Results 1 to 16 of 16
Thread: HID's
    Active Member Two Rings BmegaS4's Avatar
    May 19 2011
    Leesburg VA
    HID's
    So the stock passenger side headlight is dimmer(almost pink) than the driver side. What does this mean and what can I do?
    2008 A6 3.2 S-line, stock
    2001.5 S4 Avant, Tip, APR Stage 2, Evolution Raceworks Intercoolers, 710N's, 33k miles!
    Veteran Member Three Rings miggity02's Avatar
    Mar 22 2008
    B5, 8P A3
    East Bay, Nor Cal
    It means it's time to change both your bulbs. You want to replace in pairs to keep the colors the same.
    B6 1.8t Quattro sedan - SOLD
    B5 2.8l Avant 5mt quattro - Sport Package - JHM short shifter - K&N - Magnaflow - STs - Yak rack - 2500k fogs and highs - OEM USPs
    2007 8P 2.0t - 6MT - S-line - Sport Package- Premium Package - Nav - (tinted)Open Sky - Cold Weather - Bose - REVO STG 2 (7-2-9) - AWE turboback - AFE Pro Dry - H&R sport cup kit - Eibach RSB - BFI torque mount - OZ Ultraleggera - 12mm spacers - Thule
    Registered Member Three Rings HaVoKTheJoker's Avatar
    Dec 11 2010
    New Jersey
    replace your bulb. Bulb is a D2S
    TEAM A.C.E. NJ
    May 19 2011
    Leesburg VA
    Sweet, thanks for the quick replys. I'll order two tomorrow. Any place you guys recommend?
    Active Member Three Rings jeffrey146's Avatar
    Feb 19 2012
    04 s4 noggy avant MT 98 A4 2.8LQM 30V 207K 98 A6 2.8LQA 30V 118K
    Ogden, ut
    Bulb is about to go out. Buy a pair ASAP.
    Noggy S4 Avant MT B6
    Miro 111s, DRS extreme contact, AudiUp 10mm front 15mm rear spacers, 034 rear sway (soft setting till I get new end links), APR DPS exhaust and tune, H&R springs, Morimoto mini H1 Bixenon retrofit (4300k), clear corner mod & APR tune.
    May 19 2011
    Leesburg VA
    Just found then on HIDoutlet.net for 24$ for the pair? What color should I get?
    May 19 2011
    Leesburg VA
    Also, how hard is it to replace the bulb? I have replaced plenty of halogen bulbs but never an HID.
    Senior Member Four Rings Timtheguru's Avatar
    Dec 30 2009
    You just have to remove the headlight housings, changing the bulb is easier than removing the headlight housings. Be sure to note which way the notches lined up when removing the old bulb. Be sure to get 4300k bulbs for the best light output.
    May 19 2011
    Leesburg VA
    So I dont need to do anything with the ballasts?
    Active Member Two Rings hutchb2's Avatar
    Sep 25 2011
    N/A
    It's also possible that the reflective coating on the focal piece the bulb sits in has been burnt. If a new bulb doesn't change the color, I'd say that's your culprit.
    Veteran Member Four Rings 00SantorinS4's Avatar
    Oct 02 2006
    So. Maine
    Has anyone used the DDM D2S 5000k to replace the stock bulbs? How do they look/hold up?
    2001 Audi S4 2.7TQM ** Brilliant Black - Silicone Hoses|APR Snub Mount|710Ns|//J-Fonz Tuned|AWE Gauge|AWE S-Flo|Darintake|H&R Sports
    Senior Member Three Rings omgwtfbbq!'s Avatar
    Jul 08 2009
    Daytona Beach, Fl
    I picked up a D2S from NAPA for $75, it works but I have $15 H7 DDM bulbs in my HID fogs and they work too. The DDM bulbs don't last as long But when I can replace a pair 4 times before reaching the price of a single bulb available locally (they're the only ones available here) I don't mind using the cheapo chinese crap.
    01 Sedan /// Brilliant Black ///F4H Frankenturbos w/ tubular manifolds /// J-Fonz stage 3- /// Borla 3" /// Darintake
    I hate: FMICs, flat colors, A-pillar gauge pods, vented hoods, drilled brake rotors, SSAC products, Rotas, you
    Senior Member Two Rings s4vagguy's Avatar
    Feb 19 2011
    1949 Ford F1
    anyone have an idea how much oem bulbs go for? i really dont want to chance it with aftermarket products really enjoy the stock quality
    Dec 30 2009
    By far the best bulbs I've had, 2 sets have lasted me 5 years, even with removing and messing with the headlight configurations. (2 sets because I work on 2 S4s)
    http://www.ebay.com/itm/PHILIPS-4300...ht_1616wt_1397
    2001.5 S4 Sedan
    2002 A4 Avant 1.8t
    Dec 11 2010
    New Jersey
    i have 8000k bulbs and they look great and light up well. I have H7 8000k for the fogs..and they when both are on it lights up the block
    TEAM A.C.E. NJ
    Senior Member Four Rings S4 00 2.7's Avatar
    May 13 2011
    Quote Originally Posted by Timtheguru View Post
    Thanks. I may order some soon.
