Results 1 to 3 of 3
    Feb 20 2010
    1999 Cougar ATX 3.0 swap, SVT; 1996 Audi A4 2.8 V6 quattro, 2002 Allroad custom tune, cat delete
    Brighton, MI
    Oil pan gasket for 2.7T?
    I want to drop the oil pan, clean it up, maybe replace the pick up tube filter (if there is one?).
    Can't seem to find a gasket for the pan. Sources for the gasket (and pick up tube filter, if any)?
    Just use RTV sealant as gasket?
    1998 Audi A4 1.8T Quattro, dark blue, custom optimized K04, Carbonio CAI, APR Inlet Tubes,Turbo+Intake, Giac PC16, 31lb inj, Straight Pipe, Milltek CB Exh, Podi Boost Gauge, 17" OZ F1 225/45-17, Power Slot Rotors, Hawk Pads, SB Stage III clutch. Not installed: Walbro 255, stock ECU. Coming: K04max (RS6) hybrid.
    Active Member Three Rings 2.7taudi's Avatar
    Sep 08 2011
    Atlanta
    i believe i remember my mechanic saying he used silicon and no gasket.
    Stage 3 Forum Advertiser Four Rings Scotty@Advanced's Avatar
    May 16 2008
    South Texas
    Quote Originally Posted by 2.7taudi View Post
    Correct it's all sealant, no gasket.
    I stock that part.
    VW/Audi OE sealant
