Results 1 to 17 of 17
    Nov 18 2005
    Pair of (. )( .)
    Cool H-sport front sway bar.
    I will be taking mine off and going back to stock front sway since i will be doing a lot of city driving 21-23 mpg comparing to 9-13mpg in my durango, and and no time for track or auto-x, i was wondering if anyone would be interested, couple time auto-x'ing most of the time on highways, has some scratches from speedbumps but in perfect working condition, no accidents either, will take pix next week when i will take it off. its a 35mm one.
    -Andrey
    Stanced and Tuned Brilliant Black C5 A6 2.7T 6MT
    Senior Member Four Rings 8520's Avatar
    Feb 07 2008
    00 6mt A6, 95 5mt del sol
    Jmgraham probably is.
    -dre
    Active Member Two Rings DJPoochi's Avatar
    Jan 15 2012
    Atlanta, GA
    Quote Originally Posted by Kievskiy View Post
    I'm still learning how all these components affect the ride quality - I also will be using my A6 as a daily driver. That said, Why are you choosing to take off the front sway to improve your daily ride? What "Feel" is changed to make the stock better for a daily use?
    In general, I know these thicker bars stiffen up the ride, so is it that it's too stiff and you are wanting to go more "cushion-y"?
    Active Member Three Rings
    Jul 23 2010
    2000 A6 4.2L
    Vancouver, BC
    The sway bars only affect handling under cornering, daily ride quality is unchanged unless you also change out your springs/shocks. The one exception to that is if you use the Subaru STI rear sway endlinks instead of the OEM Audi links on the front bar. The Subaru links have no rubber so they transmit cornering much more directly improving response, however the lack of rubber bushings also means that all vibrations in the sway is transmitted into the suspension and steering rack.
    2000 A6 4.2L: Koni Yellow Sport Dampers, Eibach ProKit Springs, H-Sport sway bars, DICE iPod unit, brushed aluminum gauge rings.... and a proven ability to consume (lots of) fuel
    Senior Member Four Rings redneck truck's Avatar
    Apr 22 2010
    2001 TTQ Roadster TDI 6MT, 2001 A6 4.2Q 6MT, 2000 & 2001 MK4 TDI 5MT, 2006 CBR1000RR
    Plano, TX
    I'm running them and am very picky about ride quality; they did not affect ride, but they made the cornering a lot more responsive. Car has a tendency to understeer a bit, even with the rear bar on the stiffer of the two settings, but I suppose that's better for the average driver than rotating.
    Veteran Member Three Rings scot_w's Avatar
    Apr 05 2006
    '04 allroad 4.2, '00 A4 1.8T QWSM
    H-Sports on hard here. I did not notice any deterioration in ride quality only an immediate difference in cornering. The H-Sports took the allroad from Buick handling to Audi handling.
    But I am sure someone will love them.
    BTW if you are just removing the front and leaving the rear you will have some really bad handling.
    Nov 18 2005
    Pair of (. )( .)
    I just have no real use for it any more, thats all, no complains just wanna sell it i guess, at least for now
    -Andrey
    Sep 11 2009
    NE
    Weird. Are they off yet? How about you install oem ones and see how horribly car drives without them before you sell the bars. I can't imagine going back. Wallowing cars is not my cup of tea.
    Nov 18 2005
    Pair of (. )( .)
    I know how it will be i had my 6 for quite some time now with any susp setup avaliable exept air bags, plus i will still have race h&r coilovers which perform very well even with stock sway bars, i like my car tO have more stiffness in the rear for more oversteer too, not sure why are you so negative about the ride quality, mine drives quite well;)
    -Andrey
    Active Member Three Rings v8a6's Avatar
    Aug 25 2010
    I am running H&R coilovers and H&R rear sway with stock front. Ride seems fine to me. Mind you, I don't track the car.
    Nov 18 2005
    Pair of (. )( .)
    Here you go:))
    -Andrey
    Oct 26 2010
    San Francisco
    Hey, I'd be interested! What were you looking for? I can pick it up too since you live right by where I go to school :P
    Nov 18 2005
    Pair of (. )( .)
    P91 i will be taking it off this weekend, i will let you know the price after i will look closer at it
    -Andrey
    Oct 26 2010
    San Francisco
    Sounds good :) if you need a second hand or anything let me know.
    Nov 18 2005
    Pair of (. )( .)
    Thanx bro, i hope there will be no rain, damn it, was planning doing it outside since my garage is taken by my w124 lol
    -Andrey
    Aug 30 2007
    nyc
    Kievskt, do u recommend the rear over the front...i am stock now...saw your car on the city last year looked and sounded great.thx
    c5 A6 tip
    this n that
    ssp tuned
    Veteran Member Three Rings AnthraciteA4's Avatar
    Dec 31 2006
    Fort Collins
    If they're not spoken for yet, I'd love to trade my S-Line sways for your Hotchkis plus cash on my end obviously.
