Page 1519 of 1519 FirstFirst ... 5191019141914691509151715181519
Results 60,721 to 60,733 of 60733
  1. #60721
    Established Member Three Rings wjg22's Avatar
    Apr 14 2016
    '01 Monster 750
    Pittsburgh
    Quote Originally Posted by a4lownslow View Post
    No problem! Id first check codes with vagcom. Then you should hook up a manifold gauge and refill. This way you can monitor low and high side pressure allowing you to add the correct amount of refrigerant based on temperature/pressure chart. Iíd also add dye so you can find the leak.
    After you find the leak the next step would be evacuate the system, fix the leak, then pull a vacuum and refill to spec. This is listed under the hood in grams and should be around 16oz.
    It seems more complicated than it is, but if you take one step at a time and check out YouTube it really is a diy fix. Thatís how I learned.
    If you donít feel comfortable hooking up a manifold gauge and doing that process you could always buy a can from Walmart with dye and a low pressure gauge. Refill this way and check for leaks over a few days/weeks.
    Sweet, to YouTube it is. Plenty of time to figure this out before I really need the A/C, and hopefully it's nothing more than a small leak. Air con was working perfectly last summer.
  2. #60722
    Senior Member Two Rings a4lownslow's Avatar
    Feb 12 2014
    2007 Audi A4 2.0T
    Hudson WI
    The reason I say scan with vagcom is because a bad low/high pressure switch on the condenser could also cause the compressor not to turn on.
  3. #60723
    Apr 14 2016
    '01 Monster 750
    Pittsburgh
    Gotcha, I'll scan it first and see if I can rule that out. Fingers crossed, I guess.
  4. #60724
    Jun 27 2011
    Was going to say that. Check that first.
    -CP
    Former USP CLUB MEMBER #136
  5. #60725
    Registered Member Two Rings Flygman's Avatar
    Jan 27 2018
    Gothenburg
    Picked up a pair of B5 spring perches today. Has anyone had a shop install them? If so, what did you pay/how many hours of labor was put into it?
    Brilliant Black A4 Avant B7 2.0TS
  6. #60726
    Sep 09 2009
    Minneapolis
    They have to remove the front strut from the spring.
    Iíd say at least 2 hrs/side.
    How many miles on car?
    Other things might need to be changed when you open up the suspension.
    Control arms, tie rods, etc..
    2006 A4 2.0T Q. S-Line 6MT - Arctic White
    JHM stage 1, 034 hfc, Europaparts exhaust.
    Miro 111 18x8.5 et 35, 034 RSB.
  7. #60727
    Jan 27 2018
    Gothenburg
    Yeah, they usually tend to break when you start fucking with them after a few years I've heard.. Mine's at about 120k miles. Right side had control arms & tie rods changed a couple of months ago, so that side will probably be pretty easy. I think I've got a bad bushing in the left suspension, so I thought it'd be a pretty good time to take care of it all.
  8. #60728
    Established Member Three Rings Dondbg's Avatar
    Mar 12 2016
    MB w203
    New Zealand
    What Did You Do To Your B7 Today?..
    Can someone tell me what is this oil ?
    Itís all over the sway bar bushings as well.
    Is it another mount which leaks ? Confused
    Will jack it up this weekend and see
    In the meantime , any ideas ?
  9. #60729
    Jan 28 2018
    Wellington, New Zealand
    Silicone key cover because the keys both looked scruffy.
    Bluetooth OBDII thingy. Works well with Torque Pro app.
    1985 ur quattro
    2006 Audi A4 3.2 quattro. (Not to be modified by order of the wife!)
    quattro project
  10. #60730
    Mar 08 2011
    union, nj
    Area around the mount seems clean... Possibly oil from an oil filter during service. Check from under.
  11. #60731
    Veteran Member Four Rings QuattriumMT6's Avatar
    Aug 24 2013
    1991 Toyota Mr2 Turbo
    Stockton, CA
    Weight reduction!!
    2008 A4 2.0TQ | S-Line | 6MT | Brilliant Black | Ti | JHM | APR | 034 | H&R | Bilstein | Magnaflow | AWE | Apikol | Relak | Cupra | Ziza | DTM | Maxton | ECS | RS6 Grille DIY | CC'd
    1991 MR2 Turbo | Berk Technology | JDM Ceramic CT20b | Works VS-XX | BC Racing | H&R | Pegasus | Twosrus | CRW | Euro Kouki Taillights
    ~Marc
  12. #60732
    Veteran Member Three Rings khaos443's Avatar
    Nov 27 2011
    Ft. Worth, TX
    It's been a while since I've posted on here, nice to see some familiar names are still active in the forum. I have sadly sold my A4, it was time and ended up replacing it with a Jeep Grand Cherokee once I graduated school. The mod bug still exists, but its obviously different and man the forums just arent active, makes me miss this place.
    06 A4 2.0T SOLD - Shopping for a B5 S4
  13. #60733
    Senior Member Three Rings oVeRdOsE's Avatar
    Jul 01 2015
    Mtl
    Quote Originally Posted by khaos443 View Post
    everybody told me that the bug mod will disappear with age and kids.
    Well... no. I still want to mod everything, even my coffee maker. lol .
    the avant got a big exhaust, and the kid likes it, in fact , it's been proven that the mom's heart beat can reach 90dB, so loud exhaust will help baby to sleep.
