Page 1404 of 1404 FirstFirst ... 404904130413541394140214031404
Results 56,121 to 56,126 of 56126
  1. #56121
    Established Member Two Rings panman142's Avatar
    Jun 21 2015
    Akron, OH
    Go to your moms or gf bathroom and steal some aerosol hair spray. Then over the pipe and then the silicone hose over the pipe. Then the coupler. I did this and never had a problem going on 4 years now
    Good stuff! I think I might need to pull the bumper again and trim the core support a bit more depending on how much pipe I can get into the coupler, was running low on dremel discs and my dremels on its last leg too. Some hairspray probably should do it though, pretty sure there is just enough for me to get adequate couple over the pipe and have enough to clamp. Definitely a nice cheap looking out ;)
    2006 6MT
    Malone stage 2+ w/ Autotech HPFP upgrade, ECS CF intake, test pipe, RS4 clutch w/lgwt flywheel, Forge DV, 034 RSB w end links, poly diff and carrier bushings, poly snub, 034 trans, RS4 engine mts, EVO boost & oil press gauges, ECS short shifter w/BFI knob, RS4 grille
  2. #56122
    Senior Member Three Rings Hightekflytech's Avatar
    Sep 24 2013
    I.E. Cali
    Quote Originally Posted by adamddd633 View Post
    Judd T202, 235/35-20 :-)
    I thought they looked pretty damn huge lol
  3. #56123
    Veteran Member Four Rings vvenom800tt's Avatar
    Dec 04 2011
    Kansas City, KS
    Took some pictures!
    20s look dumb on our cars. 19 are the biggest that look good.
    2005.5 Audi A4 Quattro 2.0T 6MT - APR - 034 - Custom 3" single exhaust - 17z Brembo - GFB - Alzor - Kumho - ST - Injen - Swift - Hyperco - ECS - Saikou Michi - PowerFlex - Podi
  4. #56124
    Jun 15 2011
    cville,VA
    What's a GF? Go Fast??
    08 ibis white A4 quattro 6 mt s-line
  5. #56125
    Registered Member One Ring 13 |'s Avatar
    Apr 27 2017
    Miami, FL
    First time posting on here. Been lurking for many years back when I still drove an mk4 GTI and dreamed of upgrading to an a4. Bought the car with 36,000 miles back in 2011, currently sitting at 109,000. Finally decided to start making some slight upgrades to the car after driving around stock for 5+ years. I'm on a slight budget so I had some solo werks s1 coilovers put in yesterday as well as HIDs both in the headlights and fogs. Here's a picture I took today... I know I need to restore my headlights asap. Will post more pictures once I remove the plastidip that is currently on the wheels (in pretty bad shape). Front is set between 24.5 to 24" FTG rear is maxed out at 25 FTG. [IMG][/IMG]
  6. #56126
    Senior Member Three Rings vierno12's Avatar
    Oct 26 2014
    ny
    Just got these for my exhaust build. Great thing they clamp on instead of welding
