Parts came for my APR Stage 1+ prep:)
Going to do a little work this weekend in prep for my APR Stage 1+:) Except for the injectors that is... those I'll have to do just before or after I go to the dealer for the flash.
I have two more coil packs at home too... I hope the DV, plugs and coils help pep it up a bit too before the chip and injectors!
Senior Member
Three Rings
Very nice. I love the feeling of getting a nice big box of parts in the mail
-Andrew
Frankenturbo/GIAC
cool, you will love it once you get APR Stage 1+.
Be interesting to understand what people have gone regards upgrades before they have done any Stage1, Stage1+, Stage 2 etc upgrades and what people found worked and didn't.
I know when I did this, I was advised to stay away from APR DV and get either Forged DV or Audi TT DV. I also heard that VW guys use Madmax DV as say they are great, not sure if they work on Audi's.
What did you order as your pre-equipment? Also have you upgraded your exhaust system or air filter?
Active Member
Four Rings
Jealous. Been itching to buy some 386s and go 1+ but only once I sort out my engine and get it running tip top. Stage 1 is fine for now I suppose. Anyway there's no point when I've got a boost leak.
-CP
2004 A4 1.8TQ 6MT USP - APR Stage 1 - FSI Coils - BKR7EIX-11 - 034 Silicon Breather - 034 Rear Swaybar (Soft Setting) and Solid Spherical Endlinks - B6S4 Front + B7A4 Rear Brake Setup - Failing Clutch Mod
2008 Black Unicorn (2.0t S-Line Ti 6MT Avant) - BRK6EIX-11
SOLD -- 2006 A4 2.0TQ Avant Tiptronic stocker - Failing TC Mod
Three Rings
Even with Stage 1+ this car is slow as f*ck.
Save your money and buy new car.
I kind of regret getting full exhaust and all the toys after some gonzalez in chevy blazer smoked me....
Four Rings
The part OP will regret is the "APR" part.
Nothing wrong with their tunes as they are buttery smooth... There is just no where to go (worth going) after stg 1+. You are basically stuck.
OP should go with REVO that way when he wants to go BT (so his car is actually decently fast) he can for an affordable price.
-John
"get the biggest of everything you can. always. that's a winning combination. everytime. just ask the military." -Dan[FN]WTF
Three Rings
I am having really bad luck with revo and their customer support is not the best...
If OP wants to keep the car for some time i would definitely go with maestro.
Four Rings
^ true
You got me. That would be a smarter choice.
-John
Senior Member
Three Rings
I have APR software and I would definitely urge the OP to try something else if you ever plan on going bigger than Stage 2. Unitronics, Revo, Maestro etc.
Don't get me wrong I love APR software. It's easy to use and has some nice features. But if you ever plan to go to at least an Eliminator turbo go a different route.
APR stage 2+, CM FX400, LWFW, APR snub mount, JHM short throw, RAI TP, Forge DV, RS4 rear sway bar, Vogtland Coilovers, Thor belly pan. 19's staggered.
Active Member
Three Rings
I think Revo has the best upgrade path.
If I wanted more than a normal GT-series BT, Maestro would be the best option...although I think a lot of people don't realize that they themselves probably aren't capable of writing their own tune.
Active Member
Four Rings
I think the biggest I'll ever go is a K04, so APR would probably work just great for me... depends on how far you want to go.
~Calvin
034Motorsport
RogueEuro 2004 Audi A4 1.8T /// 6-Speed /// quattro /// Moro Blue Pearl || uni stage 2 || symph ii+ || podi || ns sport w/ b5 seats || v718 sunken treasure
Four Rings
K04 would probably be a huge disappointment. That is a lot of coin to shell out for maybe 20hp.
Hp is addicting. The more you have, the more you want.
-John
Active Member
Four Rings
Truly only 20hp??? OMG that's terrible. I figured I'd at least get 30-40.
I just don't want to go to the trouble of changing the manifold, etc. just to get a different turbo to fit. And i don't want so much HP I have to upgrade my transmission.
I figured: Injectors, Exhaust, High-Flow Cat, Downpipe, K04, inlet/outlet pipes, Tune... Wouldn't that net me somewhere in the 240-250 AWHP?
~Calvin
034Motorsport
Four Rings
Sadly, yes.
Standard K04-015 that an APR K04 Tune calls for, yea the difference is 15-20hp IIRC. Maxxed with everything you can expect about 190-200, maybe 210 on a happy dyno.
A FrankenTurbo and all supporting mods will get you somewhere around 240 with a good agressive (probably custom) tune (Read: not APR)
-John
Forum Moderator
Four Rings
Ahh yes but the power is quite strong low down the rev range making it a great option around town plus if you pick up one cheap your quids in.
Pro's & Con's
USP CLUB MEMBER #127
04 A4 B6 1.8TQ S-Line 190bhp 6 Speed
|B7 DTM Milltek| VMR Gauge| SP51 K04-15 Outlaw (K04-23+)| Samco Sport DV|034 Sport CAT|Auntbahn88 TIP| N75J|TT MAF|380 inj|SouthBend 4 Clutch|
2Do list:|B7 RS4 F-Brakes|RS4 custom SMIC|
I'm not that concerned with speed, if I was I'd buy a Vette...
I also have a B7 S-Line (Charcoal) and a Boxster (Silver) in the garage as well, so if I feel the need I have options. But truthfully, I like this B6 just as much! I had a B5.5 for 10+ years with full APR stage 1. Cat back etc. LOVED IT!
In prep for the Stage 1+...
For this B6 I have only done the DV, plugs (new coil packs for giggles)... I'll do a few more mods but not many. I might just do a test pipe and leave the stock exhaust until it needs replacing...
That's really about it... (I also did the timing belt etc a couple weeks ago)
I'm looking forward to getting back into turning a wrench!
Four Rings
Looks like Bosch 386cc injectors, 710n DV, BKR7E plugs, and Revision "D" coil packs.
'03 Ming Blue A4 Avant 1.8TQM | Maestro | Spec Stage III+ | Vogtlant GT's | JHM trio | Podi | OEM+
Active Member
Two Rings
the peak gain with a K04 is only about 20hp, iirc, i think you're right on that.
however if you look at the graphs, there's a whole knut-tonne of area under the curve low down, so it will feel like a pretty decent gain.
that being said, i would personally not get a K04, i'm going Franken on Unitronic tune shortly (i know i've been talking about it forever, but seriously its going to happen, lol)
2005 A4 1.8tqm - black on black - FRANKENTURBO, 440cc, 034 HFC, stealth exhaust, 18" enkei EKM3, Bilstein sport/H&R, RS4 rear sway, Precision FMIC w custom piping, HP2, Podi, R1DV
Active Member
Two Rings
Sadly, yes.
to clarify here, sir, you are talking awhp, correct? i've read the franken threads multiple times, and the crank numbers are close to 285. please correct me if i'm mistaken
Four Rings
Yes, i was talking about awhp.
Theoretically, being that it is a 31lb/min turbo, it should be capable of about 310 crank hp. (given the right setup)
With 310 crank hp, figure in your 20-25% drivetrain loss for a quattro car and that puts you in the 235-245awhp ballpark that you are seeing in the thread.
-John
Four Rings
Don't waste your time on all this 1+ 2+ -3 etc etc. Get a bigger turbo. I wish I skipped the whole APR 1/1+ train, and went straight to what i have now. Go big or go home.
Four Rings
^ if we had the money I think we all would
but between work and college, Stage 1+ is fine........until I pay off the car  then were going bigger
Please Drive Right
FS: TT ballast, GTI Stock Springs, 2.0 Cams
I think, for my needs, the 1+ is just fine...
All I'm looking for guys is just a bit more umphh out of the car. Not a racer! Based on my experience with my chipped B5.5, the APR chip is a great decision!
Active Member
Four Rings
I get this sentiment and if we were all shooting for big HP then I would agree. But the fact of the matter is we are all different and we all have different goals for our cars.
Having had a NA 330hp RWD car I can honestly say it was an absolute blast to drive, but the power is wasted in a DD. There were times where teh power was great, but sitting in traffic, I almost would have preferred a stock 1.8t. Ok well stage 1.
My point is the Stage 1+ is good enough in many respects to satisfy the power urge 90% of the time where I drive. The other 10% I do wish I had more power, but I can live with that. Lots of us just want to be able to have a fun DD that isn't a money pit or complete hassle to get a build finished on. A k04 is a relatively drop in solution that retains a good deal of the OEM factor and for those reasons its still pretty viable option despite the FT being a better power producer and the eliminator kits offering more as well. I mean Vinny, you can't tell us with a straight face your build has gone remotely smoothly!
Were I ever to upgrade my turbo, it would be REALLY hard to justify (personally) spending that much on something for my 8+ y/o car.
If I lived my life a quarter mile at a time, I might PM Jesse to hook me up though...
In conclusion, I support the OP. Also the 1+ upgrade is a pretty cheap option so why not.
Edit: I thought about this a bit more and realised the GTRS kits aren't that much more for what they put out, but its still in the ballpark of $2k for an ATP kit, without tune and install. As I don't think I would be up to the task of installing the turbo myself, I would have to pay a shop, which means more cash and the possibility of them fucking it up. Either way the GTRS is about as big as I would go, so to me thats the upper end. Couple that with the increased wear and tear and potential for aftermarket parts to break and the prospect becomes much less rosy. Not saying it doesn't make sense, but for those of us with less lofty goals, a simple k04 makes a lot of sense.
-CP
- You may not post replies
- You may not edit your posts
Forum Rules
