Results 1 to 3 of 3
Thread: B7 Audi S4
    New Member One Ring
    Nov 13 2011
    Cypress, Texas
    B7 Audi S4
    How hard is it to install the Rear Passenger Bose speaker grill? I punched a hole in mine, don't think I damaged the speaker though. Also, for a stock S4 what should I do to get the most sound out of my exhaust and should I buy the Intake Manifold from JHM. Also, is there a place to buy headers etc. for it?
    Active Member Two Rings smashed s4's Avatar
    Jul 06 2011
    san jose
    check your headlight fluid.. it could be leaking
    2000 S4 6MT Stage 1 034 ECU 276 AWHP 331AWTQ SOLD
    2000 S4 6MTStage 3+, K04s, 034 Flash, 034 Injectors, 034 MAF, RS4 Accordion hose, RS4 Fuel Pump, JHM ss, AWE Twin 1, AWE LWFW & Southbend Stage 2, 18" BBS CH, X-1 Carbon Fiber Cold Air Intake, H&R/Bilstein combo
    425AWHP 435AWTQ SOLD
    2003 Carbon Black M3
    2004 Suzuki GSX 600 Katana
    Senior Member Four Rings Axel-'s Avatar
    Jan 29 2011
    Toronto, CA
    Quote Originally Posted by undecidedryan View Post
    To get the most out of your exhaust, get the JHM tune. IM and headers are great but expensive. Also, you need to drop the motor a bit to install the headers. Not cheap.
    Sprint Blue B7 S4 Avant 6MT - 421whp/350wtq
    JHM Stage 1 Supercharger - Stern Motor mounts - JHM IM - JHM Stage 4 clutch - JHM LWFW - Stoptech ST-60 BBK - KW v3 Coilovers - Apikol Rear Diff Mount - JHM "Trio" shifter - Trexturk DP - Magnaflow CB - Hotchkis 29mm RSB - JHM Intake Spacers - TT-RS MFSW - 034 Adj. FUCA - RS4 Pedals - Zada Tech Gauges - STE Gauges - Dynavin D99 Android
