Results 1 to 8 of 8
    Aug 12 2009
    New Hampshire
    AMI cable rerouted to center console
    Great car weekend, after the winter driving school on Saturday (see other post) I finished up stage 2 of my AMI cable re-route project on Sunday. People on here have done much more impressive versions of this, but I was happy with the way it came out. Used two CableJive DockExtenders, a 6' and a 2'. Routed the cable out the back of the glove box, under the center console trim and through the back of the compartment under the armrest.
    Stage 1 was last weekend, I removed the glove box (link below, mine had 10 bolts vs. 7 in his but they were easy to find) and carefully expanded a hole that was back there using a drill and a file. Then I routed the 6' cable under the center console and just left it sticking up next to the passenger seat belt.
    That worked fine but I wanted to make it better. Under my armrest there was a blank where some cars have an AUX input, mine had a removable felt cover. I was able to drill a hole in the center of the cover, slit one corner with a dremel and then fit the cable through. Not perfect but looks fairly OEM.
    To route the cable I removed the rear A/C vent and ashtray (link below), from there it was fairly easy to snake the 2' extender through the blank and connect it to the 6' under the center console beneath the vent. You can see the connection below with the vent/ashtray removed.
    Thought maybe all these connections would reduce sound quality, tested it beforehand and couldn't notice a difference but I'm far from an audiophile. MP3s and Pandora sound great to me through the B&O and I can now easily keep my iPhone in that slot in the console.
    Resources:
    Original inspiration: http://www.audi-sport.net/vb/audi-s4...e-armrest.html
    Glove box removal: http://www.audi-sport.net/vb/audi-s4...formation.html
    Rear vent/ashtray removal: http://www.audizine.com/forum/showth...-Removal-Guide
    Active Member Three Rings maga4's Avatar
    Aug 12 2011
    Olathe, Kansas
    Nice job, thank you for sharing!
    2011 A4 Premium+, Quattro, 6MT, 18" OEM 5-spokes, Nav, Black/Black
    APR Stage 1, 35% Tint, Eibach Pro-Kit, Vag-Com, Gloss Black 3.2 Grille, Hoen Endurance Fogs, LED Interior/License Plate Lights, Strat Short Shifter, BFI Catch Can, Eurocode TIP/TRUFit Kit/HFIP, Hardwired V1, Rieger Lip Replica
    '91 Audi 90s Quattro, 5MT, White, stock
    Past: '98 A4 1.8TQ, Tip, Red / '99 A4 1.8TQ, 5MT, Black, Sport
    Senior Member Four Rings Ryan_T's Avatar
    May 11 2009
    09 A4 2.0T
    T.O - Canada
    Very nice. I have mine routed there too, but not as cleanly.
    Ryan - flickr
    Active Member Two Rings keeva381's Avatar
    Mar 24 2011
    Raleigh, NC
    Very nice. I have not seen any write up or pictures with that AMI version, which is what I have. The other write up on the forum has that older box in the glove box that you can remove. I have the extension cables and ready to do this mod, so I might be asking some questions eventually. Great job!!
    Mar 02 2004
    Phoenix, AZ
    Very nice man! I've been wanting to do this exact same thing for a while. Why did you need two extension cables? Would it not work with just one routed from the glove box to the space under the arm rest?
    2011 Audi A4 • Premium Plus • Navigation+ • Sport Package • Bang & Olufsen
    www.DIYAudi.com: Audi Wheel Spacers Install • Audi MFSW Install • Audi Cargo Mat and more...
    Active Member Two Rings V1Rotate's Avatar
    Nov 01 2011
    Northern VA
    Wow, you beat me to the write up! I did the exact same thing, except I have the 3.5mm ami cable, and run it to my droid phone. I popped out the rear vents just as you did, and ran it through. All in all, took about an hour. Good job
    -2009 Tip. A4 Prestige Ibis White
    -StaSis Coil-Overs, Exhaust, ECU Tune
    -Carbonio Intake, Eurocode: TIP, HFIP, USS, Alu Kreuz, HFC w/ Strat. 90d Spacer
    -19' BBS CH-R's ET40 w/Michelin 255/35/19
    -Hardwired Escort Redline, 20% Tint, Hoen Yellow H11 Fogs
    Active Member Two Rings STA4's Avatar
    Jan 12 2012
    Mississauga, ON, Canada
    I'm going to have to do this for sure.
    Peter
    2009 A4 2.0T Quattro Premium 6MT
    Meteor Grey/Black | B&O | STaSIS ECU/Exhaust/Springs/RSB/Rims | K&N Filter | Eurocode TIH/HFIP/IHK/HFC | Strat O2 Spacer | BFI OCC | Podi Boost Gauge | Rieger Rep Spoiler | LED Interior/Doors/Plate | 5000K HID Foglights
    Aug 12 2009
    New Hampshire
    Thanks guys, hope it's helpful. Def seems easier on the '10+ glove boxes like mine with no AMI box to deal with. Prob the main step to be careful on is drilling the glove box hole, as the space I used is right by a thick bundle of AMI cables running on the back of the glove box to the MMI interface I imagine. The whole thing took me several hours, but I mod really slow when doing stuff the first time, especially when removing trim pieces held in by clips. They always feel like they are about to break right before they pop off, so I take my time.
    On the cables, if you look at the last picture, where the connection occurs was about as far as the 6' cord would go, as far as I could tell. So I don't think it will reach, at least with my AMI setup with the cable on the far right side of the glove box. You could probably make it work with one cable by drilling/cutting a new hole in the armrest compartment on the front near the cup holders. I thought about that at first, I think you'd want to remove the whole center console to do that, which is doable but more work. I decided to just order another cable, which sort of sucked as they are $25-$30 each.
