I am the seller. Loads of pictures in the craigslist posting, but i can't figure out an easy way to convert the html to forum text easily (gr)
http://portland.craigslist.org/grg/pts/2934843312.html
Description from ad below:
Most of the parts you'll need to put a big turbo onto your a4 b5 1.8t quattro excluding upgrading the exhaust (not required but suggested).
Should fit 1997-2001
Parts are new unless otherwise noted. They were set up as a mock up on my car. Then i chose to go a different route - and sold the car. You can see current condition of the parts in the pictures i have posted.
Parts are new unless otherwise noted. Save at least 800 dollars from new cost.
This would include (prices as current 'new' cost)
$1595 **** gt28rs eliminator (elim) turbo (bolts to stock exhaust manifold/cat) from here: from here http://www.atpturbo.com/mm5/merchant...ory_Code=VVWTK
$140 **** High flow stock-placement exhaust manifold - drilled for EGT, slotted like stock to keep from cracking - a generic version of this from same casting: http://www.atpturbo.com/mm5/merchant...gory_Code=VVWM purchased from ebay http://www.ebay.com/itm/vw-passat-au...ht_3367wt_1042
$225 **** High flow Turbo Inlet Pipe Evolution Racewerks - in black, with silicone hose for 3" maf - from here: http://www.evolutionracewerks.com/node/64
$150 **** Forge turbo wastegate actuator **** Similar to but slightly different than http://www.avenueautosport.com/Forge...K03_p_109.html
$30 **** Forge actuator spring set http://www.forgemotorsport.com/conte...oduct=FMPACTUN
$121 + 2x $47 **** Westach Dual Intercooler Gauge with two sensors **** http://www.westach.com/products/DUAL...TURE/index.php
Used audi TT 3 inch MAF
Used stock A4 intercooler with intercooler gauge sensors wired into it
adapter plate from turbo to stock turbo inlet pipe
adapter plate from turbo to high flow turbo inlet pipe (larger)
Used Oil Drain Pipe - mounting holes drilled to fit larger studs on elim turbo without having the stepped studs the kit came with
Used Oil Feed Pipe - waiting to be modified with tube nut and a/n fittings for turbo
Oil restrictor for A/N fitting - to limit oil flow for the ball bearing turbo
A/N tube nut, hose, and fittings - to adapt oil pipe to turbo
Used Turbo to intercooler hose, modified to fit onto elim turbo
Used/New mixture Extra coolant lines
Think that's it.
Asking 1300 or best offer. Prefer pick-up that shipping
