Results 1 to 16 of 16
    Active Member Two Rings ClutchMaster's Avatar
    Mar 01 2012
    1994 BMW 318i Convertible 5 Speed "Biddie"
    Samll Issue...Might be nothing at all.
    For the past few weeks or so and today it seemed the worse...Every time I turn the key and start my car it kicks over but when i turn it back to it's normal position it dies. Today it took me about 6 tries before it would stay running. I thought maybe it was the fuel pump but I hear it turning on. This may just be something stupid but I never had this issue before really...it's fine when the car is warm but when its cold it seems to not want to stay running. Any thoughts?
    Active Member Three Rings Johnny1.8T's Avatar
    Oct 26 2011
    '05 B6 1.8T 6- Speed Quattro. '89 BMW 325i (E30)
    Chicago Suburbs, IL
    when's the last time you've changed your fuel filter?
    Senior Member Three Rings ggcrash's Avatar
    Nov 25 2008
    Orlando, Fl.
    Might be the Crank Position Sensor, at least that 's what it was when I had those symptoms. Has your car shut off at a stoplight, by chance?...Also on a stretch, it might be the actual key ignition being faulty as well, that issue has cropped up a few times on this board.
    Mar 01 2012
    I look into those things...if it gets worse do you think it will throw a code?
    Active Member Three Rings foley803's Avatar
    Sep 29 2011
    is the outdoors
    San Antonio, TX
    It will eventually, but usually you can see it acting weird by streaming RPMs with vagcom its probably wise to take care of it before it gets that bad so you don't get stranded. If it just plain shuts off, then I would think its either crank pos sensor or ignition switch related, but if it sputters and gradually dies I would suspect a fuel(filter) issue.
    -Rich
    "Because magic, and science, and learning books" -Dan[FN]6262
    WTB: B6 sport steering wheel (grey) and clockspring.
    Mar 01 2012
    When I had my first coil pack issue I hooked my car up to the obd2 reader at our shop. We are a Body Shop so we really don't do mechanic work but we have a Matco Obd2 reader on hand. It stated that there was an old code in there and it read crank position sensor so maybe its been done before. I don't think its the fuel filter. I guess ill look around for a crank position sensor diy.
    Sep 29 2011
    is the outdoors
    San Antonio, TX
    That'll stream data right? Or is it just a code reader? You'll usually see the RPMs jump around a bit as you raise the revs.
    -Rich
    Mar 01 2012
    I'm looking at an old thread now and it says something about the cam position sensor. It says it wont crank if the crank postion sensor is bad but mine is cranking just wont stay running. Would this narrow it down to the cam position sensor?
    Sep 29 2011
    is the outdoors
    San Antonio, TX
    It'll crank, but it won't keep the fuel pump running unless it gets a signal from the CPS.
    -Rich
    Mar 01 2012
    Yeah it will stream data. So is it safe to say since I hear the fuel pump going on and it will start most of the time after 5 or 6 cranks that it is a bad cam position sensor?
    Nov 25 2008
    Orlando, Fl.
    Crank position, Cam position...I think its the same sensor, regardless, start there first. You might get lucky.
    Senior Member Four Rings Charles.waite's Avatar
    Jun 27 2011
    2004 A4 1.8TQ 6MT USP • 2006 A4 Avant 2.0T tip
    ^^ No no. They're very different. With different symptoms when they go bad.
    -CP
    2004 A4 1.8TQ 6MT USP - APR Stage 1 - FSI Coils - BKR7EIX-11 - 034 Silicon Breather - 034 Rear Swaybar (Soft Setting) and Solid Spherical Endlinks - B6S4 Front + B7A4 Rear Brake Setup - Failing Clutch Mod
    2008 Black Unicorn (2.0t S-Line Ti 6MT Avant) - BRK6EIX-11
    SOLD -- 2006 A4 2.0TQ Avant Tiptronic stocker - Failing TC Mod
    Nov 25 2008
    Orlando, Fl.
    I think YOU are talking about the "Cam Chain Tensioner" NOT the (cam position or crank position) sensor!
    Jun 27 2011
    -CP
    Nov 25 2008
    Orlando, Fl.
    I stand corrected Mr. Waite...I apologize. Well played sir!
    But check your "crank position sensor", I believe thats the cause.
    Jun 27 2011
    Quote Originally Posted by ggcrash View Post
    Haha! Yea sorry, I just didn't want to confuse the OP.
    -CP
