Page 278 of 295 FirstFirst ... 178228268276277278279280288 ... LastLast
Results 11,081 to 11,120 of 11795
  1. #11081
    Senior Member Four Rings Luxus Panzer's Avatar
    Apr 15 2014
    B6 A4 Avant, B4 90 Sprot Q, B4 90 FWD, 2014 VW Tiguan
    Ottawa/Gatineau Canada
    Are you sure the vacuum hoses under the intake manifold are attached correctly? The SAI only runs on a cold start and then it shuts off.
    This pic is gold....Added to my archives. Thanks Old Dude
  2. #11082
    Established Member Two Rings Moncion's Avatar
    Jan 14 2016
    Ontario
    Helllo audizine -
    Ever since I bought my avant, sometimes when I turn on the headlights they trip ABS, Traction control, ebrake, and basically everything on the dash. The PO installed some sort of aftermarket bulb or ballasts so theyre those blue/white colour headlights. It seems like theyre taking too much power or something - I can take a video or something soon.
    Any ideas?
  3. #11083
    Established Member Three Rings Pswish's Avatar
    Mar 25 2016
    2010 Suzuki VStrom 650
    Bay Area
    Quote Originally Posted by Moncion View Post
    Helllo audizine -
    Any ideas?
    The HID ballast is too close to the ABS module causing your problem, make sure you ground it too.
    Early 04 1.8T Dolphin Grey A4, 156k miles and counting, often in bay area traffic, HIDs lows and fogs, ECS Snub mount, Vag-Com, AllDIYData.com access, Photographer.
  4. #11084
    Active Member One Ring kenny2many's Avatar
    Jan 27 2016
    Ma
    Gas cap
    Sent from my LGLS676 using Audizine mobile app
  5. #11085
    Senior Member Three Rings Arnie91's Avatar
    Oct 28 2015
    London
    Whats the best way to clean out the intercooler? It's been left open and disconnected for a while so I imagine its got a bit of dust, dirt and cobwebs up in that shizzle.
  6. #11086
    Aug 19 2013
    minnesota
    Quote Originally Posted by Arnie91 View Post
    Soak it in some Degreaser and swish it around then let it hang and dry after you rinse it out
    Sent from my SM-G920V using Tapatalk
    APR exhaust, HFC, 225 injectors, APR II program, KO4, South Bend II endurance clutch and SMFW, Forge Tip+piping, Apikol SMIC, Stern motor+trans mounts, Stern Snub, 034 street density arms, Hotchkis sway bars, Lemforter links, Bilstein B8, B7 S4 calipers, powerstop braided lines, Centric drilled rotors, PowerStop Carbon Fiber pads, Timken bearings, Gates racing timing belt, DENSO IQ01-27 plugs, R8 coils, Motul Xcess 5w40, MANN 950/4 filter, gear300, CHF202, Motul RBF 660.
  7. #11087
    Oct 28 2015
    London
    Im working on finalising my engine, testing stuff out. I have a persistent water leak at the back on the coolant flange. I've checked the pipe connections and they are solid. What it looks like is that the coolant flange is not level on the back of the block. This is weird because it should be manufactured level. I know that when the car last overheated t hat this was the same flange, could overheating and running an engine with no coolant (sensors never went off) cause the flange to warp?
    Ive unbolted it, and tried to see if it was torqed in at an angle but playing around with the bolts, definitely looks like its an issue with the flange.
    Im hoping that re-ordering a new one will solve it, otherwise im kind of fucked.
  8. #11088
    Senior Member Four Rings blitz2190's Avatar
    Jul 31 2014
    NH
    the coolant flange on these engines goes bad if you look at it wrong, they suck. Uro tuning recently started selling a long needed aluminum version, which I'll be swaping in when mine goes again. https://www.urotuning.com/Cooling-Fl...FZJKDQodx3IEBQ.
    The problem is they rely on a rubber oring and a flat surface to seal. The plastic gets to hot on the head over time and warps and the crushed orig no longer seals.
  9. #11089
    Oct 28 2015
    London
    Quote Originally Posted by blitz2190 View Post
    Ah yes, the flange probably had less than 2000 miles on it but the Oring was flat as hell.
    Is there a warranty on the cast flange?
  10. #11090
    Jul 31 2014
    NH
    for the pain in the ass job that it is I would get that one I linked, it may seem a bit expensive but I would pay that twice to not have to do this job again, for the third time.
  11. #11091
    Senior Member Four Rings Pr1ce's Avatar
    Aug 11 2014
    03' 5spQ with extras
    Kissimmee
    I went to my local "powder coat store" and they quoted me $65 per caliper for 17z
    Does that sound about right?
    I've never had anything PC before and curious if that's a "fair" price
  12. #11092
    Jun 26 2015
    Tampa, FL
    Quote Originally Posted by Pr1ce View Post
    Are they doing the prep too? Sandblasting and such? If so, that's what I would charge to do a good job on them.
  13. #11093
    Feb 09 2013
    CNY
    Sounds right, maybe a little on the high side. But if they do a good job, it's worth it.
  14. #11094
    Established Member Two Rings NYDCB's Avatar
    Aug 22 2016
    Washington, DC
    So, this happened after a short drive yesterday evening
    Now, is this the proper kit to get for repair?
    https://www.ecstuning.com/b-assemble...FYmFswodW-cA7w
    I want to fix this ASAP. Tired of smelling cooked coolant when I drive, and hemmoraging on chicks' driveways when I stay the night lol.
    Also, what about this coupler?
  15. #11095
    Aug 11 2014
    Kissimmee
    ^ I have to tear them down removing boots and pistons etc .... they will sandblast them, powder them and clear them he said.
    So it sounds like a fair price according to y'all so I guess I won't look further and I'll take em there
    Thanks for the input guys
  16. #11096
    Apr 07 2011
    Quote Originally Posted by NYDCB View Post
    No, do not get that kit. Get an OEM flange only, not aftermarket.
  17. #11097
    Aug 22 2016
    Washington, DC
    Thanks... So this is the one then?
    https://www.ecstuning.com/b-genuine-...06b121132ekt3/
  18. #11098
    Apr 07 2011
    That's a kit that you could get. Honestly, you don't really need anything else except the flange and the o-ring(that already comes with it). So this is all you really need. Click The sensor is easy to change at any time so it makes no sense to do it as a 'while you're in there' type deal.
    One other thing about that kit is it's not really the right hardware AFAIK. There should be one stud along with a nut. There is a stud for the oil hard line to mount onto and the nut holds that hard line to the stud. There is no nut in that kit. You also don't need 2 of those studs, there's only 1 hard line back there that needs to be secured.
  19. #11099
    Jul 31 2014
    NH
    dont even get an oem one, get the uro tuning aluminum one and never deal with the crap plastic again. https://www.urotuning.com/Cooling-Fl...FYiEswodBJcK1w
  20. #11100
    Senior Member Three Rings G.AUDI's Avatar
    Dec 07 2008
    MK6 GTI
    SGV, CA
    dont even get an oem one, get the uro tuning aluminum one and ner deal with the crap plastic again. https://www.urotuning.com/Cooling-Fl...FYiEswodBJcK1w
    I second this... Installed for a year now with no issues
    Sent from my ONEPLUS A3000 using Tapatalk
  21. #11101
    Aug 19 2013
    minnesota
    Don't bother reattaching the turbo oil supply to the flange. It's just another thing to bend and put tension on the flange. It's plenty secure if it's mounted everywhere else
  22. #11102
    Apr 07 2011
    Quote Originally Posted by G.AUDI View Post
    I installed my OEM coolant flange back in January of 2014(over 3 years ago) when I did my cylinder head. I've put almost 60k miles on the car and the coolant flange is just fine.
  23. #11103
    Dec 07 2008
    MK6 GTI
    SGV, CA
    I wish that was true for me but after a couple of replacements (OEM too) I gave the metal one a shot and have been happy so far.
  24. #11104
    Jul 31 2014
    NH
    Mines leaking after a year ~80k miles
  25. #11105
    Oct 28 2015
    London
    Quote Originally Posted by daught View Post
    Get the now spring model. Easy to install and reuse.
    Sent from my DROID Turbo using Tapatalk
    I got the EGR delete so it's easy to get to really.
    New flange came today, secured on perfectly. I'm so surprised this flange warped within three months of use.
  26. #11106
    Oct 28 2015
    London
    PVC and Vacuum Delete Regrets.....
  27. #11107
    Oct 30 2008
    3 B5's
    Big Lake, MN
    Dude you have a massive vacuum leak. I deleted all that crap off my 01, don't have an maf either, and it idles smoother than a mostly stock evo that was over at my house
    "The American people already know that Bill Clinton is a bad boy, a naughty boy. I'm going to speak out for the citizens of my state who in the majority think that Bill Clinton is probably even a nasty, bad, naughty boy." Former Senator Idaho Senator Larry Craig, the man with a wide stance.
    2001 A4 1.8TQMS Mods- GT2871R, Maestro, All things that are good.
    2000 A4 Avant 1.8TQMS- Daily Driver
    2000 S4- Working?
  28. #11108
    Oct 28 2015
    London
    Quote Originally Posted by redline380 View Post
    Could it be due to the manifold not being bolted on fully? I've got like 2 bolts torqued down. Everything else Is either plug up or not connected.
  29. #11109
    Oct 30 2008
    3 B5's
    Big Lake, MN
    Absolutely
    2000 S4- Working?
  30. #11110
    Veteran Member Four Rings WillŽnskraft's Avatar
    Oct 14 2011
    2002 Audi A4 1.8TQ, 2007 Audi A4 2.0TQ
    Norcross, GA
    I tried pairing my key fobs today, but got flashing immobilizer and arrow flashing light. Am I doing something wrong or missing a step?
    EDIT: The buttons on the remote work i.e. LOCK/UNLOCK/PANIC
    I followed Ross Tech's instruction video
    "Beep beeeep bloop boop" - R2D2
  31. #11111
    Jun 26 2015
    Tampa, FL
    I'm not sure what you mean. Mine has two studs, each stud having two nuts, each nut holding something down. Maybe the '03 is different?
  32. #11112
    Dec 04 2010
    San Francisco, CA
    Quote Originally Posted by WillŽnskraft View Post
    You still have to adapt the keys. Remote function is only half of it.
    2004 A4 Avant 1.8T 6MT
    2005 A4 1.8T 6MT
  33. #11113
    Apr 07 2011
    Quote Originally Posted by rocket1420 View Post
    The reason for the stud is to have a nut securing something there. In the picture below, you can see there is a stud, with a nut securing the oil hard line to the stud. There is no reason to have another stud since there is nothing else that needs to be secured. I'm not saying the stud wouldn't work, just that it's not necessary.
  34. #11114
    Oct 14 2011
    Norcross, GA
    Quote Originally Posted by asg1290 View Post
    Is the PIN the SKC number?
  35. #11115
    Senior Member Four Rings eljay's Avatar
    Aug 13 2015
    NS
    Yes
    2005 Audi A4 1.8T Quattro Avant / 6-speed / Ultrasport - Unicorn rescue operation in progress.
    WTB: Mint condition silver B6 passenger fender.
  36. #11116
    Jun 26 2015
    Tampa, FL
    Yeah, I know what you're saying, but what I'm saying is that there's something secured there on mine. I don't remember what. I'll have to go look.
  37. #11117
    Dec 28 2006
    CCVR6
    Western Maryland
    On the 03 model there is something secured to each stud. On the driver side it is the hard pipe that connects the PRV to the PCV. The stud on the other side connects the oil line.
    A4 Motoza tuned Frankenturbo F21L mixed flow turbo / Bosch 550's / 3" MAF / TyrolSport SMIC / FT High Flow Exhaust Manifold / 034 HFC / TT 2.5" DP / Borla Exhaust / Eibach ProKit Springs / Koni Yellows / H-Sport Sway Bars / TyrolSport Brake Stiffeners / HyperShift Short Shifter / Podi Boost Gauge
    A5 Mods to come: Little stuff so far. 20/25mm spacers / H&R OE Sport springs / 35% tint / Neuspeed Power Module
  38. #11118
    Oct 14 2011
    Norcross, GA
    Quote Originally Posted by eljay View Post
    Yes
    I just read imnuts SKC retrieval guide. Is the VAG Commander absolutely required or can I just use a HEX CAN to pull the code?
  39. #11119
    Aug 13 2015
    NS
    VCDS will not read SKC.
    Look up cschuster's instructions for swapping clusters. There are steps to retrieve SKC.
  40. #11120
    Oct 28 2015
    London
    Absolutely
    Got the manifold on, it runs but still really badly, and needs a lot of gas.
    Ive just discovered a problem made by a rogue mechanic. Hes cut off one of the rods from the exhausting housing that joins onto the cat converter, the bolt has been cut, and there was a cut bolt which he used to replace it, but it wasnt secure. Now there's a gap in the exhaust between the downpipe and the exhaust housing, and its making a horrible horse sound as air spurts out. Im hoping the problem is this? This is going to be an impossible fix..
