Results 1 to 15 of 15
    Active Member Two Rings Sam091990's Avatar
    Dec 22 2011
    05 A4 1.8TQM
    Burbank, IL
    Test Pipe Question
    Does the test pipe replace the down pipe & catalytic converter or does it just replace the down pipe? Haven't had a chance to look underneath the car and check everything out, but how is our exhaust system setup? Is the down pipe and catalytic converter all one piece or two separate pieces?
    Whenever I search for test pipes it says it replaces the cat but when I search for a down pipe it says it connects to the cat.
    || Slow A4..
    Senior Member Four Rings Turbwhistle's Avatar
    Jan 02 2011
    A test pipe only replaces the CAT, something like a downpipe from 034 will bolt up to the turbo, and go to the flew pipe.(at the end of the oem downpipe)
    -Chris-
    PAST
    SILVER 1999 AUDI A4 AVANT 1.8TQM
    HIBISCUS 2000 AUDI S4 SEDAN 2.7 TQM
    NEW
    f250 -_-
    Flickr
    Senior Member Three Rings Abuck35's Avatar
    Sep 11 2009
    PA
    LOL. you answered your own question. Re-read your last sentence.
    turbo-> cat-> downpipe-> rest of system
    REVO2** AWE FMIC** Genesis 380's** Carbonio** ER tip** EVO MS DV** Magnaflow** gutted cat** N249 bypass**
    Stage 3 Forum Advertiser Four Rings Laszlo@034's Avatar
    Sep 17 2005
    Palo Alto, California
    For B5, B6, and B7 models, the downpipe and catalytic converter are separate pieces.
    The stock catalytic converter is a major restriction, and can be replaced by a Test Pipe or High-Flow Catalytic Converter, both of which bolt up to the stock downpipe.
    You can still replace the factory downpipe with a larger diameter one if desired.
    Jan 02 2011
    -Chris-
    PAST
    NEW
    f250 -_-
    Flickr
    Apr 01 2007
    2012 MazdaSpeed3
    houston texas
    The testpipe is also in the engine bay, not under the car, so good thing you didnt go poking around under there.
    DD - 2012 MazdaSpeed3
    2003 A4 1.8TQ
    APR stg2+, 240mm clutch, 12lbs flywheel, MTM injectors, Ecode FMIC, PSi testpipe, Techtonics Tuning downpipe, Hyperboost DV, B5S4 calipers, Goodridge SS lines, Stern snub, motor and transmission mounts, JHM shifted, Vogtland Jr. Cup Kit, RS4 Rear sway bar
    Jan 02 2011
    Here is a picture from when i did my exhaust. Cat with stock dp on it.
    -Chris-
    PAST
    NEW
    f250 -_-
    Flickr
    Dec 22 2011
    05 A4 1.8TQM
    Burbank, IL
    Thanks everyone.
    Sort of figured it was like that on mine, just wanted a clarification.
    || Slow A4..
    New Member One Ring
    Mar 20 2012
    chicago, il
    Don't mean to hi-jack, but do you need to be chipped to run a test pipe or a complete turbo back exhaust?
    Senior Member Three Rings customa4's Avatar
    Apr 07 2011
    92 Geo Prizm
    Quote Originally Posted by icemanj5 View Post
    No, you do not need to be chipped but you will probably get a cel if you get rid of the cat.
    New Member One Ring
    Mar 20 2012
    chicago, il
    Ok thanks!
    Senior Member Four Rings Staz's Avatar
    Jul 03 2010
    QUEENS, NY
    i haz one for sale if youre interested
    Dec 22 2011
    05 A4 1.8TQM
    Burbank, IL
    Quote Originally Posted by Staz View Post
    What do you have? I'm going to go with the high flow cat and down pipe, not a test pipe.
    || Slow A4..
    Apr 08 2009
    Connecticut
    Quote Originally Posted by Abuck35 View Post
    haha. i was saying the same thing.
    Quote Originally Posted by Sam091990 View Post
    No where in this logic does it say test pipe replaces down pipe. If it replaces the cat, then whatever bolts to the original cat now bolts to the test pipe including the down pipe. I'm glad you figured things out.. good luck OP.
    STOCK.. :-(
    Dec 22 2011
    05 A4 1.8TQM
    Burbank, IL
    Quote Originally Posted by dubgli View Post
    When I first started searching I thought the cat was welded to the down pipe. Therefore my search for test pipes and down pipes confused everything for me.
    Anyway, I had magnaflow mufflers installed the other day and although they have a nice deep tone, they aren't loud enough for my liking.
    || Slow A4..
