Results 1 to 11 of 11
    May 31 2010
    16 Q5 3.0T
    Missouri
    removing Q5 door armrest
    I've found references to doing same for A4 B8, but didn't have any luck finding instructions for the Q5. Anyone have an idea as to how to remove the driver's side door armrest to access the window switches?
    I removed the screw under the center section of the armrest, but it's not clear to me if there are other fasteners involved or just a series of clips.
    Thanks in advance
    Veteran Member Four Rings spijun's Avatar
    Oct 11 2010
    Audi Q5 2.0TFSI S tronic
    Sarajevo, BiH
    I think that the procedures for A4 B8 and the Q5 is the same here's your image from electronic catalog for the Q5
    Maybe this is a help:
    http://www.audienthusiasts.com/Proje...rLighting.html
    May 31 2010
    16 Q5 3.0T
    Missouri
    Thanks once again for the help.
    I had looked at David's write up earlier, but a key difference between the B8 and Q5 is that the Q5 does not have the hole under the armrest into which a screwdriver or similar is placed to remove a section of the armrest without having to remove the entire door panel.
    Based on the screenshots above, the bad news is that it appears that I need to remove the door panels in order to remove/replace the window switches. (I am in the process of installing the refresh switches).
    Veteran Member Three Rings Maximum's Avatar
    May 27 2012
    My lounge
    Galt
    I'm trying to do the same thing. Any updates? Thanks!
    2012 S4 Prestige, Monsoon Grey, STaSIS exhaust/springs, APR Stage II+, RS grill, RS shifter knob, Roc-Euro intake, Ziza LEDs, CREE W16W Reverse LEDs. RS6 flat bottom wheel, MMI 3G+, P3 Cars guage, Passport mirror radar, LI, 034 trans mount & end links
    2012 Q5 2.0T Blaze Orange Matte Metallic, STaSIS Tune, exhaust & 20x10 rims, RS grill, 2013 lights, LED interior, ACCUAIR B8 Sports suspension
    2003 A4 Avant 1.8T silver
    Oct 11 2010
    Sarajevo, BiH
    Quote Originally Posted by Maximum View Post
    Which car ?
    May 27 2012
    My lounge
    Galt
    The Q5. Just curious if the door panels really have to come off. In the one diagram, it doesn't appear so. But is it like that with all the doors and what about the trunk release.
    Oct 11 2010
    Sarajevo, BiH
    Yes, you must remove the door trim
    May 27 2012
    My lounge
    Galt
    Just the door trim or the entire door panel?
    Oct 11 2010
    Sarajevo, BiH
    Pictures above explains method and what you need and how to remove
    Good luck
    May 27 2012
    My lounge
    Galt
    Thanks for the info!!
    Oct 11 2010
    Sarajevo, BiH
    If you need a PDF for this send me an email address to PM
