Results 1 to 11 of 11
    Nov 13 2011
    Tampa Fl
    Engine swap limitations
    Who should I talk to about engine swaps in the B6 platform? Specifically ecu oriented questions?
    Active Member Three Rings M|R's Avatar
    Aug 11 2011
    Not sure who to talk to...but this would make one nasty engine swap...
    B7 S4
    034 Tranny Mount • Apikol Snub • DBA 4000 • Fast Intentions • Hawk HPS • JHM SS • Trexturk 2.5" Catless • Vag'd
    034 Tranny Mount for sale: http://www.audizine.com/classifieds/...?product=71719
    Senior Member Four Rings dparm's Avatar
    Apr 24 2009
    2005 S4 sedan
    Chicago, IL
    Quote Originally Posted by tampas4 View Post
    Well what are your specific questions?
    2005 S4 saloon 6MT
    Nov 13 2011
    Tampa Fl
    My options as to what will and won't work in the car if the stock ecu is removed, and what can be run with a stand alone. Whether I can or cannot run 2 ecu's, a gm ecu for the gm swap motor and leave the stock ecu for the rest of the car. Who could wire it and how much would it cost. I'm not concerned about gauges but I do want the airbags, abs, climate control to work. I know very little about the bosch ecus I've only really worked with Denso units before so I don't know where to even begin. I've been poking around in the A4 forums, looks like there is a fair amount of swapping going on there, don't know how relevant that is.
    Senior Member Two Rings 65vetteC6's Avatar
    Jul 28 2007
    New Jersey
    Quote Originally Posted by M|R View Post
    This would, if it were real lol. Guy started up is lsx rx7 if i remember correctly and just taped the S4 as a prank.
    Senior Member Four Rings B6JoeS4's Avatar
    Sep 13 2008
    '05 S4 MT6 pollution machine
    Chicago NW Burbs
    You pretty much have to run full stand-alone
    GO: 2.5" trexturk catless dp's // 2.5" x- piped cb // JHM Stg 3 // 034 LWFW // JHM 93 // JHM SS // JHM LW Rotors // Apikol Snub // Stern Street Motor // Stern Trans // JHM LWCP // 034 MAF hose // RS4 Sway
    SHOW: 18" Enkie RPF1 // FK Coils // 35% Tint // Ecodes // HID fogs // Pioneer F90BT // RS4 Shifter // RS4 Pedals // B7 Console // Valentine 1
    AudiRevolution.net
    Senior Member Four Rings BCsniper's Avatar
    Jan 29 2010
    B6 S4 6MT Avant, B6 3.0 Avant 6MT (for sale), C5 A6 2.8 (needs fixing)
    north ga
    Check out "Project Judas" over on MotorGeek.com
    http://motorgeek.com/viewtopic.php?f...fb8c7c3a19aa45
    He finally wrapping up his LS swap into a C5 RS6. He kept the Audi accessories (AC, powersteering, TCU) to keep the cluster happy and ran the GM ECU for the engine only. As a heads up though, he barely made that motor to fit into a a RS6, so imagine how much room you've got to work with in the B6. He's said that as far as ease of installation goes, a D2 A/S8 would probably be easiest to do the swap with because it's got even more room in the bay vs the C5 A6 chassis
    Aug 11 2011
    Quote Originally Posted by 65vetteC6 View Post
    Lol I thought it was something along those lines...nonetheless it would be one crazy swap haha
    B7 S4
    Senior Member Three Rings madkimchi's Avatar
    Sep 09 2009
    Bicycle and roller blade.
    Kent, WA
    Quote Originally Posted by BCsniper View Post
    that is one crazy engine swap.
    PS3 ID: NKoreanAssassin
    Xbox ID: N Korean
    save me if you play Call of Duty Modern Warfare 3.
    Jan 29 2010
    north ga
    Yeah people often jump to say, "why don't you just get an XX engine and throw it in there, that'd be awesome, you'd make crazy power yo!". Well it's a lot more complicated than just "throwing it in there" the actual work that goes into making things not only fit but actually work are much more complicated. Same goes for the guy putting the RS6 Timing Belt 4.2 TT into a B7 RS4. I wish more could be seen of that build besides the 4-6 pictures from that one magazine article about it.Cutting frame rails for more space is going much further than just "throwing it in there"
    Nov 13 2011
    Tampa Fl
    I have a used Lq4 from my dads wrecked silverado. There's something wrong with my timing system so when I pull my motor I can compare the two better, if it's close size wise I'm gonna get more serious about this. I found a guy that makes an adapter plate for the 01e to LS with a flywheel and clutch for $1400, don't think it would be too much harder to make one for the 0a3. If it looks like too much cutting, hammering and welding then I'll look at other options. The fact is though that I have a 170k motor, even if I overhaul the timing system for $3000 I will still have a 170k motor with heads that cost over 4 g's a piece and a short block that is expensive to rebuild (Jhm charges 8000 for their base rebuild). That's quite a large incentive for me to get this done.
    *P.S. backing my car into the garage tonight I rolled over a jug of used oil and sprayed it everywhere! :(
