Results 1 to 29 of 29
    New Member One Ring
    Feb 07 2012
    98 A4 1.8T
    Bloomington
    B5 1.8T (1.88T) Build in MN, Please Recommend/Help
    1998 Audi A4 All Wheel Drive 1.8T (Bought for $200):
    Bored .020" to 1.88T
    Forged Wossner Pistons 8.5:1
    Forged H-Beam Rods w/ 20mm pins
    ARP Main and Rod Bolts
    New OEM Oil Pump
    All New Bearings and Seals
    Stock Crank
    I'll add as I go but thats it so far.
    I still need to get a clutch & pressure plate and I'm wondering which ones people would recommend.
    Also I'm looking to get bigger valves, new springs, and bigger cams but I dont know what set up to go with, any information will be great, and I'll post pictures as I go too
    Active Member Three Rings jaychen's Avatar
    Feb 19 2011
    Brisbane
    Supertech or Ferrea for the valves. Mike Hood can hook you up. They come in standard or +1mm.
    As for the clutch, have a chat to Mike again. I guess it would be mostly dependent on what the car will be used for (street/strip/track).
    FX400 240mm would prob do the job just fine.
    IE or a set of CAT cams are your best bet. I think IE cams are currently out of stock though.
    Just want seat time again, that's all.
    New Member One Ring
    Feb 07 2012
    98 A4 1.8T
    Bloomington
    Thanks alot, where can I get ahold of Mike?
    Feb 19 2011
    Brisbane
    Ringer-racing.com
    He's on here , M-Hood is his user name
    Active Member Three Rings morzechowski's Avatar
    Jul 20 2011
    GT3076r E85 A4
    Minnesota
    ah I see you made it onto the Zine as well. There are a ton of builds going on locally in the MN suburbs, keep posting on the local forum you will get tons of good info there, A4Rob is the build beast and is on the forums quite a bit thankfully, listen to what he says and it will work.. sometimes I'm sure he will jump in here and holler
    jaychen has you hooked up pretty good here. not much else to add.
    I like George Michaels
    New Member One Ring
    Feb 07 2012
    98 A4 1.8T
    Bloomington
    thanks guys, i appreciate the help
    Active Member Two Rings Grip99's Avatar
    Feb 15 2011
    ny, ny
    Its gonna be an awesome set-up...Have fun bro!
    99.5 1.8TQM > 034 Ic Standalone / CompT4-5562 / Built Head / Built Block
    My Build http://www.audizine.com/forum/showth...-8-build-Enjoy
    AKA: Pete3071
    Dec 29 2011
    1999 A4 2.8 30V Q, 2011 Corvette GS Convertible, 2008 Tundra DC LTD
    Southern MN
    Not sure if it's legal to mention, but if you haven't checked out MN Audi (site should be easy to figure out) that would be good to join. Lots of local enthusiasts there and they can point you to shops, parts, etc around the area.
    New Member One Ring
    Feb 07 2012
    98 A4 1.8T
    Bloomington
    Yeah I just joined MN Audi and I've been on Fourtitude for a while now too. Im still trying to figure out the whole head set up, turbo, fuel system set-up (Injectors, Fuel Pump, Fuel Rail, etc. for 93 tune), & tune. I've also been looking for a stage 2 or 3 clutch & pressure plate but I'm not sure which brand to trust, any ideas on any of this would be great
    Oct 06 2004
    Minnesota
    Hi. Let me know if you have any questions. I am also local. My sn is the same on MNaudi.com also.
    Welcome to AZ
    AZ B5 & MW Moderator: PM me with any concerns or questions
    '99 Audi A4 1.8T Holset HX35W- Widebody- Matte Green -PVW 11.09
    R135
    246
    Feb 19 2011
    Brisbane
    Quote Originally Posted by B5_1.9T View Post
    Dude,
    For head, it's either Ferrea or Supertech valvetrain. Then you either go CAT cams or IE. No brainer.
    http://www.ringer-racing.com/product...&categoryId=52
    Stock fuel rail is good for atleast 500hp I think, you can get adjustable FPR that fits in the stock position for ~$150ish. Fuel pump, either go 044 drop in from 034 ($400) or Aeromotive 340 is good for 340L/hr at around 3BAR ($170).
    Clutch Masters for your clutch. 240mm setup for sure. Here are your options:
    http://www.ringer-racing.com/product...9&categoryId=4
    Or if you wanna hang with the big boys:
    I think that pretty much covers all your questions.
    Jul 20 2011
    GT3076r E85 A4
    Minnesota
    since you have a built bottom end the sky is the limit.
    Turbo:
    Garrett: gt30 series and up
    Holset: hx35 (Rob is running one successfully)
    PTE: 55- 5857
    tonnnss of other options just pick one lol
    don't forget a Tial WG & BOV to go with it.
    Fuel:
    850-1000cc injectors
    IE or 034 fuel rail
    -6 braided line
    Fuel Lab or Aeromotive FPR
    044 drop in fuel pump
    Software:
    Everyone here will tell you to get 034 or Eurodyne.. I wont. You are going to have to do some serious homework here, I have been for months now and have finally narrowed my search down to Lugtronic (hard to get a hold of) or Haltech ($$$$).
    I can give you a clone of my parts list if you would like. shoot me a PM on MN0000, same name.
    Jul 20 2011
    GT3076r E85 A4
    Minnesota
    And Jaychen mentioned the rest, everything he referred is awesome.
    between our two posts you are almost set and should have some research to do.
    New Member One Ring
    Feb 07 2012
    98 A4 1.8T
    Bloomington
    Wow you guys are all such help, seriously thank you. Im going to have to rotating assembly balanced, get the flywheel & crank resurfaced, get a new oil pan, and put it all together so I can start getting into the stuff you all just talked about. I will definitely post more pictures as I go and I'll get in contact with you guys for further inquires. Thanks again
    Senior Member Four Rings viceprp's Avatar
    Oct 17 2009
    is attached to my house.
    alonE, Pa
    Well when you have a build thread with pictures and progress, its hard to ignore and not help. It's the hypothetical builds that won't see this much attention.
    I would recommend a CT that is similar to a 30r. You are only limited by your tune so don't cheap out on that.
    ATW 1.8TQM | SCAT | FX400 | GTcougaR | AEM Standalone | Meth
    PM ME: Parting out all Stage I parts
    STEVE
    Oct 06 2004
    Minnesota
    Forgot to ask, what are your power goals? Do you plan to upgrade the brakes or suspension? I also noticed stock exhaust, which will be more of a power restriction than your stock cams at this point.
    R135
    246
    New Member One Ring
    Feb 07 2012
    98 A4 1.8T
    Bloomington
    yeah i posted all the pictures so people knew that i was actually in the process of building it and not just bluffing. As for power I'm looking to get 400-500hp. I will lower it on some nice coils, do a downpipe and a magnaflow or something from the downpipe back. As for brakes, I'm not going to be doing anything with those for a little bit but they will be done, I just want the car running first, I've never driven it lol. Do you think that's an achievable power range for this build?
    Feb 19 2011
    Brisbane
    Yes achievable. Will depend on turbo/fuel/tune.
    Oct 17 2009
    alonE, Pa
    Very obtainable if you're talking chp. That's a huge gap if you were talking who
    STEVE
    New Member One Ring
    Feb 07 2012
    98 A4 1.8T
    Bloomington
    This builds been on hold for about a month now but after posting this forumn im motivated again, starting in March I'm putting the bottom end back together and getting a Clutch Masters Stage 2 or 3, and starting on the head. I'm really considering the CAT Cams but are they very realistic for daily driving?
    Oct 06 2004
    Minnesota
    I DD with mine
    R135
    246
    Feb 19 2011
    Brisbane
    It all depends , where do you spend most of your time when you daily drive ? (rpm range)
    Are you going to want a car that makes 100hp until 6k or something that makes 150hp at 3.5 and 350hp at 5.5-6
    Active Member Four Rings coolgraymemo's Avatar
    Jun 10 2010
    Northern California
    Why are there so many BT/BAT B5's in MN?
    - Memo
    SSR Comp. STaSIS S/S. GIAC. Forge. Valeo E-Codes.
    New Member One Ring
    Feb 07 2012
    98 A4 1.8T
    Bloomington
    I like more lower end power, the lower the better but I still want high horse power. And i was looking at some CAT Cams, whats a good angle for the 400-500hp range and where can i find all the info on that?
    Senior Member Four Rings flynnr's Avatar
    Sep 22 2008
    1969 chevelle SS 454 convertible
    Minnesnowta (Roch)
    Cause MN is badass.
    1999 Audi A4 Avant 1.8tqm
    JE pistons/ Scat Rods/ Built AEB head (8500rpm)/ GT2871r/ 034 IIc Standalone/
    034 Tubular Mani/ full 3" Exhaust/ Racetec FMIC/ Stg 4 Clutchmasters/ V&S shift kit/
    H&R Coilovers /H Sport sways F&R/ AR racing 330mm BBK & S4 rear brakes/S4 HID's
    Sep 22 2008
    Minnesnowta (Roch)
    you will want a stage 3 at the very least for clutch. I would run a clutchmasters or southbend
    Oct 17 2009
    alonE, Pa
    CT2-5347 (540 Hp rating)
    Cat 3658 or V2 (Dan's recommendation for my setup)
    FX400 240mm or 850 (stiff)
    Remember not to skimp out on a good tune.
    STEVE
    New Member One Ring
    Feb 07 2012
    98 A4 1.8T
    Bloomington
    I've decided to sell my build, if anyones interested in any parts, shell, or built short block please let me know ASAP
    Jul 20 2011
    GT3076r E85 A4
    Minnesota
    bummer man. If it was a complete 2.0 block I would of came and taken it off your hands.
