Results 1 to 19 of 19
    Active Member Two Rings fairbird's Avatar
    Jan 25 2010
    camaro ss , mazda 6
    Omaha
    any edvise will be apriciated (drag racing)
    Having troubles to transfer the power to the ground , spinning 1 st , 2 and some time 3rd gear , what rpm should I launch ?
    I can put slicks on the car ,my fear is to brake axles . my time is sucks , but the top speed 97 mph on 1/8 .
    Tial 770R
    Senior Member Four Rings Turbo Nerd's Avatar
    May 12 2009
    01 A4, 08 Charger R/T, 13 Jeep Altitude Edition, 01 F-150
    Detroit Metro Area
    Mods and suspension as well as tires?
    Built BAFT B5 Casa A4.
    Thanks to 034, IE, JHM, VAST, Ringer Racing and eBay.
    Instagram @MartyCac
    Jan 25 2010
    camaro ss , mazda 6
    Omaha
    tials 770 , clutch masters 725 , w/m injection , still running in the limp mode N75 off . working on file .
    Tial 770R
    Jan 25 2010
    camaro ss , mazda 6
    Omaha
    any body ?
    Tial 770R
    May 12 2009
    Detroit Metro Area
    What do you mean your running in limp mode? Are you saying running off wastegate pressure? I don't understand how you are spinning all the way through 3rd gear... In the video it looked like you barely spun 2nd if at all.
    Instagram @MartyCac
    Jan 25 2010
    camaro ss , mazda 6
    Omaha
    yes the N75 disconnected about the spinning it depends on what rpm I'm shifting , not all the runs on the video .
    Tial 770R
    Senior Member Four Rings Vinchenzo51's Avatar
    Jan 31 2010
    S-Line A6
    East Haven, CT
    What suspension and wheel/tire do you currently have?
    04 2.7T S-Line A6 6MT
    (Build Thread) <-Click
    (Featured Article) <-Click
    My Photo Gallery - MyPhotoStash.com <-Click
    Originally Posted by 8520
    You're in high school, and chipping a 2.7t is like poking the bear with a tazer.
    Jan 25 2010
    camaro ss , mazda 6
    Omaha
    Kw v3 , tires 225/40/18 , continental sport contact 3
    Jan 31 2010
    S-Line A6
    East Haven, CT
    Im not sure what you put down for power, but 770's might like some 17's on a more meaty drag radial. I understand if you don't want to run a slick to avoid breaking axels, but if you get your launch down, you will spin just enough to avoid bogging and still have good traction. Try some drag radials first, I ran NT05's on my Cobra and loved them.
    Active Member Three Rings MileMan402's Avatar
    Mar 14 2012
    2001 S4 & Camaro SS
    State College & Bethlehem
    Haha if you can't get traction with Quattro, good luck with the camaro.
    Jan 25 2010
    camaro ss , mazda 6
    Omaha
    I'm thinking to try some NITTO might be , or take the chance and put Hoosier on , I don't think on limp mode I can brake something .
    Tial 770R
    Jan 25 2010
    camaro ss , mazda 6
    Omaha
    I'll try next week , btw
    Tial 770R
    Mar 14 2012
    2001 S4 & Camaro SS
    Nice what were the numbers? Can't see them from my phone.
    Jan 25 2010
    camaro ss , mazda 6
    Omaha
    920 rwhp with 800 ft torque , on 87 pump gas with methanol .
    Tial 770R
    Active Member Two Rings lidoautogroup's Avatar
    Sep 11 2011
    Cleveland Ohio
    Ok, it seems as if only first gear is spinning which is normal. First things first, you have to find the sweet spot to launch for your specific setup. For me on K03s it was about 3500 to 3800 rpm, wheel spin is fairly normal with street tires in first gear. Don't think that the higher the launch rpm the better, it is the opposite at times. Also, get some solid engine and transmission mounts from 034 + JHM shift package trio, because it seems as if you are granny shifting, which makes up for a lot of time. When I go to the track, I lower my tire pressure to about 25 PSI or so depending on tires. What were your 60ft times?
    Jan 25 2010
    camaro ss , mazda 6
    Omaha
    I tried in range 3000-4000 rpm , I did forget lower the pressure in the tires and outside temp was about 60F , it wasn't hot enough for good traction , I do have 034 motor mounts , I do have some short shifter good speed or something like that , or you talking about linkage ? 60 ft about 1.9 , with 97 mph at the end .
    Tial 770R
    Sep 11 2011
    Cleveland Ohio
    Quote Originally Posted by fairbird View Post
    Get a real shifter like JHM. Hitting the gears right will make a world of difference in drag racing, I was beating on 11 second cars (1/4) at the 1/8th mile because of good launches on crappy tires (1.8 60") on K03s with a Giac chip. Of course this was done in 90 degree weather, so I may have had a little more traction and less lag than you.
    Jan 25 2010
    camaro ss , mazda 6
    Omaha
    Quote Originally Posted by lidoautogroup View Post
    My buddy was there with his S4 stage one he ran a lot slower then my car , by 1 second .
    Tial 770R
    Registered Member Three Rings martin0079's Avatar
    Mar 09 2011
    2001 Audi S4
    Plainfield, CT
    I think it is the tire width even in my A4 I could slide the car around with 225s on it. With 245s the car was rock solid. Get wider tires.
