Results 1 to 19 of 19
    Jan 07 2012
    reno,nv
    aftermarket HID kit flickers HELP
    have a 01 a4 bought some aftermarket hid kit but flickers what can i do?? searched and didnt find a real answer help have a plug n play kit no relay or capictor thanks
    Feb 26 2010
    NOVA
    Quote Originally Posted by JoN775 View Post
    might be the problem, get some wire and run it from battery to hid and see if it still flickers. mine are relay installed, no flicker
    Active Member Two Rings teleTay's Avatar
    Jul 19 2010
    2000 A4 Avant, 2004 S4 Avant
    SLC UT
    my driver side flickered when i installed mine.
    i bought these capacitors http://www.ebay.com/itm/2Pcs-Warning...item19c9bb9673
    but they did nothing
    it ended up being that i had a defective ballast
    i would check to see if your ballast or bulb is defective
    i had a ballast that i pulled off of my fog lights until the replacement one shipped.
    Senior Member Two Rings colombian301's Avatar
    Jun 05 2010
    2000 bmw 328ci
    DMV, Maryland
    It should be a bad ballast. Where you get your kit from? If you got it from eBay than most likely that's prone to happen. I suggest you get hid kits from ddm tuning!
    99.5 A4 28RS 1.8TQS VolcanoBlk
    Vancouver, BC Canada
    mine just started doing it too. i have 55w ddm 5000k.
    mine flickers especially when the headlights are on and you turn on the high beams, then the headlights will turn off for like half of a second and turn on again.
    also, some scenario but with headlights on and turn high beams off, headlights will turn off for half a second and turn on again.
    David L.
    www.VancouverAudiClub.ca
    99.5 A4 GT28RS 1.8TQSM Volcano Black & 99 CW Acura Integra Type-R #0010
    Go-Unitronics/GT28RS/ATP/Bosch/Bailey/HKS/Blitzkrieg/FMIC/Southbend/Fidanza/Greddy/Innovate/Walbro
    Footworks-Roti BLQ/Flik LEX/Bilstein/Eibach f800 r900/Neuspeed/034/Stern/APR/Redline
    Misc-Porsche/S4 rear/Goodridge/Motul/Rieger/A!/Ecodes/RS4/V&S/Sparco/Podi/Blitz
    Soon-Eurodyne/Siemens/SnowPerformance
    Jan 07 2012
    reno,nv
    Gonna try the capacitor see if they stop
    Dec 29 2011
    1999 A4 2.8 30V Q, 2011 Corvette GS Convertible, 2008 Tundra DC LTD
    Southern MN
    Mine flicker a little, but only when the car isn't running. When running, rarely do they flicker if at all.
    Active Member Three Rings
    Jul 27 2010
    Brisbane QLD Australia
    My DDMtuning slim ballast HID kit failed in less than 4months. It failed on the LH side first and then 10months later the RH side.
    I bought mine through my sister who lives in US and when the LH side failed I ordered another set through their website as going through the warranty procedure for international customers can suck balls.
    I replaced the failed ballast with new ones and it worked again.
    Btw, the DDMtuning stuff originates from China(what else is not nowadays lol) and the part number on the ballast purchased from US and the ones shipped from China is slightly different, probably an update.
    Senior Member Two Rings Stumanbmx's Avatar
    Nov 04 2007
    '00 A4 1.8TQM
    Minnesota
    Threads like these make me hesitant to install the DDM HID's I've had sitting in a box for a year.
    Jan 07 2012
    reno,nv
    Put the capacitor and still flickers!!!!! [evil] what to do??
    Jun 05 2010
    2000 bmw 328ci
    DMV, Maryland
    Just get a new ballast. The reason I say this is because I installed my friends hid kit on his c350 fogs and he came back to me telling me they flicker. He bought a new kit and I only changed the ballast, not the bulb and problem was fix.
    The only reason why I recommend ddm tuning is cause they have life warranty. One of my ballast failed this summer. Took it out, shipped it to ddm tuning for 7 bucks and two weeks later new ballast arrive. Better than paying 50$ for a new set!
    If you have a friend or know someone with an hid kit maybe they can let you borrow their ballast just to make sure!
    Senior Member Three Rings CCA4's Avatar
    Oct 25 2009
    A4, Cannondale Ironman caad 5
    Sterling, VA
    It's probably a ballast, I had this same problem with my VVME HID's a few years ago. Before you buy one though, just double check all your grounds. A loose ground connection could also cause the flickering, and checking them is cheaper than buying a new ballast (becuase its free )
    01.5 A4 Avant 1.8TQM|VDO|K&N|APR TIP|710n|Stėrn|DieselGeek|Diode|Forge MBC|A8/TT|EBC Redstuff|Neuspeed Race|ATP 3" TP|034 Catch Can|Sport cloth swap
    Jul 19 2010
    SLC UT
    yeah just get get the ballast replaced
    dont waste your time with the capacitors
    our cars should provide enough power that it should not flicker because of lack of power
    Jan 07 2012
    reno,nv
    Emailed the place I got them from and they send me 2 new ones and still does the same ?? ;((
    Jun 14 2005
    Irvine, CA
    +1 on the ballast. I've had flickering HIDs in the past as well and it was due to the ballast going bad.
    JB @ VMR | Wheels
    (714) 442-7916 ext. 108 | jb@velocitymotoring.com
    www.velocitymotoring.com | | | Blog
    Jan 07 2012
    reno,nv
    But the ballasts are new have 2 new sets and they flicker damn his I'm giving up :(
    Senior Member Three Rings gmx's Avatar
    Mar 01 2008
    '00 1.8TQMS
    Sydney, AU
    Quote Originally Posted by spindoctor View Post
    yeah I also bought from DDMTuning via a friend. They suck. My LH failed about 6months in. Always causes weird electrical issues when firing them on. Can't be good for the car. Next chance I get OE Euro S4/RS4 headlights are going in.
    00 A4 1.8TQ MT (AJL)
    JHM SSK
    17*8 BBS RK | Vogtland GT 575F/675R | H-Sport Sways
    GT2871R Elim | Unitrash 415cc file | 034 3" HFC | Milltek Dump back | 034 HFM (finally cracked!) | 034 TIP
    3090lbs
    Active Member Two Rings wolverineottawa's Avatar
    Mar 19 2011
    2005 Turbo Lancer Ralliart 2003 Ford Expidition
    Ottawa Ontario Canada
    I had cheap hid on my lancer and I had fliclering issues. The issues was a loose connector from the harnes to the ballast. I went through a few ballasts before I said nuts to this now i enjoy my silverstar....lol
    Jan 07 2012
    reno,nv
    Think I'm goin back to the bulbs bugs me when it flickers
