Results 1 to 7 of 7
    Mar 09 2012
    2008 Chevy suburban, 76 Lincoln mark IV
    Latrobe
    Do bigger rims after speedometer
    Do bigger rims but tires that are the same diameter affect the speedometer? If I go from 17x8 rims and 225 45 17 tires to 18x8 225 40 18 tires, will it screw up my speedometer
    Senior Member Four Rings moyenecorniche's Avatar
    May 22 2010
    10 prs of SL & GS Skis, MTB's, Rd Bikes, 04 Ford FX4 Ranger
    N.E. Connecticut
    No it's called a +1...I suggest going to Tirerack webs and looking up their definition and specs on wheel and tire upgrades to larger wider...
    Search A-zine wiki and the tech sections, should find just about any answer to most questions...
    Welcome Aboard....
    Active Member Two Rings Dad A3's Avatar
    Dec 24 2011
    2006 Audi A3, 2008 Jetta 2.0T, 2008 Taureg, 86 VFR 750
    Sound advice, bought my tires 9mounted and balanced) from tire rack.
    Welcome aboard.
    Active Member Three Rings
    Feb 02 2011
    India
    Wheels*
    New Member One Ring
    Mar 12 2012
    chattanooga tn
    Quote Originally Posted by A3mikeA3 View Post
    The change in speedo vs actual will be determined by one and only one thing. The circumference of the new tires (not wheels) vs the original tires. So check the circumference in the spec sheet of your old and new tires and that is what matters. It may only give the diameter so you will have to use the conversion between diameter and circumference which is pi x diameter 3.141 is pi
    Senior Member Two Rings JRutter's Avatar
    Nov 20 2009
    A3 3.2 and A4 2.0
    NW WA
    http://www.1010tires.com/TireSizeCalculator.asp
    The A3 speedo reads a little high anyway...
    still no turbo - other mods here
    Jun 15 2009
    Quote Originally Posted by rotts4u View Post
    The speedo will also be affected by tire pressure. Extremely low pressure will decrease its circumference, thus making you think you are going faster.
