Three Rings
I'm torn.
Leave the mirrors and rails bright, or not?
B6 S4 Avant 6MT|| Brilliant Black|Silver
JHM 93 Tune|JHM LWCP|JHM Stg 3+LWFW|Full Piggies|2.5 Magnaflow
Apikol Snub+034 ZC Bracket|Apikol Diff|034 Trans|Stern Motor|034 Density CA
B5 spring perches|19 Matte Black VMR710|Ventus V12|Stoptech Pads+SS lines|AR track rotors
Black e-codes|20% Tint|Plasti-dip|Hydrographic CF print mirrors+roof rails+bumper trim
Three Rings
I'm thinking smoke Lamin-x on the headlights is a no-brainer.
Senior Member
Three Rings
I think you are so close to being fully blacked out you should go all black to complete the look, maybe plasti-dip so you can remove as you like.
Active Member
Two Rings
My vote would be to leave em silver, paint your door blades silver, get your silver rings back, and clear corner :)
But thats just me
Three Rings
But thats just me
re: the clear corner .. the thing is, I have maybe the only set of headlights in the known Audi universe that have never gotten any condensation inside them. I'm a little reluctant to break the seal open, lol.
Four Rings
I am right there with you on the condensation issue...or lack there of....
I personally am VERY anti tint on any lights....why decrease the performance of anything on you car for vanity?
I like the polished rails and mirrors, gives some contrast....as mentioned going back to chromed rings front and rear might help tie it together better.
Cheers,
Jim
Stage 2 Banner Advertiser
Four Rings
Black it out completely
Senior Member
Four Rings
total Knight-Rider would be pretty cool...but don't screw up the S4 mirrors doing it.
I have some extra mirror caps if you want to mess around. I'm picturing it all black, ...with ONLY the high beam reflector chrome.. .. hmmmm....
Three Rings
a good friend of mine opened up a high-end custom car shop... he talked about spraying the mirrors, rails, and cargo lip with clear that had some black mixed into it in order to create a translucent black. Would create sort of a "gunmetal" appearance but the brushed AL would still show through. Just tone down some of the brightwork while still making it distinguishable from the run-of-the-mill A4.
I'm thinking that one over.
If I do crack open the headlights, I'll clear corner mod them and paint everything inside the housing black except the high beam reflector, and then skip the lamin-x.
My opinion - leave the mirror caps silver no matter what. The rails, Id lean towards yes.
I think you should either peel that aluminum/silver piece on the rear bumper first. Thats really holding off on the blacked out look from the rear. Also, spray the s4 badge as well but try leaving the red flag, curious to see what that would look like.
Oh and clear corner those suckers!!
Senior Member
Three Rings
I would say leave the mirrors, "it's an S4 thing"
Black everything else out
Three Rings
the aluminum piece on the bumper is functionally the sill plate for the cargo floor.. plastidipping that is never ever going to last. It's one that would have to be painted with the tinted clear coat, because it needs to be pretty durable.
The s4 emblem, def going to black that out except for the red.
Four Rings
Three Rings
Four Rings
Senior Member
Three Rings
keep the side mirrors silver. get rid of s4.
Xbox ID: N Korean
save me if you play Call of Duty Black Ops 2 and Halo 4.
Senior Member
Three Rings
What did you black out your window trim with?
I have been debating doing the mine, due to annoying cloudiness.
Looks ok from a distant, but up close it looks like shit.
'05 S4 6mt- Jhm 93 tune, Jhm IM Spacers, H&R c/o's, 034 Density Motor & Trans mounts, Hotchkiss Sway Bars f&r, Apikol snub & R.Differential mounts, 034 snub bracket, Jhm LW rotors w/ Hawk HPS, K&N, Piggies, FI Catback w/ 8" resonators, S.S. brake lines, 034 Density strut mounts, 034 MAF Hose, 034 adj. endlinks, RNSE, JHM Solid ss.
Active Member
Three Rings
Black it out all the way. You're so close you might as well go all out.
I have Lamin-x on my headlights and am VERY happy with it. Its the lightest level of tint and it has very little effect on light output. Very thick and durable. Makes your lenses look like brand new as well.
2005.5 S4 MT - Apikol snub mount // Apikol rear diff mount // Stern tranny mount // JHM Tune // JHM Intake Manifold and Spacers // JHM "Solid" SS // JHM Stage III Clutch and LWFW // Trex DPs // Fast Intentions 2.5" X-Pipe Cat Back w/ 14" Resonators // PSS9 Coilovers // 034 Rear Sway // 40% 3M tint // Lamin-X "tint" headlights and "gunsmoke" taillights // 19" MRR GT1 summers // 18" VMR V710 winters
Three Rings
It was your car that convinced me to do the Lamin-x tint.
Trim was blacked out using Plasti-dip. Took a few tries to get it perfect.. Was a lot more labor-intensive than expected, honestly.
silver stands out too much IMO, if you had more silver accents you might be ale to play it off nicely but the car is basicly all black. I say black the mirrors.
I would kinda lean towards putting the rings back on. I hte black emblems on a black car, looks like someone peeled your rings off and left the grill naked imo. Other than that i love your avant, looks really nice.
Registered Member
Two Rings
To close, you either have to go full on Bruce Wayne, or bring back some more brightwork to even it out.
'05 (B6) Audi s4 | '97 Land Rover Disco XD
Semper...
Active Member
Two Rings
 Originally Posted by crabpot
So hot...
2008 Brilliant Black S4 DTM, JHM 93 Tune, Piggied DP's, FI Resonated Catback. More to come hopefully.
Senior Member
Three Rings
Yeah, either go all in on blacking the stuff out, or find the perfect balance. I'd say do the mirrors black, and see if you like it. If not, go back to the aluminum and balance the car out.
Active Member
Two Rings
You could probably wrap them all up in bin bags and insulation tape to see what it looks like.
I'd do the rails and see what it looks like with the mirrors as they are.
I would suggest painting all the badges darkish grey. Either that or remove the S4 badge; if you leave the red it'll look like an S-line A4.
Audi S4 Avant (B6, 2004) in Goodwood Green. V8, motherhubbards!!
Registered Member
Two Rings
Active Member
Two Rings
Not a fan of ALL black cars. I'd put some sort of brushed aluminum trim on the front grille or just use the chrome rings again to add some definition and character to the look. Def leave the mirrors, gotta leave some stuff on it that's S4'ish. Otherwise it's tight.
Three Rings
So I have a buddy that does high end vinyl wrap jobs.. did a complete wrap on a 996tt of another friend of ours. I'm going to have him wrap the roof rails and mirrors with a carbon fiber wrap. Tempted to take the plasti-dip back off the chrome around the windows and do that in the cf pattern as well, or I may just have him wrap the chrome around the windows with flat black. I like the plasti-dip but am concerned about its' durability on the window trim.
Active Member
Three Rings
^^Sounds cool. Keep the window trim black though. I'll be interested to see the results.
Three Rings
yeah the more I thought about it, the more I realized cf window trim would look terrible. I think I will probably go ahead and have him do it in flat black vinyl though.
Senior Member
Two Rings
But thats just me
that
2005 S4 Avant 6MT
Current: O.Z. Superturismo LM Wheels / K&W Sport Springs / Koni Yellows / OEM Titanium Grills / Blacked Out Trim / RNS-E / Ipod Interface / 20% Tint
Summer '12: JHM Downpipes / FI Catback / JHM 91 Tune
Active Member
Three Rings
Surprised nobody has said "HAY UR VALENCE IS GRAY LOLOL"
Cause....it is.
I'd black that out (or CF wrap it), and leave the mirrors/rails silver. And put the silver rings back on front and rear.
My $.02
2005 Nogaro B6 S4 | CF Trim | JHM Tune | Piggies | Magnaflow RS4 Catback | Apikol Snub, Rear Diff. Mount | 034 UCAs, Trans. Mount | K&N Drop-in/Airbox mod | Yellow Fogs
If it wasn't for bad luck, I'd have no luck at all...
Active Member
Three Rings
^^Nice catch. The rear valence CF wrapped would look damn good. It would help complete the theme of the car.
Three Rings
Cause....it is.
My $.02
crap.. you guys are right.
So I'm thinking Plasti-dip the rear valance and S4 badge, CF wrap the rear cargo sill plate, mirrors and roof rails.
I may some day put the silver rings back on, but right now I'm feeling like I don't want any chrome on the car anywhere.
Senior Member
Three Rings
Car looks great! I think the black on black on black looks good, but is getting old. I like the little bit of silver you got now. Keep it how it is, but CF wrap rear valance, and yellow lamin-x on the headlights.
Four Rings
Blacked out isn't my thing, but if you're doing it ... do it all the way.
Three Rings
damn you crabby that song has been stuck in my head for DAYS now
Four Rings
im surprised no one has the photoshop skill to draft that up real quick... one with the smoke shade on everything, one completely blacked out... why guess?
Active Member
Three Rings
Any idea how plastidip holds up to heat? I trimmed my valence to make room for quad tips, and wanted to black out the grill and valence section, but I didnt know if the heat from the tips would bubble/burn the rubber-paint-chemicals-stuff.
Any idea?
Three Rings
I have the ability just not the time, lol.
However my proficiency with Photoshop is, um, not good. I can get it done but it's similar to digging a ditch with a shovel when most people would use a backhoe.
- You may not post replies
- You may not edit your posts
Forum Rules
