Results 1 to 2 of 2
    Feb 07 2008
    00 stg 3 6mt a6, 91 f150 4x4 5mt
    DIY: Repurpose rear fog light(s) as secondary brake lights.
    This is a way to enable your rear fog lights to come on under braking but only on the second pull of the headlight switch. I plan to use this only in adverse conditions when I feel extra attention to my braking important. Obviously this is best used when you've already added the second rear foglight.
    First you're going to cut the grey white wire at the headlight switch. You're going to connect to both sides of this wire so make sure you don't cut too close to the switch otherwise you won't be able to get a butt connector on it. Connect about 2-3 feet of wire to both sides of the grey/white wire using either butt connectors or solder then run it out to the dash endcap.
    Next, you'll want to tag the black/red wire at the brake light switch either using a t-tap or solder with about 3-4ft of wire then run it to the same dash endcap.
    Next, ground a ring terminal with about a foot of wire to the metal sub dash. I used one of the 8mm bolts at the endcap as it was easy.
    Now that you have your four wires wire up a standard relay as follows -
    85 - ground
    86 - brake light feed
    30 - grey/white output side
    87 - grey/white switch side
    Once those are connected, tape up the excess and secure the relay.
    -dre
    Being different means nothing if you don't have taste
    WTB: 2001 4.2 A6 Transmission code FBC
    Forum Moderator Four Rings Gumby's Avatar
    Sep 06 2008
    01 allroad, 01.5 A4 TQM
    Bellingham, WA
    link to original thread for discussion: http://www.audizine.com/forum/showth...y-brake-lights
    -Matt-
    B5 S4, C5 A6 Moderator
    Murdered out and coilovered 2001 allroad stage 2+ on a diet
    2871r'd 2001 A4 1.8t - powered by 034 Motorsport - Build thread
    Low cars are faster than high cars. It's science. -8520
