transportation and how long it sat in the lot. I would recommend picking up an Ultra-fine clay bar to remove any contaminants, if it's not needed then you'll have it for when you need it 6-12 months down the road anyway.
    Feb 25 2012
    Portland, OR
    Thanks.
    Active Member Two Rings OTDetailer's Avatar
    Oct 13 2011
    NNJ/LA
    Quote Originally Posted by Epa7 View Post
    So you will let the dealership detail your car? if you have not taken delivery of your A7 and you care for it very much, I HIGHLY recommend you to decline their detail. I work inside the dealership as a Tech FYI, so yes they do come all wrapped.
    Active Member Two Rings pokerfad's Avatar
    Feb 20 2012
    2012 A7 prestige 20" moonlight blue
    Swedesboro, NJ
    Quote Originally Posted by OTDetailer View Post
    I second this highly!!! I have a two month old A7 that was mangled by the dealer. I think they used a brush on it bc it had scratches, swirls all over. I just compounded, polished and wax it and it looks phenomenal now, but most dealers do not use proper care.
    current roster:
    2012 Q5 daytona grey 3.2L prem plus 20" sport pkg
    2012 A7 moonlight blue prestige innovation 20" sport pkg
    bye bye:
    2008 S5 prestige black (miss her!)
    Active Member Two Rings JoeyZ's Avatar
    Oct 10 2011
    If you have a heartbeat, they will let you "detail" a car.
    Active Member Four Rings maga4's Avatar
    Aug 12 2011
    Olathe, Kansas
    Good links, thank you.
    2011 A4 Premium+, Quattro, 6MT, 18" OEM 5-spokes, Nav, Black/Black
    APR Stage 2, Eurocode HFC/TIP/TRUFit Kit/HFIP, 35% Tint, Eibach Pro-Kit, Vag-Com, Gloss Black 3.2 Grille, Hoen Endurance Fogs, LED Interior/License Plate Lights, Strat Short Shifter, BFI Catch Can, Hardwired V1, Rieger Lip Replica, FRT's CXRacing FMIC, aFe Filter
    '91 Audi 90s Quattro, 5MT, White, Stock
    Jun 12 2008
    St. Louis
    I would definitely clay bar a new car on account of the rail dust it may be subjected to during shipping. It would take too long anyway since the finish is new IMO.
    http://wiki.answers.com/Q/What_is_a_clay_bar
    Feb 25 2012
    Portland, OR
    Quote Originally Posted by JoeyZ View Post
    I was wondering about that. These guys have a pretty good reputation. I need to stop by to have them appraise my possible trade in, so I'll ask to see examples of their work. Thanks again for the input.
    Veteran Member Four Rings VroomVroom's Avatar
    Jan 03 2007
    SF Bay Area, CA
    Definitely worth checking their work. I'm still cynical about this - even most premium-branded dealers still employ the dirty bucket & stiff brush method of new car prep. That said, yours may be the exception. My wife's favorite Lexus dealer, for example, contracts out with a small detail shop that keeps two of their detailers on-site. These guys do great work, but again...they're the exception. The problem is, most folks at dealerships, especially on the sales side, simply don't know any better. They think they're doing you a huge favor, and occasionally seem insulted that you'd turn down such services.
    In any case, a quality effort - or typical debacle - starts with how the wrap is removed. Caution and patience is key, and it's amazing how much micromarring is induced if either is skipped. If you're checking out their work, be sure to include this step. Good luck...
    -Jerry
    '12 Q5, 3.2L Premium Plus, S-Line Plus, MMI, Phantom/Black. VCDS & MMI Mod List
    (Formerly) '08 A4 Avant 3.2, '06 A4 Avant 3.2.
    Feb 25 2012
    Portland, OR
    Quote Originally Posted by VroomVroom View Post
    Great information! Thanks!
    Registered Member Four Rings Rodmar's Avatar
    Jan 29 2012
    None
    Colorado Springs
    Don't let the dealership wash it, and I reccomend a clay if you have an hour to burn while detailing it, new car but rail dust, etc... all over it or even overspray, who knows TBH, you will after you clay it and see what stuck to the clay. But im no professional
    BB DTM B7 A4/10% tint all around/Vortex splitters/Sonic Tuning LM Reps/Red painted Calipers/Hawk HPS Pads/Koni/Eibach Pro Kit/Kenwood DVD Headunit/REVO STG 1,Soon REVO stage 2/RAI DP/HFC/AWE Catback Exhaust/Show N' Go Plate holder/Ebay Mirror caps/Podi Mechanical Boost Gauge/Piston DV/1080 Carbon Fiber Wrapped Interior Trim/Krauto LED Interior Lights/B7 S4 Recaro seats/TTs flat bottom wheel/RS4 Pedals/S4 Door Blades/Drilled&Slotted Rotors/rs4 RSB
    Senior Member Four Rings NYSpeedRacer's Avatar
    Jun 21 2008
    '12 Audi K04 A5 | '13 VW JsW TDi | '08 Audi A4 2.0T
    NYC|ATX|RDU
    All wrapped up
    KW Suspensions are
    2012 Ipanema Brown A5
    20" BC HB-S02 | APR K04 v2 | Meth Stage III | APR CF Intake | AWE Quad Exhaust | Deval CF Rear Valance
    EuroCode ÜSS, Billet F &R Sway Links, Alu Kreuz, RotaMass, Intake Hose, HFC, Meisterwerk & FMIC
    SPC UCA |Sh*tty KW v3| 380mm StopTech Trophy | P3 Gauge | FBSW
    Build Thread | Instagram
    Veteran Member Four Rings FITZ TITS's Avatar
    Phila
    Wrong thread?
    Feb 25 2012
    Portland, OR
    Quote Originally Posted by NYSpeedRacer View Post
    All wrapped up
    Hmm, that's what I was thinking of when I was talking about partial wrapping. If that's the case, then the vertical panels of fenders and doors are exposed during transport?
    Senior Member Four Rings helix139's Avatar
    Apr 21 2010
    Florida
    Generally the entire car is wrapped during transport. +1 to the guys who said don't let the dealership "detail" your car. I had a friend that bought a BMW from my dealership a week before I took delivery and his paint was swirled and scratched to the point of needing wetsanding. Made me glad I told them not to touch mine other than to remove the exterior shipping materials. I took mine for a real new car prep detail and clearbra install the next morning after I took delivery.
    2011 S4 Premium Plus 6MT, Sepang Blue Pearl, Black Silk Nappa, Sport Diff, B&O, Nav, Ti Pkg
    Feb 25 2012
    Portland, OR
    Stopped by the dealer today for a close inspection of their prep. While I saw a few smudges and fingerprints, there were no swirls or holograms to be found. I wasn't able to actually watch them detail a car, but I'm going to trust them based on what I saw.
    Apr 21 2010
    Florida
    I wouldn't. Swirls and holograms can easily be covered up with a wax or sealant containing fillers. You wouldn't buy a new car from a detailer, so why would you get a detail from a dealership?
    Feb 25 2012
    Portland, OR
    Quote Originally Posted by helix139 View Post
    Yeah, I was wondering about wax/sealant covering things up, and while that's always a possibility, I saw consistently good finishes. What's the real downside? If there are swirls and holograms under wax/sealant, then when they reveal themselves I get the car detailed. The only downside I see is if there's irreperable damage done by the dealer, which is highly unlikely given the good appearance of cars awaiting delivery.
    Regardless I'll post my findings.
    Feb 20 2012
    Swedesboro, NJ
    My A7 was a great example of this. After each car wash I performed with the proper equipment I noticed more and more swirls and scratches appearing. I know they weren't coming from my washes. I just performed the correction on the car last weekend and it took me about 7 hours form start to finish and it looks great now, but if your spending 70k on a brand new car this should never happen. It baffles me how people that sell cars actually know nothing about car care. I thought that it was my dealer originally, but i bought my Q5 two weeks after the A7 from the same dealer and the Q5's clear coat is pristine. I have deduced that the A7 was mangled by the dealer that my dealership swapped inventory with to secure exactly what myself and my wife wanted. I have been meaning to tell my salesperson about this issue, but I just haven't done it yet. I would urge you to just opt out of it if you enjoy detailing your own vehicles. If you don't then take it to a professional and have a new car treatment done. It'll be beneficial in the long run.
    current roster:
    bye bye:
    Apr 21 2010
    Florida
    I just would not want to have to strip down the clearcoat on a brand new car. It happened on my buddy's 335i. The fillers in the waxes covered it up but the first time he washed with a pressure washer it was swirl city and it needed wetsanding. It was a real nightmare for him as subsequent washes revealed more and more blemishes and holgrams for the next several months afterwards. The dealership payed for the initial repair, but not the subsequent ones. The clearcoat damage he had was well over $1000. Lucky for him he is the web designer for the detailer we both use so the detailer took care of it for him with no out of pocket cost, but it's something I would not want to have had to deal with. There is no reason anyone should have to remove significant clearcoat on a brand new car.
    Feb 25 2012
    Portland, OR
    Pokerfad,
    Great feedback. Thanks. I'm just learning about detailing, swirls, etc., so not sure that I'm quite ready to tackle my first detailing on this car, and because it's early, I may not have time to practice on my other cars as I'd planned. While I can certainly opt out of the dealer prep, that means I need to get a detailer lined up immediately (or do it myself) upon delivery. I'm not sure I will have the time to do it myself or even get it to a shop within a week of delivery. What isn't clear is the benefit of opting out if I'm going to need to do a detail/correction anyway. Why not take the convenient way out and have the dealership do the prep? The worst case seems to be they put more swirls/holograms in which will get removed when I detail it the first time anyway.
    Again, thanks for all of the great information.
    Edit: While I was typing my response to Pokerfad, helix was answering my question about the worst case. $1k in damage to the clearcoat is definitely not good. Guess I'd underestimated the amount of damage that can be done with a hamfisted dealer prep
    Apr 21 2010
    Florida
    Pokerfad,
    If you don't have the time to get a detailer lined up right away, here's what I would do: Request the dealership not do the detail. If you decide to go with the clear bra installation, bring some blue painters tape with you for the ride home and tape up the front of your car. Set aside some time on the Saturday or Sunday after delivery to give it some quality care. Give it a quality wash with proper technique, then clay the car. Wipe it down with IPA to remove any residue. Then apply a quality sealant or wax by hand that will last at least until you can get it to a detailer. Reapply the painters tape until you can get to the clear bra installer. That way you'll at least have the car decontaminated and protected a little until you can give it some proper care from a pro.
