Active Member
Three Rings
Headers?
I was looking around and i it seems like JHM are the only people that make headers. It this true? In the future i would love to get Intake, intake manifold, Headers, and exhause and chip/tune. Basically a bunch of nice bolt ons.
Even if other companies made headers I would stick with JHM. Go with the JHM headers, you wont be dissapointed. They really require an engine pull though...you know that right?
Do some reading on the intakes - they are pretty much proven worthless on our cars.
Four Rings
Intake spacers or cold air intake? I'm aware that the CAIs are worthless since the current air boxes do the same magical trick.
Marine Driven. Marine Approved.
The police are just regular dickheads like you and me...anyone ever met Slow? - $4C@BS <3
2005 DG B6 S4 Avant - JHM Tuned | JHM Intake Spacers | Fast Intentions CB | Catless 2.5" Milltek DPs
2001 Silver B5 S4 - APR Tuned | ASP TruDual CB | 2.5" Full Catless Techtonic DPs | Forever In Memory
Active Member
Three Rings
LOL at slow4 magical trick. No i had no idea i needed a pull for headers. Honestly if/when i do my bolt-ons ill do them all at once. Thanks for the info on the intake though.
BTW only being in the Audi community for a week and i already realize that JHM seems to be qaulity stuff. Im coming from F-bodys (camaros) and everyone and thier mother made headers and exhaust systems. thats why i asked. I found it a little odd that only one company seems to make headers.
Senior Member
Three Rings
do intake manifold, intake spacer, 034 MAF boot to stock air box with a K/N filter
2006 Audi S4 Brilliant Red 6-spd (neutered)
Thats why I mentioned it. If you want the sound and performance of headers without pulling your engine, look into going with a full2.5" catless system. Thats as close as youre going to get.
Slow4, I was referring to "cold" air intakes. They have shown no to very little increases in power, and possibly even decreases...how embarrassing is that lol.
OP, stick with OEM, or a drop in KN filter if you really feel the need to mess with it. Intake spacers are a whole different story though, those are worth it.
[/QUOTE]
Im coming from F-bodys (camaros) and everyone and thier mother made headers and exhaust systems. thats why i asked. I found it a little odd that only one company seems to make headers.[/QUOTE]
This is a different animal altogether...forget the easy bolt ons and finding parts at Autozone days...
OP, not a prob. Its a learning experience.
You will soon realize how kind Audi engineers were to us in their choice of placement for bolts, sensors, and screws.
Four Rings
Oh I am in total agreement with CAI, I remember reading that they make NO significant gains HP wise. I believe there has been a study (unofficial) that proves this and if anything, they slightly increase throttle response.
My DarinINTAKE mod for the B5 S4 increased my throttle slightly, at least that's what I observed/felt.
Are the drop-in K/N filters lightly oiled? I bought one and read/heard it causes issues with the B5 hitachi and bosch MAFs so I removed it. I'm not sure if that's the same on the B6/B7.
Senior Member
Three Rings
This is a different animal altogether...forget the easy bolt ons and finding parts at Autozone days...[/QUOTE]
Ya if the 4.2l was in as many cars as the LT or LS series engine we would be set. You can grab a set of long tubes for less than freakin $200!!
You my friend have moved on to a much different beast, but my F-body friends envy the sound of a high revving 40V V8!
I believe they come lightly oiled when they are new. Some say that the oil ruins the MAF in our cars but I would imagine you would have to drench the filter in oil for that to happen. I just stuck with an OEM Mahle filter, I believe it is.
Four Rings
To answer OPs question, there are other companies out there that do manufacture/fabricate headers for our 4.2s but as of current, I think JHM has been the one to put one use.
Check APR, AWE, Vast or SummitTuning to see if they carry them. I believe AWE might stock some.
Senior Member
Three Rings
They do some pre oiled, and when you clean and oil it, lightly coat the filter. Also, make sure you give the oil a little time to dry and soak in....and the oil goes on the outside of the filter, not the inside or both sides
Senior Member
Three Rings
JHM makes the only headers, and don't quote me on this, but Vast may have been the company that they had reproducing them......and yes anyone can fabricate headers, but the R&D that JHM put into them is way more than any other company every will. Have you ever looked in your engine bay? Imagine the amount of work that went into fab work on long tubes for our cars with the amount of space, then take into account all the other design parameters for making efficient headers.
I am hoping to go faster than 12.7 all motor without headers.
Senior Member
Four Rings
even if someone else ends up making headers, the JHM ones would be the ARH equivalent and will make more power/torque
Active Member
Three Rings
Thanks for all the input. what exactly is an intake spacer and why so much of a significant mod?
Four Rings
From what I read, it helps the engine keep cool while adding torque to the low-to-medium RPM range.
http://www.audizine.com/forum/showth...e-power-(NEW!)
Senior Member
Three Rings
The JHM headers are not JHM, they are Fast Intentions. JHM developed them and sells them. My question is: there have been a lot of these made so why are they still welding them? Why not mandrel bend? The cost should go down significantly because a welding artist will not have to spend hours creating one set. And they would flow better due to smooth insides not a bunch of seams. I have seen some crazy bends with a mandrel machine so I know it can easily be reproduced.
Senior Member
Four Rings
the JHM headers actually used to be built in michigan but that may be changing. I believe the prebent sections are in part used because some of the compound bends are too complex for a mandrel bending machine
Four Rings
Nice basic bolt on mods :
- intake manifold
- Aftermarket drop in filter
- 2.5" downpipes
- 2.5" catback
- JHM Tune
SRT8 Jeep / Custom exhaust w/ X pipe / Catch can / AFE intake / Diablo Intune/ 275's & 315's
Active Member
Three Rings
I agree thats why i was surprised only one company makes them and the price is steep. However going to a business school you know that if you in a market by yourself you can set a price for people to pay. If they got some competition you can bet your ass the price would drop to probably somewhere around 2,000.
Three Rings
They actually don't make as much of a profit as you think. The thick laser cut flanges + the high quality steel are all expensive. IIRC each set uses over a dozen jigs to create and many many hours of welding.
A few mods here and there
Senior Member
Three Rings
Everyone thinks R&D is free too, you couldn't even get a custom set made for that, unless you are an amazing fabricator yourself. Even if you were it would be a lot of man hours!
Senior Member
Three Rings
This is exactly what I am talking about. Mandrel bend these things! All those jig set-ups plus the talented welder = fucking expensive.
The material is not that expensive. Like someone stated earlier, the F-body cars have a lot of header options and the best header makers use the same material, thick flanges, and quality collectors for 1/4 of the JHM/FI price.
example: http://www.summitracing.com/parts/KOK-6022/?rtype=10 for less than $800 you get top quality and look at those bends!
Senior Member
Four Rings
1-5/8" 16G 304 (like those headers) is $13.22/ft
1-1/2" 16G 321 (like the JHM headers) is normally $29.95/ft
prices from burns stainless llc
the material cost of building the headers in all 321 is significantly higher than 304. The JHM headers also include a new hardware kit and intermediate pipes.
Three Rings
Yup. When I spoke to the person who designed the headers he told me he had the motor in and out well over 100 times just testing fitment! 99% of people don't realize that there's way more that goes into designing proper headers than just runner length. If any other company starts producing headers I'd be completely skeptical if they had even a fraction of the R&D that JHM's headers have behind them.
This.
JHM has the header game in the bag. Pretty much the only headers for our cars that are tried and true with no issues. Id be wary at the least if another company came out with them.
Senior Member
Three Rings
Wasn't there a post about some custom Kooks S4 headers? I'll check real quick.
edit: just checked. not Kooks headers, it was a custom catback from Kooks for an RS4
Active Member
Three Rings
i understand R&D. I father has a custom built WS-6 Firebird and made alot of his own stuff. He made a sweet ram air intake that cost him almost 1500 bucks to make. Now he could reproduce it for like 200 to 250 and sell for probably 350-399. Eventually he would make profit. All i was getting at is once you create that one that works, reproducing is easier. As S4 artillery said, use mandrel bends and try to mass reproduce for less cost. Anyways i do appreciate all the info and good talks going on in here!
Four Rings
^When you see them in person you'll understand. As beem said, the bends are very complex, and the area is extremely tight. There's a reason years went by without anyone even trying, and only one company has even produced a set. At the end of the day, JMH didn't just make 1 set and say that works best. The multitude of factors and combinations they considered means it's the only one I would consider for headers, and frankly, the only reason they built them (imo) is to fulfill their entire picture and to meet their big power needs down the road.
2005.5 S4 MT6 l JHM Parts: Stg 1 Supercharger, Long Tube Headers, IM, SS Trio, LW Front Rotors, LWFW, Stg IV clutch, 4:1 Diff, Stern Motor Mounts, Snub/Trans/Diff Mounts, F.I. Res B6 Exhaust, Pedals &Weighted Shifter l H&R C.O. 24.75" G-F, 034 Adj UCA's, H-Sport RS4 Rear Sway l Hawk HPS Pads, SS lines & SuperBlue l Fly'sV4 LEDs l 15% Tint, 50% Front l VMR V710 GM 19" & Enkie RPF01's l JL 10W7, Focal Components l V1 Mirror Display l
Registered Member
Four Rings
You have a point, but you should realize, the technology of modern CNC benders is impressive. It can do any free-form shape, not just simple mandrel bends. It is also, as far as this is concerned, perfectly repeatable and requires no special setup. Granted a machine like that is very very expensive, however the point is it could be done if they wanted to. I am guessing they are happy where they are currently with the manufacturing and see no reason to change.
Just a quick search turned up this bending the proper size tubing for the exhaust:
http://www.youtube.com/watch?v=ot0Cxmk2aa4
Is it economical? Who knows, but it is pretty damn cool and looks like it would make short work of the bends on the headers.
2008 Audi RS4 Ibis White w/ Ti Package | 18x10 TE37 w/ 275/35 StarSpec | PSI Raceline Ohlins | Gyrodisc Rotors F&R | Apikol Diff Mount | 034 Billet Subframe Bushings | 034 Track Trans Mount | 034 Spherical UCA | 034 Front Endlinks | JHM LWFW&Stage 4 Clutch | JHM Shifter+Linkage | Custom CAI | Stern Motor Mounts | Hotchkis Sways F&R | EBW Rear Endlinks | EBW LW Battery | Euro Bumper/Headlights | 50% Tint
355WHP 298WTQ on stock tune/91Oct
Senior Member
Three Rings
I didn't realize the material is 321 SS. But do they have to use 321? 304 is more than adequate for the application.
Exactly!
Honestly, all it would take is some dishonest character to get their hands on a set of headers and model it to be reproduced on a CNC mandrel machine, use 304 steel, and sell the completed copy for half price. Or JHM could do the same and everybody wins. The sound of header equipped Audis will dominate the streets.
Registered Member
Four Rings
Exactly!
I would be shocked if those XS Power headers are anything different.
Registered Member
Four Rings
I am kind of curious why they chose such an expensive material. I guess do it once and do it right, but I think 321 is a little excessive for NA engine headers. I know it is used on turbo applications due to high EGT. 321SS is optimized for operation between 800-1500F, I don't think the exhaust gas temps from an S4 get anywhere near that temp, I could be wrong though.
Senior Member
Four Rings
lol, I wouldnt bet against that..
Senior Member
Four Rings
I think there was concern over cracking at the welds given the length/weight of the headers. So I gather they decided to use 321 to mitigate issues with precipitation at the welds.
Senior Member
Four Rings
I've seen this video before, very cool to watch however I see one problem when thinking about it for our header application: "Nissin 3D bender that can bend up to 1-1/4" O.D." Those would be some tiny headers. I'm sure there are probably other machines out there that can do a diameter that would work but I would imagine getting a set done on those would cost the same or more than the JHM headers unless you were ordering a ton all at once.
I'd imagine the problem with having them mandrel bent is much like Beem and mbgt72 have said, the area is might me too tight or complex to be done from a mandrel bender. Or maybe they were worried also worried about strength. The first thing I read when looking up mandrel bending was "the bend may appear stronger the outer wall of the tube is actually stretched thinner by the mandrel bending process". I doubt it would really do much to change the strength of the pipes, but with all of those things together, having them welded probably was just the best/most reasonable way to go for this application
Active Member
Two Rings
Exactly, I think its payback from the war.
As others have said, go for catless dp and full 2.5" exhaust system. Will save you a bunch of cash and you'll still pick up some nice gains and the sound is great. I definitely recommend Fast Intentions. Danny at FI is a great guy to do business with.
Senior Member
Four Rings
From a business perspective, even if mandrel bending them might be cheaper IF (as mentioned above) they were mass produced and therefore lowered the unit price, installing them requires an engine pull. Even if they were 1/3 of the price or even 1/2 price from what they are today, how many would actually buy them and install them. I doubt they would be able to sell a huge inventory (if mass produced) to make a profit within a reasonable amount of time. That would mean having them sit in inventory for a long period of time which in itself has a large associated cost (tied up capital, storage, etc.)
I'm going to assume they've done the math from a business model stand-point and felt it just wasn't realistic/profitable/justified.
Sprint Blue B7 S4 Avant 6MT - 421whp/350wtq
JHM Stage 1 Supercharger - Stern Motor mounts - JHM IM - JHM Stage 4 clutch - JHM LWFW - Stoptech ST-60 BBK - KW v3 Coilovers - Apikol Rear Diff Mount - JHM "Trio" shifter - Trexturk DP - Magnaflow CB - Hotchkis 29mm RSB - JHM Intake Spacers - TT-RS MFSW - 034 Adj. FUCA - RS4 Pedals - Zada Tech Gauges - STE Gauges - Dynavin D99 Android
Senior Member
Four Rings
^thats a good point too, the market is tiny and building the cad program to bend the pipes would make their r&d dollars even higher. plus the cost of contracting out the bending, it may make very little sense to take that next step forward.
JHM's old fabricator for the headers was suprisingly efficient and fast, he and I worked side by side on my car for an extended weekend and I was always impressed by his perfectionism and speed at the time.
- You may not post replies
- You may not edit your posts
Forum Rules
