Page 1363 of 1363 FirstFirst ... 363863126313131353136113621363
Results 54,481 to 54,499 of 54499
  1. #54481
    Senior Member Four Rings vce1232000's Avatar
    Jun 17 2013
    jersey city nj
    I just use 2 cans of brake cleaner
    APR KO4 ,S3 Inj, APR HPFP,RS4 LPFP Controller,145 bar PRV, APR TP, TT DP, GFB DV+, AWE FMIC, BFI CC, AWE Exhaust, RS4 Exh tips, ST Coil Overs, 034 RSB,034 St Density Mtr Mts, New South Vent Boost Gauge, Front B7 RS4 8 pot Calipers.Stop Tech slotted rotors.Goodridge SS brake lines frt & rr. Hawk HPS frt & rr. S6 19 inch rims. S4 mirror caps,RS4 Mesh Style Grill
  2. #54482
    Jun 15 2011
    cville,VA
    Thanks! I have extra and it evaporates immediately.
    Also Ordered VCDS from Europa with free shipping. OBDEleven is nice to have for a quick code reading, but the programming interface is not as intuitive. And since I plan on keeping this car for a bit, it is a must have
    08 ibis white A4 quattro 6 mt s-line
  3. #54483
    Veteran Member Four Rings drewgold's Avatar
    Sep 21 2004
    1981 Kawasaki KZ440
    Rocky Mountains, Canada
    Quote Originally Posted by Axis View Post
    We have to find out how to buy that
    @drewgold any luck with the interior aluminium door handles? I've been looking for a set for a while
    Unfortunately no doors. If I come across a set, I'll let you know!
    2006 A4 Avant, 2.0TQM - JHM Stg 1 Tune - Unitronic HFC/3" Downpipe - 034 Street Motor/Trans Mounts - APR Snub Mount - 034 Turbo Inlet Hose - JHM Short Shifter - Brembo Q5 Front Brakes - S4 Rear Brakes - Stock Sport Suspension - Platinum Recaro Interior -
    Put out to pasture: 1997 A4 1.8TQs, Tiptronic
  4. #54484
    Senior Member Four Rings 2pointOh's Avatar
    Dec 08 2013
    Buffalo, NY
    I think my driver rear caliper is stuck. Rotor has rust on face after driving. Fun.
    2006 A4 2.0T 6sp. JHM Stage 2 93 Oct. JHM TP-DPY to S4 Exhaust. GFB DV+. AFE Dry Filter Drop-In. 034 Engine Mounts. ST Coilovers. ECS RA4 LW SMFW and RS4 Clutch.
  5. #54485
    Established Member Two Rings wjg22's Avatar
    Apr 14 2016
    '01 Monster 750
    Pittsburgh
    Got it inspected
  6. #54486
    Veteran Member Four Rings 80sGuy's Avatar
    Oct 09 2007
    Miele S7
    Replaced driver visor - same with Homelink. Simple swap and re-programming not needed. Wouldn't stay up towards windshield while at use, kept on hanging down and blocking my vision.
    2008 A4 2.0T | Dolphin Gray Metallic/Dk Gray | multitronic | Bluetooth | Dk Wood | Convenience. | Premium. | Sprt Susp. | Bare-bone 100% factory stock!
  7. #54487
    Jun 15 2011
    cville,VA
    It's the extra weight. You are losing your race car status!
    Quote Originally Posted by 80sGuy View Post
  8. #54488
    Oct 09 2007
    Miele S7
    Quote Originally Posted by z_wrecker View Post
    Well, I'm more worried about safety than anything. Seemed to block the traffic lights. Actually no weight issues at all since the actual transmitter is fitted behind the front bumper.
  9. #54489
    Jun 15 2011
    cville,VA
    I was kidding given your signature. More than likely is the visor itself. Can you make it tighter? I'd gladly take a look at my car to see how it is being held but I drove the truck
  10. #54490
    Senior Member Three Rings klrider44's Avatar
    Aug 20 2014
    Doylestown PA
    Mine is literally doing the same thing, very annoying. I heard something snap one cold morning when I put it down. You say nothin need to be reprogrammed to the car?
  11. #54491
    Oct 09 2007
    Miele S7
    Quote Originally Posted by klrider44 View Post
    If you have existing Homelink then it is a simple swap. No need to reprogram or pair your garage remote with the visor. I found this on ebay, a NEW item. There are many used ones for a bit less but I don't want to encounter the same problem. Beats the dealer!
    Here's the seller. Ask him about the condition because he's got one with a slight indented dimple on it that might go for a bit cheaper if you don't mind.
  12. #54492
    Oct 09 2007
    Miele S7
    Ha ha!
    I tried tighten it but they don't work that way. These things are designed to be replaced, not repair.
  13. #54493
    Aug 14 2014
    TJ Jeep Wrangler Sport, 1979 P200E Vespa
    Finally ordered a new VC from Europa. Hopefully it solves my one of my oil problems. Also ordered the two gaskets, oil cooler & oil filter case gasket. Have a lot of oil coming from the area and figured I would replace both if I'm going there. Waiting on better weather for that though. Figure I'll do a carbon clean while I'm taking everything out. It's due for one after all this oil getting into where it shouldn't be
  14. #54494
    Established Member Four Rings james12lucy's Avatar
    Jul 04 2015
    Custom built, 440cc Midget, w 89 WHP. 2009 GSXR 600/750 w 129 WHP
    Toronto Ontario
    Carpet is now gone, too. The headliner and airbags are next. After that, it's measuring and bending time. That effing carpet weighs about 30-40lbs. What a piece of junk!
    As an aside; I've found about $14 worth of change in the interior from the previous owner (and at least $40 worth of Virginia slims cigarettes). Making this Canadian $1300 B7 even cheaper.
    Anyone want B7 interior parts before they go to scrap in my B6 scrap pile car?
    B7 Avant, 6MT, Quattro - Brilliant Black
    JHM 93 Octane Stage 2 tune, APR HPFP, S3 Injectors, JHM Test Pipe, Stasis Catback, R8 coils, 034 TIP, Carbinio CIA, 18" VMR 710, Podi Digital Boost Gauge, RS4 rear sway bar, RS4 grill, Eurojet Billet VC, 42DD catch can, Ohlins SL Coilovers w/ Hyperco springs, OEM Bi-Xenon retrofit, GFB DV+.
  15. #54495
    Jun 15 2011
    cville,VA
    That looks like fun!!! make a separate thread and update it daily!
  16. #54496
    Jul 04 2015
    Toronto Ontario
    Good idea.
    I'll bet I've stripped 300lbs already.
  17. #54497
    Veteran Member Four Rings mcpcartier's Avatar
    Oct 14 2011
    07 A4 2.0T Q 6MT, S-Line, Ti Pkg, Black, 08 xB, 13 Ex Ltd
    Quote Originally Posted by james12lucy View Post
    Let us know if you can fit the headliner out the door without bending it? I was told u need to take out the windshield or else you'd damage it!
  18. #54498
    Jul 04 2015
    Toronto Ontario
    I'm assuming it'll make it through the trunk.
  19. #54499
    Established Member Four Rings Okedokey's Avatar
    Oct 24 2015
    Sydney
    Got pulled over by the cops a few weeks ago and although he started off being a cockhead, he settled down. Pointed out that my cone filter needed to be 'enclosed'. Finally got around to building one today.
    Should look good once the paint dries and it is fitted.
    A4 B7 2.0L TSFI (Mauritius Blue) | KO4 + Autotech HPFP upgrade + BSR Stage II tune - 2.5" BSR CAT-back - CAI | GFB DV+ | 19" Audi 2015 RS4 rims | R8 Coils | 034 RSB, control arms, end links, street density engine & CVT mounts - snub nose - HFC | Cupra R lip | 7" Erisin 2028AM | Yellow Fogs, LEDs throughout | CXRacing FMIC - B12 Bilstein Suspension + H&R Springs | S4 brake upgrade and braided lines.
