Page 1516 of 1519 FirstFirst ... 516101614161466150615141515151615171518 ... LastLast
Results 60,601 to 60,640 of 60732
  1. #60601
    Established Member Two Rings K1196A's Avatar
    Feb 16 2007
    DOVER, PA
    Quote Originally Posted by B7S3wannabi View Post
    Attachment 52178
    Mounted my S5 Rotors with 255/35/19 PSS. Need to make a few adjustments but they look sick!
    Drool-worthy!!!
    For my part... this valentine's day evening was spent rebuilding my front inner CV joint. My wife is a Saint!
  2. #60602
    Senior Member Three Rings klrider44's Avatar
    Aug 20 2014
    Doylestown PA
    Turned on my methanol injection today, forgot how hard it pulls with it on.
  3. #60603
    Established Member Three Rings B7S3wannabi's Avatar
    Mar 27 2017
    2005 ZCP Competition M3
    Burke, VA
    Quote Originally Posted by Older_not_Wiser View Post
    Looks great. My favorite OEM wheel. The 255 PSS are wider than the average 255. Let us know how you make that work without excessive rubbing. Do you think it is going to require some pulling? Extra camber?
    Thanks! Obviously my favorite as well. Just dont tell my wife I have two sets! ;)
    Yes, the PSS 255 are wider than average. Im actually running 275 PSS on the rear of my M3 so i kind of expected it.
    Iv been trying to find a place near me that will pull my fenders, but still nothing. I am only rubbing in the rear a bit on big dips. But that might also be because I have four Miros in the back...
    I will probably go with a 245 once these wear out.
    Currently I am at -2.7 in the front and -2.4 in the rear for camber with a 5mm spacer in the front to clear the RS4 brakes. Will be reducing to 2mm in the front. There is no spacer in the rear.
    Quote Originally Posted by Flygman View Post
    Looks great? Are you running any spacers or are they that wide?
    Thanks! Just the 5mm in the front to clear the RS4 calipers until my 2mm come in.
    Quote Originally Posted by eurojunkjon View Post
    Looks good
    Out of curiousity what color is your car officially? Mine is deep sea blue pearl and it always looks black in pictures
    Thank you.
    Officially its the Ocean Blue color. Not sure if its called anything else...
    2006 Sline A4 Quattro 2.0T | JHM K04R | JHM Tuning | JHM HPFP Upgrade, S3 Injectors, RS4 Fuel Controller | R8 Ignition Coils | APR Carbonio CAI | AWE FMIC | Golf R Intake Camshaft | JHM Lightweight Crank Pulley | USP Test Pipe, Europaparts Catback w/ Quad Tips | RS4 Front & Rear Brakes w/ JHM lightweight Rotors | Stern Adjustable UCAs | STX Coilovers w/Hypercoil Rear Springs | 034 Solid Rear Stabilizer Bar w/ Adjust End Links | B6 Recaros | Miro 111s |
  4. #60604
    Jun 17 2013
    jersey city nj
    I had the same 5mm spacer's to clear my brakes also
    APR KO4, APR HPFP,RS4 LPFP Cntr,145 bar PRV, APR TP, TT DP, GFB DV+, AWE FMIC, BFI CC, AWE Exhaust, RS4 Exh tips, ST CO, 034 RSB,034 St Dnsty Mtr Mts, New Sth West Bst guage, B7 RS4 8 pot Calipers.Stop Tech slotted rotors.Goodridge SS brake lines frt & rr. Hawk HPS frt & rr. RS4 PS rack, RS4 Servotronic Relay,RS4 rims. S4 mirror caps,RS4 Mesh Style Grill,LED tail lites
  5. #60605
    Established Member Three Rings funkypterodacty's Avatar
    Apr 30 2017
    Aren't you running RS4 wheels? Why would you need spacer to clear RS4 calipers? Unless those stoptech rotors have a shallower mounting face than stock RS4 rotors ?
  6. #60606
    Established Member Two Rings DanielP's Avatar
    Dec 08 2016
    Las Vegas
    Installed an Ebay BOV spacer $16 and this thing sounds great, on YouTube spacers seem so quite but this one is perfect!!!
    Highly recommend!!!
  7. #60607
    Registered Member Two Rings Flygman's Avatar
    Jan 27 2018
    Gothenburg
    Quote Originally Posted by DanielP View Post
    Highly recommend!!!
    Could you try to upload a video? $16 is impressive. Does it have a rubber o-ring? I got a Forge one for around $70, having it installed on monday.
  8. #60608
    Dec 08 2016
    Las Vegas
    Yeah it has O-rings and says Forge, which is sad i didnt want it to be a direct copy.... but whatever sounds SO LEGIT!
  9. #60609
    Active Member Two Rings theguysinger's Avatar
    Nov 25 2017
    '13 Subaru Legacy 2.5i
    Ephrata, PA
    These things are so sick, I put one on my car the other month and itís never coming back off.
  10. #60610
    Jun 17 2013
    jersey city nj
    Quote Originally Posted by funkypterodacty View Post
    Im running RS4 wheels now. When I had the spacers [wrenched] I had S6 wheels
  11. #60611
    Jan 27 2018
    Gothenburg
    Damn I could have saved some money then
  12. #60612
    Established Member Three Rings mgfranz's Avatar
    Apr 08 2016
    Temecula, CA
    Highly recommend!!!
    What is the purpose of this?
    2008 Audi B7
    2007 BMW 650i
    2001 Porsche Boxster (for sale)
    1999 BMW 740i M-Sport
  13. #60613
    Nov 25 2017
    Ephrata, PA
    Quote Originally Posted by mgfranz View Post
    Choo choo noises
  14. #60614
    Apr 01 2007
    2017 Mustang GT Performance Package, 1983 Chevy Silverado
    houston texas
    Dont the spacers cause issues? Isnt that a known thing?
    2005.5 6 speed with the Premium, Lighting, Sport, and Cold Weather packages
    PPT Brute 144mm rods, Pag Parts Turbo EFR 6758 Turbo kit, Pag Parts custom FMIC (600hp garrett core), Pag Parts custom TIP (retains stock airbox), S3 injectors, RS4 PRV, Modified LPFP, APR HPFP, Water/Meth, Turbosmart kompact 50/50 DV/BOV, Turbosmart IWG actuator, Eurodyne Boost Manger Plus, Eurodyne Tune - Pag Parts
  15. #60615
    Dec 08 2016
    Las Vegas
    U get to be the coolest guy on the block
  16. #60616
    Nov 25 2017
    Ephrata, PA
    Quote Originally Posted by texasboy21 View Post
    I donít know, mine has been fine so far. I believe the intention of it is to only let some of the air into the atmosphere so that your car doesnít freak out like it would with a BOV.
  17. #60617
    Dec 08 2016
    Las Vegas
    The main issue is everyone will be scared to race you when they hear the "swooooosh tututu"
  18. #60618
    Mar 27 2017
    Burke, VA
    To be obnoxious...
  19. #60619
    Dec 08 2016
    Las Vegas
    To be obnoxious...
    Ahh yes, squirrel nuts talkin about obnoxious
  20. #60620
    Mar 27 2017
    Burke, VA
    Interesting how you are so bothered by deez nuts
  21. #60621
    Dec 08 2016
    Las Vegas
    Well........u got me😡😠
  22. #60622
    Apr 08 2016
    Temecula, CA
    So... Rice rocket on steroids right? No HP, Nothing but rice rocket noise.
    2008 Audi B7
    2007 BMW 650i
  23. #60623
    Dec 08 2016
    Las Vegas
    Same with Stereos/Speakers no HP gains. But people install them??
    I wonder why??????????
    Ohhhh maybe cause i love how it sounds. Just maybe ......
    No, that cant be it!
  24. #60624
    Mar 27 2017
    Burke, VA
    If you like the sound over performance, go for it.
    Without a DV or BOV, in the conditions of high boost and rapid closing of the throttle body, the boost can cause the compressor wheel to rapidly decelerate trying to spin it backwards. This can damage the compressor wheel and the shaft that connects both the compressor and turbine. The difference between the two is with the DV, by rerouting this pressure back to the compressor inlet, it helps keep the momentum of the wheel going, in turn decreasing lag.
    Also, with a high flow intake and high boost pressure, your DV makes enough noise as it is to be "cool"
  25. #60625
    Apr 08 2016
    Temecula, CA
    So.... rice rocket. #nonoisegohp
  26. #60626
    Dec 08 2016
    Las Vegas
    Just wait till i order the DV block off plate, the panties will bunch.
  27. #60627
    Jun 27 2011
    DV relocation?
    -CP
    Former USP CLUB MEMBER #136
  28. #60628
    Veteran Member Four Rings i3oricua's Avatar
    Sep 17 2006
    2006 A4; 2007 Audi Q7 3.0 TDI
    Brandon, Suffolk, England
    I had one of these for like 6 years I stalked and never had any turbo damage. Just like you I enjoyed the sound but to answer the original question the purpose is get the BOV sound that our cars lack. I enjoyed it. I say go for it.
    Believe me if I listened to only the opinions from this forum then my car would be an avant, with LMs or RS4 reps, and probably white because you know #itstheinternetandIcantrollandbetoughwithoutgettin gpunchedinthemouth
    Brilliant Red B7 // EFR 7163 w/S3 injectors and stock internals // RS4 Fuel Controler // Meth Injection // Rotiform BLQs // Eibach Springs w/Koni Shocks // Raxles // Custom Front Mount - Treadstone // Fluidampr Pulley // Thor Skid Plate // 18Z Upgrade // S-100 Touch Screen // RS-4 Sway Bar // Custom Catback // Snub Mount // JHM upgraded fuel pump internals // ECS Catchcan // ACTechnic Blackout Boost Gauge in PodI // Seat Cupra Splitter
  29. #60629
    Jun 27 2011
    What Did You Do To Your B7 Today?..
    Imma let you finish...but avants are clearly the best. Itís science.
    Also going to a blowoff valve wonít ruin the turbo at all. But it will mess with your fuel trims because youíll be dumping metered air to atmosphere.
    Itís not the end of the world but still something to consider.
    -CP
  30. #60630
    Dec 08 2016
    Las Vegas
    Block off, as in no air will exit and it will flutter like crazy!!!!Screenshot_20180216-000252.jpg
  31. #60631
    Sep 17 2006
    This one is questionable. I donít know the effects of this but it doesnít sound healthy to the turbo. Youíll get that cool flutter sound buuuutttt....I donít know what else.
  32. #60632
    Dec 08 2016
    Las Vegas
    Quote Originally Posted by i3oricua View Post
    What else???? WHAT ELSE?!?!?!?
    ill be so cool, neck breaker turbo shaker
  33. #60633
    Established Member Two Rings RandyBeanz's Avatar
    Jan 12 2017
    Honda Pilot
    LA
    Found a local guy that sold me his dash trim and door trims for $65. Loving how it matches so much more now inside. Also went back to oem leather b7 seats because recarro bladder swap will never get done by me . Attempting to find a direct swap b7 recarro seats now. IMG_6914.JPGIMG_6915.JPG
  34. #60634
    Jan 27 2018
    Gothenburg
    Please post a video if you're doing this
  35. #60635
    Mar 27 2017
    Burke, VA
    Who said a BOV will damage your turbo?
    I was implying that you need one or the other to prevent damage to the turbo.
  36. #60636
    Mar 27 2017
    Burke, VA
    DV relocation?
    I seriously hope he plans to relocate the DV or BOV if he installs that. Otherwise THAT will damage the turbo or even break the throttle plate if running high boost pressures.
  37. #60637
    Dec 05 2016
    miami FL
    Would a fordge DV on a stock turbo provide additional BOV compared to the original dv or do u have to add components to get upgraded preformance/ sound like a throttle plate or adapter plate?
  38. #60638
    Dec 05 2016
    miami FL
    Or spacer? To get BOV effect of a upgradedforge DV?
  39. #60639
    Jun 27 2011
    Yup. That will totally fuck the turbo.
    And throw you into limp mode.
    And probably blow your intake piping off.
    But, hey, good luck with that.
    -CP
  40. #60640
    Established Member Two Rings Irizarry's Avatar
    Mar 27 2012
    Tampa, FL
    Traded her for an 18 Accord Touring 2.0T and really missing her! But thankful I still have my MK1 TT 225! Needed something larger for clients and the new A4 optioned up was a bit more than I was willing to spend. Already regretting it
