Results 1 to 17 of 17
    May 23 2010
    2004 S4 6spd
    Dougalsville, GA
    start up rattle shortly after timing job
    ok so less than 2000 miles ago i had all the timing chain stuff replaced becuase the car was misfirin really bad and multiple guides were broken yadda yadda yadda. point is i have been goin the whole time with absolutely no start up rattle. took the car up to the shop to have them change the oil and everything went smoothly. drove the car home. when i went to start it after it sat for an hour or so, it had a start up rattle. not loud but definitely there. im concerned about this. i dont know what oil the shop put in there after they finished the work but the oil i gave them to put in it the first time was motul 5w-40.
    help me guys. im going to call them in the morning and see what they want me to do.
    Thanks
    Connor
    JHM 93 Tune w/ LA ** Piggies ** Magnaflow catback ** V1 Hardwire ** Podi V1 Gauge Remote Display ** A Beagle in the Back Seat ** K&N drop in ** Porsche 6000k low beams ** 3000K Fogs ** JHM Delrin Weighted Shift nob ** stern motor mounts ** stern trans mount ** Apikol snub ** 034 zero clearance snub bracket ** IM spacers ** Cupra R lip ** Thule 480 Roof Rack With 44" Fairing ** Super Blue DOT4 Brake Fluid
    May 23 2010
    2004 S4 6spd
    Dougalsville, GA
    nobody has any ideas?
    Nov 07 2010
    Troy, MI
    Check your oil first. If the shop didnt put enough in then your cam adjusters are starving for oil and you will here the startup rattle.
    Mar 26 2007
    Colorado
    on a side note, what did it run you to replace the whole timing system?
    - and yes, check your oil level.
    A Fully Catless JHM tuned S4.....
    Dec 26 2008
    2004 Audi S4---SOLD!
    STL
    That really is sad to hear, especially with all the labor and costs, not to mention frustration of not having a car, involved to replace timing compoenents. You said that you brought the oil to the shop, so i assume you brought them 10 quarts right?
    Who did your timing belt service? it's possible that if something was not adjusted probably that it's showing up later, but that's a strecth though. I would take it back to the shop that did the oil and speak with the manager about this. If this is the same shop that did your timing belt service, they should warranty their work.
    May 23 2010
    2004 S4 6spd
    Dougalsville, GA
    Quote Originally Posted by Slobo7x View Post
    timing belt?
    Dec 26 2008
    STL
    my bad, i realise we have a chain..just used wrong terminalogy..
    Active Member Three Rings Amsterdamned's Avatar
    Mar 21 2011
    2004 DG S4 Sedan
    Miami, FL
    The only thing I can add is after my last oil change. I switched from M1 0w40 to the Motul X-cess when I first started the engine after the change I got the gnarliest chain rattle imaginable. It sounded like everything was dry. Not much help I know, just thought I would chime in. I'm on all original timing components and get the occasional .5 - 1 sec cold startup rattle.
    .:2004 DG S4 6MT:.
    Clear Corners // 6000k HID Fogs & Lows // Hardwired V1 // 3M 35% Tint
    Trexturk Cat-less DP's // 2.5" Magnaflow // K&N Drop-in // JHM LWCP // JHM 93 Tune
    Apikol Snub & 034 Bracket // Stern Pro Mounts // 034 Street Trans. Mount // Apikol Rear Diff Mount
    Senior Member Three Rings JimmyBones's Avatar
    Apr 03 2010
    NOVA
    What did you replace exactly? I had to deal with this type of issue before and most people only replace the guides because they are cracked and maybe a camshaft adjuster if they have faults for it. I only sold one of those jobs because I always said to replace all the guides, tensioners, chains, and camshaft adjusters so you don't have to go through that again. Plus looking at it from the shop's standpoint how do they know it isn't a tensioner making noise that wasn't replaced.
    Quote Originally Posted by simplesedan99 View Post
    timing belt?
    LOL!
    Ex-Audi Tech - Looking for sidework. Vag-Com equipped and PM questions.
    2004 S4 6MT - Current Fun Car - Wavetrac LSD rear diff, JHM LWFW and St4 clutch, trio shifter, 4:1 center diff, LW crank pulley, USP metal slave cylinder with SS line, Stern race engine mounts, 034 Motorsports race trans mount, Apikol snub mount and race rear diff mount.
    2000 A6 2.7T 6MT - Current Daily Driver
    2004 S4 6MT Cabrio - Totaled
    May 23 2010
    2004 S4 6spd
    Dougalsville, GA
    yeah i dont know i was thinking about having them change it again back to whatever kind they used and see if it goes away. they also told me to check oil level so ill do that when i get home. sadly i left it there :(
    The shop manager is a friend of mine and just got done talking to him about it. he said to check oil level and we would go from there. and this is not the first time he or another tech in the shop has done this project so im not worried about stuff being wrong
    Senior Member Four Rings BCsniper's Avatar
    Jan 29 2010
    B6 S4 6MT Avant, B6 3.0 Avant 6MT (for sale), C5 A6 2.8 (needs fixing)
    north ga
    Just curious, what shop was it that did this job and has done it previously. I know this is going to get more common with these cars getting older, but aside from Audi dealerships, shops that are really knowledgeable about the TC 4.2 seem to be very few and far between.
    May 23 2010
    2004 S4 6spd
    Dougalsville, GA
    Quote Originally Posted by JimmyBones View Post
    LOL!
    i had the whole thing done. they replaced everything
    May 23 2010
    2004 S4 6spd
    Dougalsville, GA
    Quote Originally Posted by BCsniper View Post
    solomotorsports did it. check them out. good bunch of guys. tell Boris that Connor sent you
    Clicky
    when you go to the site, the second picture that slides up is my car on the lift with no motor lol
    Active Member Two Rings mlittleton's Avatar
    Nov 21 2011
    2006 S4, 2002 E39
    Atlanta
    Saw your other thread on this. So what's the story? Are you still having problems or worried about issues after the timing chain service?
    2006 Audi S4 / Black on Black / 18" S5 Reps / Akebono Euro Ceramic - R1Concepts drilled/slotted rotors
    Veteran Member Four Rings drew's Avatar
    Jul 27 2004
    Gone: 996TT stage 3, E46 M3
    so cal
    I wouldn't worry about it. Some start up rattle is normal. Audi has a TSB on it.
    05 S4 6MT Light Silver/Black-Silver Alcantara
    Senior Member Four Rings dparm's Avatar
    Apr 24 2009
    2005 S4 sedan
    Chicago, IL
    These cars have noisy valvetrains & injectors. Are you certain it's not the normal operating sound? The chain rattle is like marbles-in-a-can...very distinct.
    2005 S4 saloon 6MT
    May 23 2010
    2004 S4 6spd
    Dougalsville, GA
    Quote Originally Posted by mlittleton View Post
    the other thread is a summary of symptoms and events leading up to me getting the service done. after my first oil change...like the original post says, i had chain rattle when i did not have any. its gone now. turns out oil was a little on the low side
