Active Member
Two Rings
HID's
So the stock passenger side headlight is dimmer(almost pink) than the driver side. What does this mean and what can I do?
2008 A6 3.2 S-line, stock
2001.5 S4 Avant, Tip, APR Stage 2, Evolution Raceworks Intercoolers, 710N's, 33k miles!
Three Rings
It means it's time to change both your bulbs. You want to replace in pairs to keep the colors the same.
B6 1.8t Quattro sedan - SOLD
B5 2.8l Avant 5mt quattro - Sport Package - JHM short shifter - K&N - Magnaflow - STs - Yak rack - 2500k fogs and highs - OEM USPs
2007 8P 2.0t - 6MT - S-line - Sport Package- Premium Package - Nav - (tinted)Open Sky - Cold Weather - Bose - REVO STG 2 (7-2-9) - AWE turboback - AFE Pro Dry - H&R sport cup kit - Eibach RSB - BFI torque mount - OZ Ultraleggera - 12mm spacers - Thule
Registered Member
Three Rings
replace your bulb. Bulb is a D2S
Active Member
Two Rings
Just found then on HIDoutlet.net for 24$ for the pair? What color should I get?
Active Member
Two Rings
Sweet, thanks for the quick replys. I'll order two tomorrow. Any place you guys recommend?
Active Member
Three Rings
Bulb is about to go out. Buy a pair ASAP.
 Noggy S4 Avant MT B6
Miro 111s 9.5" 18" et 35, DRS extreme contact, AudiUp 10mm front 15mm rear spacers, 034 rear sway (soft setting till I get new end links), APR DPS exhaust and tune, H&R springs, Morimoto mini H1 Bixenon retrofit (4300k) in hylix housings & APR tune.
Active Member
Two Rings
Also, how hard is it to replace the bulb? I have replaced plenty of halogen bulbs but never an HID.
Senior Member
Four Rings
You just have to remove the headlight housings, changing the bulb is easier than removing the headlight housings. Be sure to note which way the notches lined up when removing the old bulb. Be sure to get 4300k bulbs for the best light output.
Active Member
Two Rings
So I dont need to do anything with the ballasts?
Active Member
Two Rings
It's also possible that the reflective coating on the focal piece the bulb sits in has been burnt. If a new bulb doesn't change the color, I'd say that's your culprit.
Four Rings
Has anyone used the DDM D2S 5000k to replace the stock bulbs? How do they look/hold up?
2001 Audi S4 2.7TQM ** Brilliant Black - Silicone Hoses|APR Snub Mount|710Ns|//J-Fonz Tuned|AWE Gauge|AWE S-Flo|Darintake|H&R Sports
Senior Member
Three Rings
I picked up a D2S from NAPA for $75, it works but I have $15 H7 DDM bulbs in my HID fogs and they work too. The DDM bulbs don't last as long But when I can replace a pair 4 times before reaching the price of a single bulb available locally (they're the only ones available here) I don't mind using the cheapo chinese crap.
01 Sedan /// Brilliant Black ///F4H Frankenturbos w/ tubular manifolds /// J-Fonz stage 3- /// Borla 3" /// Darintake
I hate: FMICs, flat colors, A-pillar gauge pods, vented hoods, drilled brake rotors, SSAC products, Rotas, you
Senior Member
Two Rings
anyone have an idea how much oem bulbs go for? i really dont want to chance it with aftermarket products really enjoy the stock quality
Senior Member
Four Rings
By far the best bulbs I've had, 2 sets have lasted me 5 years, even with removing and messing with the headlight configurations. (2 sets because I work on 2 S4s)
http://www.ebay.com/itm/PHILIPS-4300...ht_1616wt_1397
2001.5 S4 Sedan
2002 A4 Avant 1.8t
Registered Member
Three Rings
i have 8000k bulbs and they look great and light up well. I have H7 8000k for the fogs..and they when both are on it lights up the block
Senior Member
Four Rings
 Originally Posted by Timtheguru
Thanks. I may order some soon.
- You may not post replies
- You may not edit your posts
Forum Rules
