Results 1 to 40 of 50
    Oct 01 2010
    b7 a4 2.0T 6MT
    Squeaking noise coming from engine bay 2.0t
    So this problem all started over a year ago. At first there would be a squeaking noise coming from the engine bay on cold start ups and would go away after a few mins of driving. Brought it to bell Audi and they said it was the accessory belt and that it wasn't covered under warranty. I had 35k miles and was still under the factory warranty and have a CPO warranty and they wouldn't do anything to help. I said forget it and left. The noise continued to bother me and about 3 months later I bring it to Flemington Audi. The tech does something (belt dressing) and the noise stopped for about a month or so. Then the noise now started to happen all the time. No matter how hot or cold or how long I drive it the noise is always there. The exact noise that it sounds like is from greensto's video (google b7 a4 squeaking noise from engine bay). I bring the car to bell Audi again and the service rep tells me that it was one of the timing belt tensioners and that they would replace it under warranty. Got the car back and the noise is still there all the time. I was too lazy to bring the car back because I'm tired of going back an forth with no fix. I'm asking the audiZine community to see if any of you have any suggestions before I go back to the dealer yet again...?
    Ps. I searched and read the timing belt thread so I'm aware of that but I doubt they would replace that under warranty...
    Any ideas?
    Dec 03 2008
    2014 Forester XT, lawn mower
    Castle Rock, Colorado
    Items for Sale
    I have same squeak. Haven't done anything about it yet, but I was told it was the serpentine belt needs replacing. ~$200 at my shop to take care of.
    2012 Audi S4 Prestige 6 speed, 034 Stage 1, USP Intake, custom x-pipe exhaust, 034 Trans Mount Insert, 034 Front/Rear Diff Mount Inserts, JHM Stage 3 clutch, JHM LWFW, USP SS clutch line
    Dec 03 2008
    Items for Sale
    I was told to try this, but haven't yet.
    While the engine is running, spray brake kleen on the serpentine belt. If it stops squeaking, then you know that is the problem.
    May 21 2007
    13 S4
    Northshore, MA
    Items for Sale
    wtf! do not try that!!!!! brake cleaner will eat your belt up. they have shit called belt dressing that will do what youre describing.
    also, replace the belt yourself man it litterally takes 15 minutes! if you look at the belt and you see its dried and/or cracked you know its time to replace.
    -Nate
    Current: 2013 Ibis White S4
    Mistake: 2008 BMW 135i
    Previous Audi: 07 Ibis White A4 S-Line Ti Package [SOLD]
    B7A4 Build Thread: http://www.audizine.com/forum/showth...58#post7310258
    Dec 03 2008
    Items for Sale
    You could do this:
    Veteran Member Four Rings bman005's Avatar
    Sep 06 2011
    2015 Silverado, 2012 A4 Avant. Former; 90 Corrado, 97 Golf, 05.5 A4, 2010 Tiguan
    Harrisburg, Pa
    with the engine running put a wrench on the serp belt tensioner and loosen the tension slightly, if the noise goes away it is serp belt related. If not it timing belt related
    New Build, 2010 Tiguan. Details to com
    Oct 01 2010
    b7 a4 2.0T 6MT
    ok lol thats not going to happen on a b7 lol. But i will try the wrench method once it stops snowing and will report back!
    Apr 01 2005
    dfw
    Items for Sale
    I had the same issue and it was a timing belt roller, since it was under warranty the dealer went through all the trouble to get to it and change it only.
    ACNA Member
    08 A4 2.0TQ Titanium S-line
    17 A4 2.0TQ Prestige S-line
    Former;
    02 A4 1.8TQ
    03 A4 1.8T
    03 RS6
    Dec 03 2008
    Items for Sale
    bman: Any diagram as to which bolt is the tensioner? I want to do this this weekend. Any diy on replacing it?
    Registered Member Four Rings Rodmar's Avatar
    Jan 29 2012
    None
    Sioux Falls, SD
    I just had a question about this the other day and there should be a post of mine if I can find the link ill link it. I bought the belt to change because now my car constantly squeels, it used to just be on cold start and it would go away, but either way I have a link ill try and get ya showing where the belt is and I might be able to show you what you have to turn slightly to release tension.
    Jan 29 2012
    None
    Sioux Falls, SD
    Here's the link to my thread http://www.audizine.com/forum/showth...t-and-location
    Here's the link also showing how the belt needs to be on when done
    http://www.audizine.com/forum/showth...ng-Belt-Change
    Here's a pic of the belt
    http://i31.photobucket.com/albums/c3...20Belt/P11.jpg
    Here's a pic of the tensioner
    Dec 03 2008
    Items for Sale
    Thanks! you don't have to remove all that bullshit to do this, do you?
    Jan 29 2012
    None
    Sioux Falls, SD
    I haven't done the change yet, been to cold to stand outside in the wind and do it lol, but I will soon. I was also thinking I'd try taking off the tensioner itself, and regreasing the bearing inside and cleaning it up, and that would be a good start. easy remove seeing as you just have to remove the three bolts on the tensioner, and grease was about 4 bucks at autozone, high temp grease is what you would want, again can take it off, take it inside in the warmth and do it then put it back on and the belt, pretty easy job when I get around to it and might solve the problem if it doesn't a bearing somewhere could be going, a pulley could be, the tensioner itself, and if it's not any of that, then its a timing belt area issue.
    Jan 29 2012
    None
    Sioux Falls, SD
    HELL no lol you don't have to go into service mode to do it, just open the hood and take it off, small hands are a plus or just dont wear gloves even if it's cold out and you can take it off.
    Addition: It might be a PITA, but work with it, it's just hard to do because it's a tight space
    Oct 01 2010
    b7 a4 2.0T 6MT
    so to change the serpentine belt all i have to do is open the hood, turn the nub clockwise to release tension, uninstall belt, install new belt, and then turn nub counter clockwise to increase tension again?
    Oct 01 2010
    b7 a4 2.0T 6MT
    also my noise in constantly squeaking no matter cold or warm and even when my car is fully warmed up it stills squeaks. This is EXACTLY the same noise i have btw: http://www.youtube.com/watch?v=iMSfJ7zn67o
    Dec 03 2008
    Items for Sale
    That sounds just like mine. Doing a little work to the front end on Monday, I'll try loosening the tensioner and report back results then.
    Sep 06 2011
    Harrisburg, Pa
    @JR are you planning on doin the thermostat?
    you don't need the special tool, an allen wrench that fits the holes is strong enough.
    And here is the routing
    Sep 06 2011
    Harrisburg, Pa
    Quote Originally Posted by Rodmar View Post
    It shouldn't take any more than 5-10 minutes to do.
    Dec 03 2008
    Items for Sale
    Quote Originally Posted by bman005 View Post
    Yet my shop will charge me over $200 with parts. lol. I love them, but sometimes it's like, really? I guess you gotta pay to be ignorant.
    Sep 06 2011
    Harrisburg, Pa
    Sometimes the extra cash is worth it to know the work is being done properly. Piece of mind
    Jan 29 2012
    None
    Sioux Falls, SD
    lol maybe in the case of a timing belt job, but not when it comes to just the serp belt, it's so easy to do if it wasn't -1 out id go finally get it done HAHAHA
    Veteran Member Four Rings ericpaulyoung's Avatar
    Feb 24 2011
    '08 a4 b7 6MT
    Eugene / OR
    You could do this:
    Holy shit.
    - Eric
    Dec 03 2008
    Items for Sale
    Oh I hear you on that one. That's why I paid them $800 to do my clutch.
    Jan 29 2012
    None
    Sioux Falls, SD
    BTW just did the belt change today, was a PITA for sure, no space in there and deffintly need 2 sets of hands. but all done.
    Jul 25 2010
    Spare engines!
    Denver, Colorado
    Items for Sale
    Actually when you replace the timing belt, there are marks that show you exactly where to line up everything, pretty simple.
    Dec 03 2008
    Items for Sale
    Soooooo, did it fix the squeak?
    Veteran Member Four Rings mr shickadance's Avatar
    Jul 08 2010
    tucson
    danbury
    Quote Originally Posted by b7a4GT30 View Post
    Any ideas?
    your pcv is blown, this happened to me too
    [CENTER]Scott
    2011 S4
    America is all about speed, hot, nasty, bad-ass speed - Eleanor Roosevelt
    Jul 08 2010
    tucson
    danbury
    before you go tearing your engine apart, do the PCV test....i am telling you, that is your problem, hot or cold, the squeaking would happen, then it gets louder, and louder, and louder.....its worth the 5 minute check just to see
    [CENTER]Scott
    2011 S4
    Established Member Two Rings DarkHelmet's Avatar
    Jan 15 2012
    Renton
    What is this 'test' you speak of?
    Quote Originally Posted by mr shickadance View Post
    Sep 06 2011
    Harrisburg, Pa
    I would like to think that a dealership tech would never mistake a bad PCV as a belt noise. The 2 sound nothing alike. PCV sounds as you described and the belt noise while still high pitched has a definite rotational difference to it.
    Jan 29 2012
    None
    Sioux Falls, SD
    So far no queaks at all.......I'll let you know later tonight after I let the car sit for awhile, but it sounds and even feels better but that possibly my brain tellin me that. But I drove around town for a bit and didn't hear a thing like I've been hearing so I'm thinking it's fixed.
    Jul 08 2010
    tucson
    danbury
    noo they sound incredibly similar, thats what i thought when it first happened bc it only happened when it was cold, then it happened no matter what, then it got louder and louder
    it was insanely similar to the sound an a belt does when they get old ....im just sayin before you go all frankestein.....take a few puffs through your breather hose,
    [CENTER]Scott
    2011 S4
    Dec 03 2008
    Items for Sale
    I have catch can, soooooo at least for me, it must be my belt
    Veteran Member Four Rings mcpcartier's Avatar
    Oct 15 2011
    07 A4 2.0T Q 6MT, S-Line, Ti Pkg, Black, 08 xB, 13 Ex Ltd
    Good job. Did you need to take the belly pan off to get access for snaking the belt into place or did you do it all from above?
    Veteran Member Four Rings papadelogan's Avatar
    Jul 31 2011
    1999 F250 7.3 Powerstroke
    Rockin' in the Rockies!
    I have a bit of a squeak and have the BSH PCV Revamp, so I don't think it can be my PCV, though there is a hose left from the OEM parts that is reused.
    Where did you source the new belt? I checked Autozone.com and they list 20+ belts when I put in my model, almost all having different lengths!
    2007 Ibis White B7 A4 Ti Avant 6MT quattro JHM Stage 2, HFC, Milltek CatBack, GFB DV+ "the YETI"
    2005.5 Black B7 A4 6MT quattro sold
    Jan 29 2012
    None
    Sioux Falls, SD
    Well it was snowing outside, so it was cold enough to give the car a go, and so far the squeak or squeel is gone after a couple revs, it still does it but no where near as bad, and it's gone within a minute unlike before it would last awhile.
    Oct 01 2010
    b7 a4 2.0T 6MT
    I dont think it would be the PCV. However, i am not a mechanic. I will say the dealership told me it was the accessory belt. I think im going to bring it back in and mention some of these pointers that you guys are giving me. If i were to conduct a PCV test, where is the PCV valve and how would i do the test?
    Oct 01 2010
    b7 a4 2.0T 6MT
    Nevermind, i read how to conduct the PCV test by removing the Oil filler cap. If it tests good i will assume its belt/tensioner related with the accessory/ serpentine belt since the noise appears to be louder when moving towards the nose of the engine bay.
    Jun 27 2011
    Items for Sale
    Its probably the idler pulley or somethign for the accessory belt. I think there are two actually. One on the end of the tensioner and one that is attached to the block. Sounds like your bearings are on their way out...
    -CP
    2008 Brilliant Black Unicorn (2.0t S-Line Ti 6MT Avant) - Bosch FR6KPP332S plugs - Q5 Rear Aero Wiper
    2012 Q5 2.0t - Stock Mommy Missile
    Former USP CLUB MEMBER #136
