Results 1 to 9 of 9
    Senior Member Three Rings flyingfish2626's Avatar
    Nov 23 2008
    2000 Chevy S10 ZR2
    Colorado
    Any other options for meth hookup besides the VAST up-pipe?
    Getting ready to pull the trigger on the VAST meth system. Wondering if there was any other options besides the VAST up-pipe to install the nozzles in? I know someone sells a mount system that you can put into your stock intake hose, but that is definitely not the way I want to hook it up. Can you inject the meth right into the manifold, via a boost tap like the BSH PCV revamp kit?
    2008 A4 Avant Spec. Ed/Ibis/Oynx/Sport/6-speed
    2001.5 S4 Avant/Pearl/Oynx/Tial 605/6-speed......Sold
    Senior Member Four Rings NorcalPB's Avatar
    Jul 15 2008
    Supercharged M3...sold/ Titanium B7 A4
    Tempe
    Vast Up Pipe
    034 Intercooler Piping Kit
    Any aftermarket intercooler with metal piping
    I was thinking about custom fabbing my own charge pipe, but the bends in the stock ones are rediculous and I don't think I can replicate it.
    Feb 20 2004
    Fridge full of Beer
    Marion, IA
    Devils Own sells a way that you can tap into a rubber hose. That's what I'm doing and it worked for about 5k miles. I'm upgrading to an AWE intercooler next week :)
    -Dan
    2007 Audi A4 S-Line Ti - JoM, Carbonio, Ecodes, RS4 Black Optic Grille, Tint, whole bunch of APR stuff, Forge, and AWE stuff, Devils Own Methanol Injection, just your run of the mill B7 that's been "tinkered" with
    Senior Member Four Rings Operator's Avatar
    Feb 06 2009
    Audi A4, Mit. Montero, Escort
    Wellington, CO/Cheyenne, WY
    Quote Originally Posted by Lensch09 View Post
    -Dan
    He said he doesn't want to use the OEM intake.
    Keith, check out Viz's thread in the builds section, I think his meth goes straight to the manifold. If you plan on going with a FMIC though, you may as well wait.
    K0R-GT Maestro tuned
    Info:
    Build
    History
    Active Member Four Rings Mc Suly's Avatar
    Aug 20 2010
    UPS TRUCK/AUDI B7
    MONTREAL, QC, CANADA
    ^Wait until you have fmic
    Black is beautiful
    APR HPFP|AWE FMIC|AWE Exhaust|RAI Motorsport 3"DP/HFC|145Bar Rail Valve|Stasis Coilovers|Meth Injection Kit|RS4 Rear Sway Bar|JHM SS|034 STUDS|S4 BBK|STOPTECH SS LINES
    Unitronic: Stage 2 HPFP
    Flat White Enkei PF01
    Montreal Audi Club
    Active Member Two Rings jsandor91's Avatar
    Jun 10 2011
    lawn mower
    Burlington nj
    Usrt has a adapter that goes after the throttle body that has a spot for meth.
    http://www.usrallyteam.com/index.php...oducts_id=1618
    Senior Member Four Rings SykoraA4's Avatar
    Aug 09 2007
    2006 A4 Avant, 09 Tiguan
    Mount Airy, MD
    ^^ good option. however if you mount it after the throttle body, remember you'll need a shut off solenoid:
    From Snow's site: Shut off solenoid is used to prevent siphoning when the injection nozzle is mounted after the throttle body and is exposed to vacuum. Solenoid link
    Snow also sells nozzle mounting bungs for aluminum/steel and silicone tubing.
    either way you will definitely need a nozzle to spray the meth in. simply mounting it to a boost tap will not work.
    - Will
    06_Avant . DTM . Votex . K0R-Gt . Unitronic . HPFPupgrade . CMstg4/lwfl . Votgland . Stoptec . etc...
    The Avants Timeline
    Senior Member Four Rings DRAKLORE's Avatar
    Oct 14 2009
    '81 Mk1 VW CADDY rabbit :-) yamaha fz6r
    Robins AFB, GA
    I would avoid tapping in the silicone, the effort to fab up a work around for the up pipe may cost more money than the vast pipe. I personally am
    Using my Godspeed FMiC up pipe tapped
    -Shane Drake
    DRAKLORE/VAST PERFORMANCE BAT B7A4 Built & Tuned
    DRAKLOREs Build
    VAST PERFORMANCE.com
    The Original Hipster B7 \[•]-[•]/
    Nov 23 2008
    2000 Chevy S10 ZR2
    Colorado
    Does anyone else make a up-pipe besides VAST? No way I am tapping into my stock hose.
