View Poll Results: fter consider all options/features, price, and mileage, is this worth it?
Voters
19. You may not vote on this poll
  • Yes
    6 31.58%
  • No
    13 68.42%
Results 1 to 25 of 25
    Jan 23 2012
    2009 Audi A4
    Red Deer, Alberta, Canada
    Question About To Buy an A4 (Questions about service history)
    Hi,
    I am about to buy a 2009 2.0T Quattro automatic. It has 74,000 KM (46,000 miles), and it includes the Audi Certified Pre-Owned Warranty of 2 more years/80,000 KM more (50,000 miles) warranty through Audi Canada.
    It is a black on black with the Technology Package, Navigation Package, Audi Drive Select & Bang & Olufsen. I am getting it for $35,000 + tax. I want to make sure that this is a good vehicle and that it has been serviced well and hasn't had major issues that I should be worried about. I am allowed to call the previous owners and I want to discuss the vehicle he owned with him. Any particular questions that I should ask him? It has had only 1 owner, and it was in Ontario, Canada.
    Also, I really want LED tail lights and the 2009 don't include them - instead they have the Incandescent Tail Lights. I want to replace them with LED tail lights, should I purchase the OEM ones from Audi Canada/Germany or should I purchase aftermarket ones? I found these aftermarket LED tail lights on eBay what do you think of them?
    Ultimately, is this a good vehicle to buy? It is everything I have been looking for, so I want to make sure I am making the right decision here. Should I be worried about the high mileage? The rear brakes were replaced when it went through Audi's 300-point inspect during the recertification process. I'm going to do a poll, so please consider the price, features, mileage, and let me know if you think it's worth itAny comments and advice is greatly appreciated, thanks!
    Here is the service history:
    Repair Date: Mileage: Description:
    11/25/2008 33 Radio remote control sender removed & reinstalled
    03/14/2009 8260 Test drive
    03/14/2009 8260 Driver comf sys cntl module removed & reinstalled
    03/14/2009 8260 Front door trim panel removed & reinstalled
    03/14/2009 8260 GFF/Guided Functions
    03/14/2009 8260 Technical check
    03/14/2009 8260 Maintenance 8000 KM
    10/15/2009 23229 GFF/Guided Functions
    10/15/2009 23229 Door handle removed & reinstalled
    10/15/2009 23229 Lock cylinder removed & reinstalled
    10/15/2009 23229 Perform Oil Consumption Test #1
    10/15/2009 23229 Perform Recall Campaign 23D6
    04/21/2010 35282 GFF/Guided Functions
    04/21/2010 35282 Door handle removed & reinstalled
    04/21/2010 35282 Lock cylinder removed & reinstalled
    04/21/2010 35282 Performed Oil Consumption Test #1
    04/23/2010 35364 Test drive
    04/23/2010 35364 GFF/Guided Functions
    04/23/2010 35364 Lock cylinder removed & reinstalled
    04/23/2010 35364 Fuel filler flap replaced
    04/23/2010 35364 Fuel door positioning motor removed & reinstalled
    04/23/2010 35364 Technical check
    05/13/2010 36318 Fuel filler flap replaced
    05/13/2010 36318 Fuel door positioning motor removed & reinstalled
    05/13/2010 36318 Technical check
    05/13/2010 36318 Cylinder compression checked
    05/13/2010 36318 Perform Oil Consumption Test #2
    05/13/2010 36318 Test drive
    05/13/2010 36318 Door handle removed & reinstalled
    05/13/2010 36318 GFF/Guided Functions
    07/27/2010 41183 Test drive
    07/27/2010 41183 Readiness code US
    07/27/2010 41183 Cylinder compression checked
    07/27/2010 41183 Pistons removed & reinstalled
    07/27/2010 41183 Connecting rods checked
    07/27/2010 41183 Crankshaft checked
    07/27/2010 41183 Sprocket for camshaft removed & reinstalled
    07/27/2010 41183 Camshafts removed & reinstalled
    07/27/2010 41183 Upper oil pan removed & reinstalled
    07/27/2010 41183 Cooling system checked
    07/27/2010 41183 Transmission mount removed & reinstalled
    07/27/2010 41183 Technical check
    07/27/2010 41183 GFF/Guided Functions
    07/27/2010 41183 Engine complete removed & reinstalled
    07/27/2010 41183 Pistons checked
    07/27/2010 41183 Manual cleaning of the intake valve
    07/27/2010 41183 60 mile test drive
    07/27/2010 41183 A-time for extensive insp assisted
    09/02/2010 45190 Heated washer jets removed & reinstalled
    09/02/2010 45190 Technical check
    09/02/2010 45190 Power-assisted steering hose removed & reinstalled
    09/02/2010 45190 Test drive
    03/08/2011 58213 Door handle removed & reinstalled
    03/08/2011 58213 Lock cylinder removed & reinstalled
    03/08/2011 58213 GFF/Guided functions
    03/08/2011 58213 Technical check
    08/11/2011 69817 Replace camshaft adjuster as per RE
    08/11/2011 69817 Fuel
    08/11/2011 69817 Compressor/condenser line removed & reinstalled
    08/11/2011 69817 Compressor removed & reinstalled
    08/11/2011 69817 Transmission removed & reinstalled
    08/11/2011 69817 Power steering pump removed & reinstalled
    08/11/2011 69817 Performed extensive road test
    08/11/2011 69817 Refrigerant drained & filled
    08/11/2011 69817 Front wheel track adjusted
    08/11/2011 69817 Vehicle front & read measured
    08/11/2011 69817 Subframe removed & reinstalled
    08/11/2011 69817 Front wheel camber adjuster
    08/11/2011 69817 Compressor evaporator line removed & reinstalled
    08/11/2011 69817 Test drive
    08/11/2011 69817 GFF/Guided Functions
    08/11/2011 69817 Readiness code US
    08/11/2011 69817 Technical check
    08/11/2011 69817 Engine complete removed & reinstalled
    08/11/2011 69817 Engine carrier removed & reinstalled
    08/11/2011 69817 Cylinder compression check
    08/11/2011 69817 Camshaft adjuster removed & reinstalled
    08/11/2011 69817 Cylinder head removed & reinstalled
    08/11/2011 69817 Bonded rubber mounting removed & reinstalled
    08/11/2011 69817 Exchange engine completed
    08/11/2011 69817 Long block completed
    08/11/2011 69817 Door handle removed & reinstalled
    08/11/2011 69817 Front seat removed & reinstalled
    Active Member Two Rings audisline08's Avatar
    Jul 20 2011
    2008 B7 2.0T 6MT//2006 GLI 2.0T 6MT
    Alabama/Ft. Benning, GA
    If you say its everything you are looking for then get it, its your car your money?! IMO I wouldnt get an automatic, and the miles arent that bad with that service record...........my .02!!!
    Senior Member Four Rings bmc333's Avatar
    Feb 12 2009
    2007 A4 2.0TQ / 2006 TSX
    NoVA
    Go with the OEM LED tails if you get the car, please thanks.
    2007 A4 2.0T-Q - DSB - Tip - APR Stage III+ - Snow Stage III Meth kit - Billy Boat Cat back - APR TP - APR HPFP - APR Intake - Forge DV - Koni FSD/Eibach - RS4 Rear Sway - 034 Intercooler hoses - Evolution Racewerks SMICs - Hawk Ceramic Pads - 034 Catch Can - Podi Electronic Boost Gauge - Sterns Control Arms - Pioneer AVIC Z-120 - Rieger front splitter - Votex rear valance - 19" Avant Garde M310's
    Senior Member Four Rings bigblue's Avatar
    Mar 17 2010
    06 Jetta
    Pittsfield, MA
    Holy work done to it, what happen? the previous owner blow it up multiple times? and break into his gas door mad times?
    05 USP 1.8t A4 Tip | F4L FrankenTurbo | TT225 Injectors | Apikol SMIC | Powergasket | Forge 007 | 034 HFC | 034 Motor Mounts | Stern Transmission Mounts | Apikol Rear Diff Mount | APR Snub Mount | B5 S4 Front Brakes | AWE boost gauge | K&N Filter | 2.0T Coils
    Senior Member Three Rings Crucible35's Avatar
    Apr 22 2010
    Snow shovel
    Toronto, Ontario. Canada
    This car has had the oil consumption test done for excessive oil consumption.
    I'd be a bit leary of that but at least the original owner was getting this car looked after.
    Looks like the final entry relates to the CPO process.
    Regardless, With the extended warranty at least you're protected and if it has everything you want, go for it......just hope that the oil consumption didn't continue (ask the owner) so that you;re not spending a ton of time at the dealership getting it looked.
    "This one's just for practice!"....
    Jan 13 2008
    2008 A4 2.0t Avant 6spd
    Boston MA
    Quote Originally Posted by Crucible35 View Post
    I'd say its fixed:
    2008 A4 2.0T Avant 6spd. Black on Black Ti S-Line
    Registered Member One Ring nvr_follow_a4's Avatar
    Aug 25 2005
    2010 Ford Edge, 1989 Mustang LX 5.0
    Waterford, MI
    That A4 sounds like a horrible deal. The service history is horrendous for a '09. I bought my 2008 A4 Quattro S-Line Titanium edition, fully-loaded w/navi certified pre-owned from Audi about a year ago with 38,000 miles for $21,000. My service history was half a page if that. Just my .02 but I'd pass as there are plenty of A4s out there to choose from. Good luck!
    2008 A4 20TQM - S-Line Ti Edition
    Active Member Two Rings STA4's Avatar
    Jan 12 2012
    Mississauga, ON, Canada
    So much work done that the car has been probably been completely disassembled...haha. I bet you the original owner got sick and tired of having their car in the shop. Looks like they finally fixed the oil consumption issue, but I question why so many of the others repeat. If you're lucky, all the problems have been fixed for good, but I have a feeling that these problems are going to come back (the door handle showed up many times).
    Peter
    2009 A4 2.0T Quattro Premium 6MT
    Meteor Grey/Black | B&O | STaSIS ECU/Exhaust/Springs/RSB/Rims | K&N Filter | Eurocode TIH/HFIP/IHK/HFC | Strat O2 Spacer | BFI OCC | Podi Boost Gauge | Rieger Rep Spoiler | LED Interior/Doors/Plate | 5000K HID Foglights
    Registered Member Two Rings jrod80's Avatar
    Dec 18 2011
    '11 HD Dyna Street Bob - Highly Modified
    SLC, UT
    Seems way overpriced for a 2009. You could get into a brand new 2012 P+ for not too much more than that. I would pass as well, much better deals out there.
    2012 Ibis White A4 Avant P+, B&O & Smart Key
    Mods: ST Coilovers, VMR 701 19x9.5 Gunmetal, 20% tint
    Senior Member Three Rings A4 Centaur's Avatar
    Jun 05 2009
    2008 Ducati 848, 1199 Panigale on the way
    Colorado Springs Colorado
    Way too expensive for an '09. And considering the service history that car is a rolling time bomb! I would think that car would sell for closer to 30k tops.
    I bought a brand new 2012 Avant Prestige for a little over 39k.
    Way better deals out there!
    Black B8 A4 Avant S-Line Prestige Package, Tiptronic 8 speed, V1, Vogtland Coilovers, APR 91 & 93 ECU Upgrade, VMR RS4 Reps, and more mods to come!
    Jan 12 2012
    Keep in mind that he's in Canada where we get screwed for everything! I'd say the price is high considering mileage.
    Peter
    Active Member Two Rings DrnknCamel's Avatar
    May 05 2011
    Macon, GA
    I would be skeptical of a car with that much service history no matter what brand it was. I love Audi's but i made a mistake a long time ago in buying a 99.5 A4 that had a sketchy service history and I paid for it, over and over again. Cost me 4 Grand in repairs over the course of a year. Back when i didnt make much money so it hurt bad. Some cars no matter the brand are lemons and it is best to stay away from those.
    However i know you are getting the warranty, but what happens in 50k miles, (which is about 1.5 years for me with how much i drive) when you run out of warranty. There are a ton of Audi's out there. It would be worth it to travel a couple of hours to get one in great condition.
    Also if you look through the service history, it is a bunch of removal and re-install. Almost as if there is an issue with the car that they just cannot find. Who removes Transmissions, Engines, Sub frames, cam shafts, etc just to re-install the old one right back in the same day. It looks like they did solve it. But i bet it comes back at a later date.
    Active Member Four Rings dracolnyte's Avatar
    Jul 12 2010
    Quote Originally Posted by STA4 View Post
    +1, you guys dont notice that he is in Canada, where base A4 starts at 37k, and a premium plus equivalent here is around 45k
    Jan 23 2012
    2009 Audi A4
    Thank you all so very much for your input. I will definitely be calling the owner and asking him about the service history and why these were performed (especially repeatedly) and why he finally decided to sell.
    Regarding the LED tail lights: I'm doing research to see if I can retrofit OEM LED tail lights, as I would much prefer those even if they cost more.
    As for those questioning the price, please remember I live in Canada where it is substantially more. I have been shopping around across all 40 Audi dealerships in Canada for the last few months and this seems to be the average price for an Audi CPO A4 with these specs. I also looked into purchasing in the USA where it's a faction of the price, but I would not receive the extra 2 years/80,000 KM warranty which is important to me as I want to avoid as much maintenance costs as possible. Plus after shipping, fuel, flights and miscellaneous charges, the extra work is not worth the savings for me.
    Pricing aside, is this car not a good one? It looks like so far the consensus is don't buy this car due to the extensive service history. I was wondering what the removed & reinstalled were from (is it because they are removing the part to try and find the problem, and they could not find a solution so they reinstalled it?).
    I appreciate all of your help as I am eager to purchase an A4 but don't want to rush it and purchase the wrong one. I want to be one of the forum members that are spending their money on modding their car and not repairing it! All input is greatly appreciated!
    Senior Member Four Rings cory_can's Avatar
    Mar 05 2009
    (Very) Red B8 Avant, '11 Volvo XC70 T6
    Golden Horseshoe, ON, Canada
    Quote Originally Posted by dracolnyte View Post
    In Canada that particular car with Auto, NAV, Tech, B&O and Drive Select would have been high 50's when new.
    Dec 18 2011
    SLC, UT
    Pricing aside, I still would not buy the car. I probably wouldn't even consider it at a really good price. To me there are way too many things that have been fixed, many of them major. I would be nervous about ongoing issues after I purchased it and do not want a car that could potentially be in the shop all the time, even if it's covered by warranty. This is why I usually steer clear of first year model releases when there are major changes...can't stand to be back and forth to the dealer all the time and deal with all the BS that usually comes with it.
    Jan 12 2012
    Quote Originally Posted by Resophy View Post
    Do you know when the original warranty expires? Does the 2 years/80k start immediately or does it make your warranty 6 years/160k?
    Peter
    Jan 23 2012
    2009 Audi A4
    I believe it starts in 6000 KM, and has 2 years/80,000 KM remaining.
    Jan 12 2012
    Depending on when the original warranty ends, it may not be such a great bonus. For example, I just purchased my 2009 with 37k kms and a warranty that ends June 30, 2013, which is about 1.5 years. So, if I was in your position, I would only gain 1/2 year (mileage not a factor in my scenario).
    EDIT: Oh, and don't bother with those eBay tails, they look cheap. OEM is the only way to go...and it's not cheap (over 1g I believe). Maybe worth getting a 2010 with less technology and less mileage?
    Peter
    Feb 07 2012
    CO
    That's a long laundry list of repairs. If the only thing holding you back from buying in the States is the 2 year CPO warranty, buy a newer non CPO version with much of the original warranty left.
    I just picked up a 2010 A4 quattro premium with the sport package and 15000 miles for less than 30k out the door (price+taxes+fees).
    Jan 22 2011
    2008 Mercedes C300
    MILWAUKEE/WI
    I would find the other A4
    Jan 23 2012
    2009 Audi A4
    What is everyone's opinions or experiences with buying from an Audi dealership in USA and shipping it to a state close to the Canadian border? I will be sending $30K-$40K without even seeing the vehicle in person, also is it risky?
    Active Member Three Rings maga4's Avatar
    Aug 12 2011
    Olathe, Kansas
    I would imagine some of the Audi dealerships near the border have experience with this, but would expect it to be a bit more complicated than that. Good luck either way...
    2011 A4 Premium+, Quattro, 6MT, 18" OEM 5-spokes, Nav, Black/Black
    APR Stage 1, 35% Tint, Eibach Pro-Kit, Vag-Com, Gloss Black 3.2 Grille, Hoen Endurance Fogs, LED Interior/License Plate Lights, Strat Short Shifter, BFI Catch Can, Eurocode TIP/TRUFit Kit/HFIP, Hardwired V1, Rieger Lip Replica
    '91 Audi 90s Quattro, 5MT, White, stock
    Past: '98 A4 1.8TQ, Tip, Red / '99 A4 1.8TQ, 5MT, Black, Sport
    Senior Member Three Rings englishbay's Avatar
    Sep 30 2009
    Vancouver, Canada
    You can buy from most dealers in Washington state and they are all ready setup to do all the import stuff for you. Also CPO warranties can be transferred to Canada despite what you may have heard
    B8 A4 2.0T Quattro 6smt | Sport Package | APR S3/K04 | APR Turboback | Carbonio Intake | AWE FMIC | Eurocode HFIP | StaSIS Challenge Suspension | StaSIS High-Bias Torsen Differential | JHM Short Shifter | P3Cars Vent Gauge | Alu Kreuz | Snow Performance Water/Meth |
    Jan 23 2012
    2009 Audi A4
    Quote Originally Posted by englishbay View Post
    I've called several Audi dealerships in USA and they all confirm that the CPO warranty does not carry over into Canada. Some dealers recommend buying the vehicle and then purchasing warranty through a third party in Canada.
